查看: 17351|回复: 0
CATIA V5R15sp3 HotFix6 对应Bug列表
发表于 2005-10-14 10:04:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
- This CD-ROM is the hotfix number 6 on SP3.
- Here is the list of problems that have been fixed since the first hotfix level.
- All of these corrections are present on the current CD-ROM.
- Level FUNCTION       APAR      Abstract
  HF2   MECMOD         HD41739   NULPMRCAD00504: Cannot query CATIMechanicalImport interface
  HF2   IGRIPDEV       DR4503    V5 is terminated with selecting Mechanism Properties
  HF2   GENDRAFT       HD42994   GENERATIVE DRAFTING / CATIA ABENDS ON DELETE OF ABF SYMBOL WITHOUT ANY LINK TO 3D
  HF3   ABFASTEN       HD43021   GSD / FILE SIZE INCREASES AFTER SAVE MODEL EVEN IF IT IS NOT EDITED
  HF3   DMPPRHUB       DR4530    Link of curve geometry increased automatically saving details
  HF3   DPMBIW         DR4534    Curve geometry isn't saved in detail when not linked to Process
  HF3   DMPPRHUB       DR4566    Cannot create resources in DPM with env variable set
  HF3   PRODSTRU       HD43438   PRODUCT STRUCTURE / SAVE AS 3DXML OR OPEN OF 3DXML LEADS TO CATIA CRASH
  HF3   ADVMESTO       HD41538   FMS : Distorted mesh on Sweep 3D mesh
  HF3   DOM            DR4542    ABF shape is NOT displayed in 3D window with MFR add-on
  HF3   ADVPMACH       HD43445   ADVANCED MACHINING : The created Tool path is not parallel to Guide curve.
  HF3   HUMNSIM        DR4575    Swap and Reset in the manikin's context menu do not work
  HF3   DMPPRHUB       DR15000   Copy command creates unusable alternatives
  HF4   MECMOD         HD38661   NULPMRCAD00505: PartBody contains a deactivated-feature is abnormal
  HF4   CATIAST        HD41844   STCAI / CATIA PERFORMANCE ISSUES WHEN CONNECTED TO SMARTEAM
  HF4   SHAPEDSG       HD41882   GSD 2D SECTION VIEW 2D SECTION IS NOT CORRECTLY PLACED ON 3D SUPPORT
  HF4   IGRIPOLP       DR4576    Least squares calibration incorrect results
  HF4   ITVPMCV5       HD43620   CONTEXTUALLY DESIGNED PART IS NOT UPTODATE WHEN PRODUCT IS RELOADED & SWITCHED TO DESIGN MODE
  HF4   DPMPLAN        DR4590    Deleted fastener data on E5 remains on the process data
  HF4   MOLDTOOL       HD43857   MTD / COMPONENT DELETED WHEN COMMAND WAS CANCELLED.
  HF4   MECMOD         HD43888   NULPMRCAD00583: The status of RemoveAttribute is illigal
  HF4   SURFMACH       HD43966   SMG / HIDDEN TOOL PATH IS SHOWN AFTER TOOL PATH REPLAY
  HF4   DMPPRHUB       DR15000   Impossible to display centrally the tree elements of Process com
  HF4   DMUNAV         DR4610    3D annotation not hidden when father component is hidden in pres
  HF4   DMPPRHUB       DR15000   Error Message while using Back button while loading a project fr
  HF5   DPMASM         DR4415    The product is not highlighted.
  HF5   DMPPRHUB       DR4552    Message saying 'Selected Activity is not loaded' comes up
  HF5   MECMOD         HD43728   NULPMRCAM00579: Runtime exception is generated at WarmStart
  HF5   HUMNSIM        DR4605    'Initial' posture is not correct
  HF5   ELECHARN       HD44401   ELECTRICAL / ON JAPANESE Env, MULTI-BRANCHABLE DOCUMENT IS SAVED AS CATPRODUCT, INSTEAD IT SHOULD BE CATPART
  HF6   DLGENGI        HD43986   NULPMRCAD00585: ExecuteUndoAtEnd is illegal
  HF6   SURFMACH       HD44084   SMG / WARM START / CORE DUMP
  HF6   INTDRAFT       HD44278   DRAFTING INFRASTRUCTURE / TIME TAKEN TO OPEN A DRAWING IS MUCH MORE THAN THAT AT R13 LEVEL
  HF6   OBJMOD         HD44315   Memory allocation failure when opening data
  HF6   DMPPRHUB       DR4654    Load PPRHub resets tools.options.DigitalMockup.DMUNav.Update
  HF6   MOLDTOOL       HD44617   MTD / CONSTRAINTS ARE NOT CREATED FOR PRODUCT COMPONENT.
  HF6   SYSTEM         HD44688   NULPMRCAD00603: When CATDUA is executed, applicative attribute is lost
  HF6   IGRIPARC       DR4661    V5 freeze at selecting Weld Node in Edit Curve Fastener.
  HF6   SYSTEM         HD44718   System downs on Synchronize Applicative Attributes.
GMT+8, 2026-8-12 19:18 , Processed in 0.049628 second(s), 11 queries , Gzip On, Redis On.
