查看: 15988|回复: 3
杆单元长经比的设置
发表于 2005-9-6 16:24:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位同仁:
请问对不同类型的杆单元长经比有什么一个比较优的数值范围没?
犹如网格单元一样,谢谢先
发表于 2005-9-15 18:41:40 | 只看该作者
>=2.5
发表于 2005-10-26 21:18:02 | 只看该作者
不出現WARNING﹐就肯定是設置沒問題﹐其實很多東西可以去調整試一下。以前做分析時總是出現WARNING﹐改了一些Y設置及MESH就越來越少﹐當然重要的是要去查詢。
发表于 2005-10-27 15:26:56 | 只看该作者
The optimum L/D ratio for cooling line related beam elements is 2.5. Significantly lower L/D ratios can result in solver convergence warnings in the analysis. Significantly higher L/D ratios may result in solver convergence warnings and a reduction in solution accuracy.
The exception to this rule is gates,which must contain at least 3 elements,These elements will have a much smaller L/D ratio.
GMT+8, 2026-7-16 06:20 , Processed in 0.055955 second(s), 15 queries , Gzip On, Redis On.
