查看: 19533|回复: 10
有关CATIA二次开发的一个问题,请大家指教
发表于 2006-3-8 15:22:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
以下是一个小程序,最后两段就是问题啦,蛮奇怪的,有高手指教吗?
Option Explicit
' COPYRIGHT DASSAULT SYSTEMES 2000
'   Purpose:       Create A Product Structure document containing
'                        an external component.
'   Assumtions:   Opens CAAPstHull.CATPart in the CATDocView
'   Author:
'   Languages:   VBScript
'   Locales:        English
'   CATIA Level:  V5R6
Sub CATMain()
    ' Optional: allows to find the sample wherever it's installed
     Dim sDocPath As String
     sDocPath = CATIA.SystemService.Environ("CATDocView")
     If (Not CATIA.FileSystem.FolderExists(sDocPath)) Then
       Err.Raise 9999, , "No Doc Path Defined"
     End If
    'Create a new product document object by adding a document with the Product
    'type to the document collection of the CATIA application.
    Dim oProductDoc As Document
    Set oProductDoc = CATIA.Documents.Add("roduct")
    'Retrieve the root product.
    Dim oRoot As Product
    Set oRoot = oProductDoc.Product
    'Retrieve the root product collection of products.
    Dim oRootCol As Products
    Set oRootCol = oRoot.Products
    'Open the Part Document
    Dim oPartDoc As Document
    Set oPartDoc = CATIA.Documents.Read("D:\图\1\1\Jin41200.CATProduct")
    'Add a new component from the already opened part document.
    Dim oNewComponent As Product
    Set oNewComponent = oRootCol.AddExternalComponent(oPartDoc)
    Dim rProduct As Product
    Set rProduct = oNewComponent.Products.Item(1).ReferenceProduct
    Dim MyProduct As Product
    Set MyProduct = oRootCol.AddNewComponent("roduct", "111")
'-----------------------下面两段改名字没反应,改不动,我试过树型里第一层以下的名称都改不动---------------------------------
    Dim MyNewProduct As Product
    Set MyNewProduct = oNewComponent.Products.AddComponent(rProduct)
    MyNewProduct.Name = "444"
    Set MyNewProduct = MyProduct.Products.AddNewProduct("222")
    MyNewProduct.Name = "333"
End Sub
发表于 2006-3-8 15:48:16 | 只看该作者
发表于 2006-3-8 15:54:57 | 只看该作者
发表于 2006-3-8 16:59:51 | 只看该作者
发表于 2006-3-8 17:04:33 | 只看该作者
发表于 2006-3-8 17:04:57 | 只看该作者
发表于 2006-3-9 11:28:13 | 只看该作者
发表于 2006-3-9 11:32:46 | 只看该作者
发表于 2006-3-9 18:23:17 | 只看该作者
发表于 2006-3-10 14:05:57 | 只看该作者
GMT+8, 2026-8-12 21:33 , Processed in 0.077182 second(s), 13 queries , Gzip On, Redis On.
