查看: 15675|回复: 2
For ug-master--How to offset surfaces in one shot
发表于 2005-12-28 22:58:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Sorry I am in canada, I can not type chinese on my computer
I am doing blow-mold design now, the layflat surfgaces are offfset surfaces,
My question is
1. how to offset over 10 surfaces with different normals in one shot and is still sewable
2. is there any way we can quilt all surface into one piece, I tried quilt many times, but either say"can not project on surface" or "the new 1-piece surface must be smaller than original
Hope any advanced user will answer my question
tHANKS A LOT
发表于 2005-12-29 20:09:50 | 只看该作者
In Ugnx 4.0, you can select all the surfaces in one time.
In Ugnx 3.0, there are some ways to do this.
Method 1: Sew all the single surfaces, and then try to use “thicken sheet” or “sheets to solid assistant” to create a solid from the sewed surface. After that, you can extract all the surfaces you want.
Method 2: use “quilt” to make all the surfaces to a single surface, but be careful with the tolerance. As for the “quilt” command, maybe you can get some ideas from the following topics:
A.
https://www.icax.net/viewthread.php?tid=206414&extra=page%3D3
B.
https://www.icax.net/viewthread.php?tid=224377&extra=page%3D1
发表于 2005-12-29 20:36:51 | 只看该作者
It is very good!
THANKS A LOT !!!!!!
GMT+8, 2026-6-23 22:45 , Processed in 0.051717 second(s), 11 queries , Gzip On, Redis On.
