查看: 16577|回复: 5
Pro/ENGINEER Wildfire 3.0 可以使用汉字输特征名啦!
发表于 2005-9-22 18:40:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Pro/ENGINEER Wildfire 3.0 Preproduction 提示可以使用双字节文字啦!
After you install support for a given non-English language on an English system, you can do the following operations:
Display language-specific characters in Pro/ENGINEER files.文件名可以用中文
Input and edit text containing language-specific characters in Pro/ENGINEER files.特征名亦可
Display the localized user interface.本地化接口也能用中文
Print language specific characters.打印也OK,,WF2.0也可以的。
当然,proe的工作未到家,双字节的输入有相当一部分不能用,但毕竟我们期待了6年啦!
Multi-byte Character Input Areas within Pro/ENGINEER have multi-byte character input enabled or
     disabled. See the table below.
Pro/ENGINEER Area        Multi-byte Enabled                                       Multi-byte Disabled
Assembly                              None                                                         Zone namesFamily Table instance
        names
        Enveloe  names
        Piping names
Fundamentals (Core)        Parameter namesParameter values
                                          (string values)
                                         Feature names
                                         RelationsView names
                                        Light Source names
                                        Cosmetic dimension/text (not symbol)
                                           Cross-section names
                                       FEM constraint-case names
                                       Beam-section names Model notes                            Family Table instance names
        Material names
        Cosmetic dimension symbols
        Group names
        UDF library names
        Simplified Representation names
        Layer names
        3D text in featuresconfig.pro file
        Folder names
Detailing                  Notes Balloon Notes Group name Table text                     Axis names     Draft itemsS   ymbol names
        Draft datum namesLine style names
Diagram                                        None        Spool Names
Layout                                             Case Study names                     Draft datums
Manufacturing        NC sequence comments
                                                       Fixture names                   Workcell namesSite names  Register names
        Radius substitute table names
        Operation namesVolume names
        NC sequence names
Process                                           Step description                                       None
发表于 2005-9-22 19:27:17 | 只看该作者
About Multi-byte File Name and Character Support
To process text on a computer, unique numbers are assigned to each letter or character in a language. This assignment is referred to as encoding. European languages (single-byte languages) use about 150 characters. Therefore, the numeric range of a single byte (0—255) is sufficient to encode European languages. Asian languages (multi-byte languages) use thousands of characters, requiring multiple bytes to store the numeric code of a single character.
Pro/ENGINEER provides universal support for single-byte languages. For multi-byte languages there are some limitations as described in the next two tables.
File Types Supporting File Names with Multi-byte Strings
哈哈,真是做整机设计工程技术人员的一大福音。但大多数人用她做注塑模具设计,真是一种资源浪费!
发表于 2005-9-22 19:34:05 | 只看该作者
x:\Program Files\proeWildfire 3.0\i486_nt\pvx\pvx_install.exe.
or
x:\Program Files\proeWildfire 2.0\i486_nt\pvx\pvx_install.exe.
你可以安装web页下的快速看模型软件,由于文件独立于PROE且文件很小,因而可以COPY文件夹PVX到无安装PROE的笔记本或不太懂proe的boss的机上安装,SHOW pat/asm 用鼠标即可,ASM文件要都到位,u盘就可以了,演示但不能修改。3.0版向下兼容2.0,反之不行。
发表于 2005-9-24 19:15:49 | 只看该作者
什么意思~~翻译一下~
头像被屏蔽
发表于 2005-9-26 13:43:20 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2005-9-27 10:44:27 | 只看该作者
看不大明白!
GMT+8, 2026-7-6 09:23 , Processed in 0.050586 second(s), 13 queries , Gzip On, Redis On.
