查看: 17691|回复: 3
帮忙看看下面程序中feature_disp_props.layer返回值为什么不正确?谢谢!
发表于 2006-2-13 20:52:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
char part_fspec[MAX_FSPEC_SIZE+1]="";
        char title[] = "\nPart %s\n";
        int curr_part,num_parts;
        int feature_type,solid_type;
        int count_l;
        int count_feature[100];
        int count_solid[100];
    tag_t obj_p;
//        tag_t obj_f[10];
        tag_t feature;
        tag_t feature_save[100];
        tag_t solid_save[100];
        char num_of_part_c[100];
        char num_of_curr_part_c[100];
        char num_of_curr_feature_c[100];
        char layer_of_curr_obj_c[100];
//        char num_of_exps_c[100];
        UF_OBJ_disp_props_t feature_disp_props;
    UF_OBJ_disp_props_t solid_disp_props;
        tag_t *exps;
        int number_of_exps=0,i,j;//与当前特征有关的表达式数量
        //获取当前会话中part的数量
        num_parts = UF_PART_ask_num_parts();
        sprintf(num_of_part_c,"PART文件数量 %d\n",num_parts);
    UF_UI_open_listing_window();
        UF_UI_write_listing_window(num_of_part_c);
        for (curr_part=0;curr_part < num_parts;curr_part++)
                //获取当前会话中当前部件的标识
        obj_p = UF_PART_ask_nth_part(curr_part);
                //获得当前部件的名称
                UF_PART_ask_part_name(obj_p,part_fspec);
                sprintf(num_of_curr_part_c,"PART顺序号:%d\nPART名称为:%s\n",curr_part,part_fspec);
                UF_UI_write_listing_window(num_of_curr_part_c);
                count_l = 0;
                feature_type = UF_feature_type;
                feature = NULL_TAG;
                //开始遍历当前部件中的特征/对象。遍历过程的起点是NULL_TAG
                feature_save[0] = feature;
                //遍历终点是NULL_TAG
                do
                        count_l++;
                        UF_OBJ_cycle_objs_in_part(obj_p,feature_type,&feature);
                        solid_save[count_l] = feature;
                        //查询对象属性
                    int result = UF_OBJ_ask_display_properties(feature,&feature_disp_props);
                        if(result) UF_UI_write_listing_window("fail");
                    sprintf(layer_of_curr_obj_c,"特征所在层:%d\n",feature_disp_props.layer);
            UF_UI_write_listing_window(layer_of_curr_obj_c);
                }while (feature != NULL_TAG);
                count_feature[curr_part] = count_l;
                sprintf(num_of_curr_feature_c,"特征数量:%d\n",count_l);
                UF_UI_write_listing_window(num_of_curr_feature_c);
发表于 2006-2-14 21:55:13 | 只看该作者
发表于 2006-2-15 09:42:17 | 只看该作者
发表于 2006-2-15 20:32:06 | 只看该作者
GMT+8, 2026-8-3 18:43 , Processed in 0.057079 second(s), 11 queries , Gzip On, Redis On.
