查看: 16180|回复: 4
NX4的郁闷
发表于 2006-3-22 11:15:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
郁闷,NX4还不支持64位啊!?
      NX                                                VERSION 4.0 Release
      Windows 2000/XP (32 Bit)                                Issued: Dec 2005
      Files on this media are intended for use on the Windows 2000 or Windows XP
      (32 Bit) platform only, they are NOT supported on Windows NT4.
      _______________________________________________________________________
      INSTALLATIONS:
      To install the products on this media, run the 'launch' program at
      the top level, or change directory to the product directory and
      run the setup program contained within that directory.
      DOCUMENTATION:
      The 'docs' folder contains Installation documents and other related
      documents, which may be viewed or printed with your browser.
      Further information is contained in the README file located in
      the "docs" folder.
      NOTE:  Viewing Documentation directly from the media Launcher will
             require that the Adobe Acrobat plug-in is installed on your
             system.  No errors are given if the plug-in is not available.
             Download the plug-in from:  https://www.adobe.com/acrobat
      RELEASE INFORMATION:
      The What's New Guide and the Release Notes are contained in the
      REL_INFO kit in the nx040 folder.  This will be installed by
      default with the Typical installation option.  If you use the Custom
      installation option, it is recommended that you select the
      'REL_INFO' kit.
      Once installed, both documents can be viewed from the start menu:
      Start -> Programs -> UGS NX 4.0 -> Release Information ->
            *Whats New
            *Release Notes
      A copy of the Release Letter is also provided in the "docs" folder.
      This is viewable with your Web Browser.
      Begin browsing with the following initial file:
          docs\release_notes\index.htm
      Further information is contained in the docs\README file.
发表于 2006-3-22 11:18:04 | 只看该作者
但DOC已支持64位了!
    NX ON LINE DOCUMENTATION                        VERSION 4.0
    Windows 2000/XP                                Issued: Dec 2005
    Files on this media are for use on the Windows 2000/XP platform only.
    There are two installations folders contained on this media, win32 and win64.
    On Windows 2000 or 32 bit Windows XP systems use the installation kit in
    win32\ugdoc040.  On the media launcher select: "Install on Windows 2000/XP".
    On Windows XP x64 systems use the installation kit in win64\ugdoc040.
    On the media launcher select: "Install on Windows XP x64".
    __________________________________________________________________________
    INSTALLATION PREREQUISITES:
    Due to the very large number of files in this kit, a minimum revision of
    Microsoft Installer is required to run this install.
    The required msiexec.exe is found in the following OS levels:
        Windows XP   Service Pack 1
        Windows 2000 Service Pack
    The install will NOT run on anything less, and the "setup.exe" will check
    for these minimum revision levels.
    INSTALLATION:
    The installation program for Unigraphics Online Documentation (UGDOC) is
    contained in the "ugdocXXX" directory. Where XXX is the release number.
    To install UGDOC, simply change directory to "ugdocXXX" then run
    the setup.exe program.
    NOTE:  Documentation must be installed in the NX 4 %UGII_BASE_DIR% in
           order to be accessible from within NX 4.0.  It is recommended
           to accept the install destination default.
    After the installation, the "NX 4.0 Documentation" shortcut
    will appear in the "UGS NX 4.0" folder on the "start" menu.
    e.g:
    Start -> Programs -> UGS NX 4.0 -> NX 4.0 Documentation.
    Note: The "docs" folder contains a "ugdoc.pdf" file with brief instructions
    on installing UGDOC.  This document is in Portable Document Format and may
    be viewed or printed with your IE browser.  The browser must have the
    Adobe Acrobat plug-in installed. You may download the plug-in
    Additional Information:
    For further information and tips on the HTML Help documents, please refer
    to UGDOC_README.txt file.
发表于 2006-3-22 11:19:02 | 只看该作者
有64位版本的
发表于 2006-3-22 11:36:28 | 只看该作者
原帖由 darkbit 于 2006-3-22 11:19 发表
有64位版本的
还没见过啊现在要装机,不知要选32或64软件还没找着.
发表于 2006-3-22 17:00:06 | 只看该作者
找一个UGSNX.V4.0.0.25补丁子就可以了,我就在64系统里作业呀。快到不得了。
GMT+8, 2026-6-19 03:02 , Processed in 0.057150 second(s), 11 queries , Gzip On, Redis On.
