查看: 19842|回复: 1
有关ug克隆装配的问题
发表于 2006-3-19 10:45:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
在克隆装配时如何对克隆的part进行命名?
在uf_clone里面有一个UF_CLONE_set_def_naming (UF_CLONE_naming_technique_t naming_technique );函数,
不知道具体怎么使用阿
为什么将naming_technique 设为UF_CLONE_autogen,总是会出现命名错误的提示?
望大家指教!
以下是部分代码
int Apply_defaultclone()
        UF_CLONE_operation_class_t operation_class ;
        UF_CLONE_action_t action ;
        UF_PART_load_status_t load_status ;
        UF_CLONE_naming_technique_t naming_technique ;
        UF_CLONE_naming_failures_t naming_failures ;
         UF_CLONE_name_rule_def_t name_rule;
        char directory_name[133] = "E:\\";
        char part_name[133] = "E:\\sld.prt";
        action = UF_CLONE_clone ;
        naming_technique = UF_CLONE_autotranslate ;
        operation_class = UF_CLONE_clone_operation ;
        UF_CLONE_initialise ( operation_class );
        UF_CLONE_init_naming_failures (& naming_failures );
        UF_CLONE_set_def_action ( action );
        UF_CLONE_set_def_naming ( naming_technique );
        UF_CLONE_set_def_directory ( directory_name );
        UF_CALL(UF_CLONE_add_assembly ( part_name, & load_status ));
                 UF_free_string_array(load_status.n_parts,load_status.file_names);
                 UF_free(load_status.statuses);
name_rule.type = UF_CLONE_prepend_string ;
name_rule.new_string = "a";
UF_CLONE_set_name_rule (& name_rule, & naming_failures );
                if(naming_failures.n_failures >0)
UF_free_string_array(naming_failures.n_failures,naming_failures.input_names);
UF_free_string_array(naming_failures.n_failures,naming_failures.output_names);
UF_free(naming_failures.statuses);
UF_CALL(UF_CLONE_apply_defaults (& naming_failures ));
        UF_CLONE_terminate ( );
        return 0;
发表于 2006-3-30 10:50:13 | 只看该作者
UF_CLONE_set_name_rule 设定命名规则,具体使用可以参考api手册
GMT+8, 2026-4-28 22:04 , Processed in 0.076104 second(s), 11 queries , Gzip On, Redis On.
