查看: 16584|回复: 1
求解:在adams/view中建的轮胎模型的警告提示
发表于 2006-1-12 22:51:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位大侠,我在adams/view中建立了一个轮胎道路模型(UA)在运行时总是出现这种警告,请指教这是怎么回事,给个解决的提示。    我是菜鸟
谢谢!
WARNING:    For TIRE zhengche.TIRE_4 the absolute value of the longitudinal slip ratio
   has gone beyond its maximum allowable limit of 1.0.
   Longitudinal slip ratio = 2.1027.
   If the longitudinal slip ratio is positive, it will be set
   to 1.0 (braking).  If the longitudinal slip ratio is
   negative, it will be set to -1.0 (traction).
WARNING:    An anomalous situation has been detected for TIRE zhengche.TIRE_1.
   The moment arm for normal force (Fz) that causes the
   rolling resistance moment (Ty) is greater than the allowable
   maximum of 1/2 the length of the contact patch.
   CRR = 6.250
   CRR_max = 1.23886E-05
WARNING:    Note regarding TIRE zhengche.TIRE_2.
   Its Road Data File (E:/work/adams documents/zhengchemoxing/275r22.5_flat.rdf) is the same as the one for TIRE zhengche.TIRE_1,
   and you have the RGRA argument on both TIRE statements.
   ADAMS/Solver will generate redundant road graphics which
   may slow graphics and animation in particular.
   Include the RGRA argument on only one of these TIRE statements.
发表于 2006-1-13 13:56:44 | 只看该作者
GMT+8, 2026-8-2 18:44 , Processed in 0.043732 second(s), 13 queries , Gzip On, Redis On.
