查看: 15652|回复: 0
汉化疑问,请大虾帮忙
发表于 2005-10-9 19:17:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
有的还是5轴的,我的版本还没,大多数是新增加的功能啊
我不熟悉,怕翻译的不好,大家看看
1174,Limit Passes of Stock Spiral
1175,Change Strategy IF # Stock Spiral Passes >
1176,Fixed + Horizontal Planes
1177,Skip Planes Close to Fixed Layer
1178,Z Margin
1179,Consider Holder & Shank
1180,Calculate Minimal Clear Length
1181,Effective Coverage Radius
1182,Ignore Narrow Areas
1183,Min. Narrow Area Width
1184,Cutting Style
1185,Clean Between Passes
1186,"Bi-Directional "
1187,Cut Strategy
1188,Plunge Feed (mm/min)
1189,Retract Feed (mm/min)
1190,Plunge Feed (cm/min)
1191,Retract Feed (cm/min)
1192,Plunge Feed (m/min)
1193,Retract Feed (m/min)
1194,Plunge Feed (feet/min)
1195,Retract Feed (feet/min)
1196,Plunge Feed (inch/min)
1197,Retract Feed (inch/min)
1198,Access
1199,Gouge Check
1216,Rounded Stretch
1217,A Procedure must either "Output Motions" or "Create Contours".
1218,Final Cutting Mode
1219,Main Cutting Mode
1220,Horiz. Minimal Radius
1221,Horiz. Acceptable Trim Distance
1222,Horiz. Round Fallback
1223,User Defined
1224,Inner Lanes
1225,Use Minimal Radius
1226,Do Not Round
1227,Allow Lift
1228,Minimal Radius
1229,Acceptable Trim Distance
1230,Round Fallback
1231,Machine Between Layers
1232,Volume Milling Strategy
1233,Side Step
1234,Between Layers Strategy
1235,Vertical Step Type
1236,Max. Vertical Step
1237,Min. Vertical Step
1238,Max. 2D Distance
1239,Bottom Up
1240,Top Down
1241,Layers Order
1242,In “Between Layers”, the Min. Vertical Step must be smaller than the Max. Vertical Step.
1243,Horizontal Machining Limits (HML)
1244,Outer Machining Limits (OML)
1245,Tooltip Pencil Curves (TPC)
1246,Touch Point Boundaries (TPB)
1247,Ignored Machining Areas (IMA)
1248,Horizontal Local Areas (HLA)
1249,Appr./Retr. - Below Z Limit
1250,Z Limits
1251,Rough
1252,Finish
1253,"Rough + Final Pass "
1254,Part Surfaces Wall Offset
1255,Check Surfaces Wall Offset
1256,Control Mode
1257,Connection Mode
1258,Note: The toolpath calculation disregards the Slot Mill / Lollipop property of the used Cutter.
1259,Basic
1260,Advanced
1261,Top Only
1262,Bottom Only
1263,Top & Bottom
1264,Limit :
1265,CBP & Ridges
1266,Ridges Only
1267,CBP Only
1268,Cutter Tilt Control
1269,Complete
1270,Maintain Tilt
1271,Z-Top must be greater than Z-Bottom.
1272,A PolyLine boundary that belongs to the Set - "%s" cannot be used. Rename the Set.
1642,Micro Milling Scale Factor
1643,Micro Milling Use
1644,Micro Milling Max. Contour Gap
1645,Some faces are beyond the procedure’s tolerance.$0AThese faces have been put in the set “Faces out of tolerance”.$0ATry to heal the gaps for these faces using the CAD functions ”Unstitch” and re “Stitch”.$0A$0A $0A$0A
1646,Faces out of Tolerance
1647,The Clearance Z value (%f) is lower than the maximum Z of the Part (%f) plus the safe Z (%f).
1648,Pick one or more Lines that have been predefined from the Tip towards the Spindle and then exit.
1649,Shift Distance (Tangent)
1650,5X Aerospace Control Panel
1651,Morph Between 2 Curves Control Panel
3150,Drive Surface Tolerance
3151,Adaptive Feed Control
3152,Feed Table
3153,Rapid Retract
3154,Drive Surfaces
3155,Max. Holder Dia. Considered
3156,The Holder Gouge Check does not consider the maximum holder diameter.
3157,Check Surfaces (#2)
3158,Check Surfaces (#3)
3159,Stock Surfaces
3160,First Boundary Surfaces Set
3161,No boundary surface was found by criteria.
3162,Second Boundary Surfaces Set
3163,Tilt Lines
3164,Projection Curves
3165,Layers Connection
3166,Connection Method
3167,Connection Shift
3168,Shift Distance (On Surface)
3169,Connection Overlap
3170,Overlap Distance
3171,Approach = Retract
3172,Preferred Approach Radius
3173,Preferred Retract Radius
3174,The Initial Stock accuracy is too low. This may affect machining quality. $0A Either: Delete the current and previous stock and also the part, and then define a smaller Initial Stock. $0A Or: Change the initial stock type to be Box or Bounding Box.$0A$0A
3175,The part is far from the MODEL UCS. This may affect machining quality due to reduced accuracy of the Stock.$0AConsider moving the part closer to the MODEL UCS.$0A
3176,Tilt Curve
3177,Lead Curve
3178,Single Edge Curve
3179,Single Edge Surface
3180,Part Surfaces Automatic Selection
3181,Ignored Surfaces
3182,No ignored surface was found by criteria.
3183,Select Line
3184,R
3185,F
3186,RM
3187,F
3188,Curve
3189,2X
3190,Drill
3191,Connect
3192,5X
3193,Special
3194,Parallel
3195,Spiral
3196,ReRough
3197,L_Stk-Spiral
3198,L_Parallel
3199,L_Spiral
3200,L_Plunge
3201,L_Zcut-Par
3202,L_Zcut-Rad
3203,All
3204,Slope
3205,Hor
3206,Profile-3X
3207,Profile-3X
3208,L_3D-Step
3209,L_Stk-Spiral
3210,L_Parallel
3211,L_Spiral
3212,L_Layers
3213,L_Hor
3214,L_Hor
3215,L_Hor-Rad
3216,L_Vertical
3217,L_Pocket-Walls
3218,L_Radial
3219,Cleanup
3220,Pencil
3221,L_Cleanup
3222,L_Cleanup
3223,L_Cleanup
3224,L_Cleanup
3225,L_Cleanup
3226,L_Cleanup
3227,L_Cleanup
3228,L_Cleanup
3229,L_Cleanup
3230,L_Cleanup
3231,L_Cleanup
3232,L_Cleanup
3233,L_Cleanup
3234,L_Pencil
3235,L_Hor-Rad
3236,Aiming-3X
3237,Aiming-4X
3238,Aiming-5X
3239,Flow-3X
3240,Flow-4X
3241,Flow-5X
3242,Ruled-3X
3243,Ruled-4X
3244,Ruled-5X
3245,Flow-Morph
3246,3X
3247,4X
3248,5X
3249,Trim-5X
3250,Pocket
3251,Pocket
3252,Pocket
3253,Pocket-Walls
3254,Profile
3255,Profile
3256,Profile-Plane
3257,Profile-Plane
3258,3X
3259,4X
3260,5X
3261,3X
3262,4X
3263,5X
3264,Aerospace
3265,Rough 5X
3266,Dyn-MX
3267,Mill-Go
3268,Ruled-Mx
3269,Mill-API
3330,Stock - Surf
3331,Stock - Cont
3332,Stock - Box
3333,Stock - Auto
3334,Stock - File
3335,Stock - 5X
3336,Draft Angle (common)
3337,Slot Mill / Lollipop
3338,Contour Offset
3339,Boundary Offset (common)
3340,Contour Offset (common)
3341,Various
3342,Cutter Location (common)
3343,Milling Side (common)
3344,Check Surfaces (#1)
3345,Machine Params.
3346,Motion Params.
3347,Sketcher
3348,Composite
3349,Pick Drilling Points and Exit.
3350,It is not recommended to edit an NC-Lite procedure within the Standard NC environment $0A(due to a difference in surface selection definitions). $0AYou may, however, copy the NC-Lite procedure to a Standard toolpath and edit it.$0AIf you still want to edit the NC-Lite procedure within the Standard NC environment, press Yes. Otherwise, press Cancel.$0A$0A
GMT+8, 2026-8-17 03:06 , Processed in 0.049575 second(s), 11 queries , Gzip On, Redis On.
