查看: 18033|回复: 4
Array of object identifiers???->这个FTN(uf5947)
发表于 2005-10-5 15:17:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
extern UFUNEXPORT void FTN(uf5947)(
const double *rp1,            /* <I>
                              Defined Transformation Matrix.  This must be
                              a 16 element array.  This array should be
                              initialized using the functions uf5942-uf5946
                              to produce the required transformation.
const tag_t *np2,            /* <I>
                             Array of object identifiers.
const int *ip3,               /* <I>
                              Number of objects in np2 array.
const int *ip4,               /* <I>
                              Move/Copy Status
                                  1 - Move
                                  2 - copy.
const int *ip5,               /* <I>
                              Destination Layer,
                                  0       - the original layer,
                                  -1      - the work layer
                                  1 - 256 - the specified layer
const int *ip6,               /* <I>
                              Trace Curve Status, 1 means on, 2 means off.
tag_t *nr7,                /* <O>
                           List of copied object identifiers.  This is
                           not used when ip4 = 1.  When ip4 is 2, this must
                           be dimensioned by the caller as large enough to
                           contain the same number of objects that are in np2.
tag_t *nr8,                /* <O>
                           Group of trace curves.  This is not used when
                           ip6 is set to 2.
int *ir9                   /* <O>
                           Status Code
                             0 - Success
                             1 - Too Many Or Too Few Entities To
                                 Transform
                             2 - Invalid Parameter
                             3 - Invalid Object (Not Alive Or Not
                                 Transformable)
                             4 - Shear Matrix With Non-shearable
                                 Objects In The List
                             5 - Modeling update error
                             6 - Error adding modeling data to copied solid
                             7 - Cannot scale parametric solid
                             8 - Transformation is unsuitable for the object
                             9 - Cannot scale developed curve
                            10 - Cannot mirror solid
                            11 - Cannot transform occurrence
                            12 - Cannot transform sketches or sketch curves
上面这个fucntion中np2是一个tag_t的数组的指针,但是事先并不知道有多少个实体,数组成动态的了,怎么弄啊,同志们?
发表于 2005-10-5 18:46:22 | 只看该作者
发表于 2005-10-5 20:47:20 | 只看该作者
发表于 2009-4-24 14:01:18 | 只看该作者
发表于 2011-3-25 19:30:02 | 只看该作者
GMT+8, 2026-8-3 21:50 , Processed in 0.046471 second(s), 11 queries , Gzip On, Redis On.
