查看: 16700|回复: 0
求教:关于UF_GDT_create_instanse
发表于 2005-10-26 22:25:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我的程序如下:为什么不能正确执行函数:
        int res,response,count,num_fcfs;
        int type,subtype;
        double origin[3],point[3];
        char mes[133];
        char datum_name[30] = "Feature1";
        tag_p_t face;
        tag_t feature_instance = NULL_TAG;
        tag_t view,edge;
        tag_t object,view_tag;
        tag_t tolerance_feature;
        my_motion_data_t my_data;
        UF_GDT_datum_identifier_p_t pdatum_data;
        UF_GDT_feature_parms_p_t feat_parms;
        UF_GDT_feature_parms_t feature_parms;
        UF_GDT_geometric_definition_t def;
        UF_GDT_datum_assoc_type_t assoc_type;
        UF_GDT_description_t descript;
        UF_GDT_modifier_data_t modifier_data;
        UF_GDT_surface_parms_t sets;
        UF_GDT_surface_parms_p_t psets;
        UF_GDT_tolerance_type_t tolerance_type = UF_GDT_DATUM_IDENTIFIER_TYPE;
        UF_GDT_annotation_tags_t instance_para_tag;
        UF_GDT_set_instance_display_information(1);
        //初始化数据结构
        res = UF_GDT_init(UF_GDT_FEAT_PARMS_TYPE,(void *)(&feature_parms));
        if(res)
                UF_get_fail_message(res,mes);
                uc1601(mes,1);
        res = UF_GDT_init(UF_GDT_MOD_DATA_TYPE,(void *)(&modifier_data));
        if(res)
                uc1601(mes,1);
        res = UF_GDT_init(UF_GDT_DESCRIPT_TYPE,(void *)(&descript));
        if(res)
                uc1601(mes,1);
        res = UF_GDT_init(UF_GDT_SURFACE_PARMS_TYPE,(void *)(&sets));
        if(res)
                uc1601(mes,1);
/////////////////////////////////////创建基准/////////////////////////////////
        UF_UI_set_cursor_view(0);
        //选择基准放置面
        res = UF_UI_select_with_class_dialog("选择基准放置面",
                "选择基准放置面",UF_UI_SEL_SCOPE_WORK_PART_AND_OCC,
                init_proc,NULL,&response, &count, &face);
        if(res)
        if(response != UF_UI_OK)
                return 0;
        UF_DISP_set_highlight(face[0],0);
        sets.num_faces = 1;
        sets.faces = face;
        psets = &sets;
        descript.name = "Feature ggl";
        descript.description = "";
        feature_parms.num_faces = 1;
        feature_parms.face_list = face;
        feature_parms.descript = &descript;
        feature_parms.feature = UF_GDT_PLANE_FEATURE ;
        feature_parms.pattern = UF_GDT_NO_PATTERN;
        modifier_data.num_modifiers = 0;
        modifier_data.num_keywords = 0;
        feature_parms.modifier_data= &modifier_data;
        feature_parms.num_sets = 1;
        feature_parms.sets = &psets;
        feature_parms.num_modl_sets = 0;
        def.type = UF_GDT_ALL_GEOMETRY;
        feature_parms.def.type = UF_GDT_ALL_GEOMETRY;
        UF_GDT_datum_identifier_t datum_data;
        datum_data.datum_label = "GG";
        datum_data.is_individual = FALSE;
        tag_t datum_feature = NULL_TAG;
        res = UF_GDT_create_datum_identifier(&feature_parms,&datum_data,&datum_feature);
        if(res)
        res = UF_UI_select_with_single_dialog("请选择","点",
                   UF_UI_SEL_SCOPE_WORK_PART_AND_OCC, init_proc_edge, NULL,
                   &response, &object, point, &view);
        if(res)
        double point_drawing[3],origin_drawing[3],temp_point[3];//存放对应成员视图中的点的工程图的坐标
        double p2[3];
        tag_t work_view;
        char view_name[30];
        UF_VIEW_ask_work_view(&work_view);
        UF_OBJ_ask_name(work_view,view_name);
        UF_OBJ_ask_type_and_subtype(object,&type,&subtype);
        if(type == UF_solid_type && subtype == UF_solid_edge_subtype)
                UF_MODL_ask_edge_verts(object,point,p2,&count);
        point[1] = (point[1] + p2[1])/2;
        double reference_pt[3];
        res = UF_VIEW_map_model_to_drawing(view,point,point);
        if(res)
        UF_DRAW_ask_drawing_ref_pt(view,reference_pt);
        UF_UI_specify_screen_position("Indicate the site of the tolerance feature",
            NULL,NULL,origin,&view_tag,&response);
        if (response != UF_UI_PICK_RESPONSE)
                return 0;
        if(view_tag != work_view)
                UF_DRAW_ask_drawing_ref_pt(view_tag,reference_pt);
                origin[0] += reference_pt[0];
                origin[1] += reference_pt[1];
                origin[2] = 0;
        UF_UI_set_cursor_view(1);
        origin[1] = point[1];
        //将两个点的坐标转成work_view的坐标。
        logical is_gdt_view;
        UF_GDT_is_gdt_view(work_view,&is_gdt_view);
        res = UF_GDT_create_instance(UF_GDT_DATUM_IDENTIFIER_TYPE,datum_feature,work_view,
                object,origin,point,&feature_instance);
        if(res)
                uc1601(mes,0);
        return 1;
GMT+8, 2026-6-12 20:15 , Processed in 0.042003 second(s), 11 queries , Gzip On, Redis On.
