查看: 18643|回复: 1
求助各位一个 CAA中use case的编译问题!
发表于 2005-11-21 10:34:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我做的是CAA V5 Encyclopedia
中Part Design中的一个use case,名为Creating and Modifying a Mechanical Design Feature,
百科全书中说用到的是CAAPartInterfaces.edu中的CAAPriCreateModify.m,我在open project后选的是
CAAPriCreateModify.m,其他的还有很多.m都没有选
mkmk没有什么问题,可是Create and Update runtime view时却出现下面的错误,
## start step: DataUpdate   at 11/21/2005-10:07:22
## end   step: DataUpdate   at 11/21/2005-10:07:23
# mkmk-ERROR: In framework CAAPartInterfaces.edu module CAAPriPrtCfgAddin.m has no module.data associated.
# mkmk-ERROR: In framework CAAPartInterfaces.edu module CAAPriPatternMain.m has no module.data associated.
# mkmk-ERROR: In framework CAAPartInterfaces.edu module CAAPriPattern.m has no module.data associated.
# mkmk-ERROR: In framework CAAPartInterfaces.edu module CAAPriCutCopyPasteMain.m has no module.data associated.
# mkmk-ERROR: In framework CAAPartInterfaces.edu module CAAPriCutCopyPaste.m has no module.data associated.
# mkmk-ERROR: In framework CAAPartInterfaces.edu module CAAPriCommands.m has no module.data associated.
# mkmk-ERROR: In framework CAAPartInterfaces.edu module CAAPriBuildUserPadMain.m has no module.data associated.
# mkmk-ERROR: In framework CAAPartInterfaces.edu module CAAPriBuildUserPad.m has no module.data associated.
# mkmk-ERROR: Unable to load one or more module.data for framework [CAAPartInterfaces.edu].
== Command done, return code = 0
我以为是open project时选少了,就重新做了一遍,把 CAAPartInterfaces.edu 下的所有.m文件都加载进来了,可是编译的时候还有错,为什么啊?应该是怎么编译执行这个use case呢?
发表于 2005-11-21 10:56:24 | 只看该作者
GMT+8, 2026-8-12 18:29 , Processed in 0.049789 second(s), 11 queries , Gzip On, Redis On.
