查看: 23101|回复: 22
【资料】pro/e二次开发
发表于 2003-1-19 13:04:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这个版太好了,以前没发现一大损失,
不知大家都怎么开发,从国外网站下载了一个文件protk_wiz,希望对大家有用
for
Visual C++6[$reg] and Pro/TOOLKIT[$reg]
General
Pro/ENGINEER[$reg] provides an API called Pro/TOOLKIT[$reg] that can be used to significantly customize your Pro/E installation. You must have a license for Pro/TOOLKIT[$reg] and the libraries and headers must be installed for the custom app wizard to help you. You must also ensure that Visual C++ can find the libraries and headers.
Download and Install
  Download A_ProTKGen.awx from this location.
  Copy the file to your ....\MSVisualStudio\Common\MSDev98\Template directory or refer to documentation if your installation is different.
Use the wizard
  From Visual C++[$reg], use the File -> New menu. Pick the Projects dialog tab as shown.
  Select the A_ProTK AppWizard option from the list. This will be displayed only if you have stored the A_ProTKGen.awx file in the proper location.
  Enter the information required and you will have a skeleton Pro/TOOLKIT DLL application complete with registry and menu files.
发表于 2003-1-19 13:09:06 | 只看该作者
发表于 2003-3-1 15:55:42 | 只看该作者
发表于 2003-3-14 16:03:08 | 只看该作者
发表于 2003-3-14 16:18:09 | 只看该作者
发表于 2003-3-18 09:38:43 | 只看该作者
发表于 2003-3-22 11:31:37 | 只看该作者
发表于 2003-3-22 11:52:00 | 只看该作者
发表于 2003-3-22 16:05:59 | 只看该作者
发表于 2003-3-27 19:48:13 | 只看该作者
GMT+8, 2026-8-3 08:58 , Processed in 0.065516 second(s), 12 queries , Gzip On, Redis On.
