查看: 15794|回复: 0
pre-配制文件
发表于 2005-10-23 21:24:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
mapkey(continued) ~ Activate `main_dlg_cur` `ProCmdViewRepaint.view`;t.view`;
mapkey t @MAPKEY_NAME打开扭曲总菜单。;@MAPKEY_LABEL扭曲;#FEATURE;#CREATE;#TWEAK;AK;
mapkey v @MAPKEY_NAME插入一个阵列特征。;@MAPKEY_LABEL阵列;#FEATURE;#PATTERN;TERN;
mapkey z @MAPKEY_NAME对实体赋予各种颜色和不同外观。;@MAPKEY_LABEL颜色和外观;\
mapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1 `View`;~ Close `main_dlg_cur` `MenuBar1`;\
mapkey(continued) ~ Select `main_dlg_cur` `View.cb_view_mdlsetup`;\
mapkey(continued) ~ Close `main_dlg_cur` `View.cb_view_mdlsetup`;\
mapkey(continued) ~ Activate `main_dlg_cur` `psh_view_appearances`;
mapkey yy @MAPKEY_NAME执行次命令。;@MAPKEY_LABEL插入和拭除;\
mapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1  `View`;\
mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\
mapkey(continued) ~ Activate `main_dlg_cur` `View.psh_view_show_erase`;
mapkey zz @MAPKEY_NAME插入一个用户组特征。;@MAPKEY_LABEL用户组特征;#FEATURE;#GROUP;\
mapkey(continued) ~ Close `file_open` `file_open`;#FROM UDF LIB;
mapkey zzz @MAPKEY_NAME删除所选特征。;@MAPKEY_LABEL删除;#FEATURE;#DELETE;
mapkey aaa @MAPKEY_NAME执行渲染操作。;@MAPKEY_LABEL渲染;\
mapkey(continued) ~ Activate `main_dlg_cur` `psh_view_photorender`;
mapkey bbb #FEATURE;#CREATE;#PROTRUSION;#USE QUILT;#DONE;\
mapkey(continued) ~ FocusIn `Odui_Dlg_00` `sel.selbut.quilt#0`;
sketcher_overview_alert no
force_new_file_options_dialog no
save_drawing_picture_file both
save_model_display shading_lod
2button_mouse_mmb_support yes
prompt_on_erase_not_disp no
dxf_out_drawing_scale yes
default_draw_scale 1
sketcher_undo_stack_limit 60
mapkey 2 ~ Select `main_dlg_cur` `MenuBar1`1  `View`;\
mapkey(continued) ~ Select `main_dlg_cur` `View.cb_view_advanced`;\
mapkey(continued) ~ Close `main_dlg_cur` `View.cb_view_advanced`;\
mapkey(continued) ~ Activate `main_dlg_cur` `psh_util_colors_sys`;\
mapkey(continued) ~ Select `color_scheme` `MenuBar2`1  `MenuScheme`;\
mapkey(continued) ~ Close `color_scheme` `MenuBar2`;~ Activate `color_scheme` `Scheme2`;\
mapkey(continued) ~ Activate `color_scheme` `OK`;
mapkey 3 ~ Select `main_dlg_cur` `MenuBar1`1  `View`;\
mapkey(continued) ~ Close `color_scheme` `MenuBar2`;~ Activate `color_scheme` `Scheme1`;\
graphics win32_gdi
set_trail_single_step yes
rename_drawings_with_object part
template_solidpart D:\PTC\proe2001\templates\mmns_part_solid.prt
template_designasm D:\ptc\proe2001\templates\mmns_asm_design.asm
template_sheetmetalpart D:\ptc\proe2001\templates\mmns_part_sheetmetal.prt
GMT+8, 2026-7-26 17:34 , Processed in 0.049489 second(s), 11 queries , Gzip On, Redis On.
