查看: 18238|回复: 5
斑竹请进,急,
发表于 2005-9-10 11:17:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我现在做动力学仿真,measue了三个角度,然后在postprocessor用spreadsheet导出转角数据,我看了你前面的例子,从view里的import这些数据,create culve,然后在motion里用AKISPL(time,0,SPLINE_6, 1)*time,但是机构的动作不是要求的那样,不知道怎么回事,节选一些错误提示如下:
WARNING:    ADAMS will no longer warn for any out-of-range violations for
   SPLINE scenario_2.SPLINE_6. Out-of-range X and Z values of spline have been used more
   than 5 times.
WARNING:    An out-of-range X value has been used in the spline calculation.
   Extrapolation is required for the SPLINE scenario_2.SPLINE_4.
   The X value ( 0.0 ) should be between 1.0 and 51.0.
   The X value ( 1.0E-05 ) should be between 1.0 and 51.0.
   SPLINE scenario_2.SPLINE_4. Out-of-range X and Z values of spline have been used more
   than 5 times.
WARNING:    The symbolic refactorization failed.  The matrix is structurally singular
   at time = 1.1891.
WARNING:    ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
   NOTE:  The set of redundant constraints has changed at time = 1.1891.
   at time = 1.1891.
   at time = 1.1891.
斑竹和各位高手指点迷津
发表于 2005-9-16 08:36:25 | 只看该作者
发表于 2005-9-19 10:32:33 | 只看该作者
发表于 2005-9-19 16:00:19 | 只看该作者
发表于 2005-9-20 09:03:34 | 只看该作者
发表于 2005-9-20 09:42:48 | 只看该作者
GMT+8, 2026-8-2 15:35 , Processed in 0.047368 second(s), 11 queries , Gzip On, Redis On.
