查看: 33864|回复: 57
【推荐】pro/e2001隐藏系统参数探密!
发表于 2003-2-15 18:19:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
pro/e2001中有很多隐藏的系统参数!
通过设定这些参数可以使PRO/E的功能增强,本人也一直在中,
下面是全部的PRO/E系统参数,大家一起来摸索:
发表于 2003-2-15 18:19:56 | 只看该作者
All config.pro options for 2001
18_PLUS (hidden)
19_PROJ_ANGLE (hidden)
19_PROJ_BOUNDARY (hidden)
19_PROJ_CHAMFER (hidden)
19_PROJ_CSYS (hidden)
19_PROJ_DEPTH (hidden)
19_PROJ_DRAFT (hidden)
19_PROJ_DTMAXIS (hidden)
19_PROJ_DTMCRV1 (hidden)
19_PROJ_DTMCRV (hidden)
19_PROJ_DTMPLANE (hidden)
19_PROJ_DTMPNT (hidden)
19_PROJ_PATTERN (hidden)
19_PROJ_PROTRUSION (hidden)
19_PROJ_SHELL (hidden)
19_PROJ_SMT_CONVERSION (hidden)
19_PROJ_SMT_TWIST (hidden)
19_PROJ_SRFOFFS (hidden)
19_PROJ_SWEEP (hidden)
19_PROJ_SWEPT_BLEND (hidden)
19_PROJ_THREAD (hidden)
19_PROJ_USEQLT (hidden)
21_PROJ_ANL (hidden)
22_PRJ_HOLE_THRD_CORR (hidden)
2BUTTON_MOUSE_MMB_SUPPORT
2_5_LOCAL_MILL (hidden)
3D_THICKNESS_CHECK (hidden)
5_AXES_REMAINDER_SURFACE (hidden)
5_AXIS_SIDE_MILL (hidden)
发表于 2003-2-15 18:23:32 | 只看该作者
ACAD_EXPORT_LAYERS_WITH_ID (hidden)
ACIS_OUT_VERSION (hidden)
ADD_TO_LAYER_BY_COMP_NAME (hidden)
ADJUST_EXPORT_ACCURACY (hidden)
ADVANCE_COMP_PLACEMENT_UI (hidden)
ADV_ST_FEAT_CONF (hidden)
ALLOW_4DNAV_EXPORT (hidden)
ALLOW_ANY_DGM_SYM_MODEL_NAME (hidden)
ALLOW_CONFIRM_WINDOW
ALLOW_COPY_WITH_EXT_REFS (hidden)
ALLOW_CREATE_PDM_PARAM (hidden)
ALLOW_FLOAT_OPT_CHECKOUT
ALLOW_GEOM_REP_REF (hidden)
ALLOW_HARN_MFG_ASSY_RETRIEVAL (hidden)
ALLOW_INTERSECT_SPEC_REP (hidden)
ALLOW_LAYER_IN_SYMBOL_EDITOR (hidden)
ALLOW_LOCAL_FLAT_PREV_TOOL (hidden)
ALLOW_MAPKEY_TRAIL_OUTPUT (hidden)
ALLOW_MEDUSA_DRAW_IMPORT (hidden)
ALLOW_NSIDED_ROUND (hidden)
ALLOW_OLD_STYLE_ALIGN (hidden)
ALLOW_PNT_ON_PIPES (hidden)
ALLOW_RCS_FORMAT_EXPORT (hidden)
ALLOW_RIVETING (hidden)
ALLOW_RMV_UNATT_INTERSECTIONS (hidden)
ALLOW_ROUND_ALL (hidden)
ALLOW_SAVE_AS_INSTANCE
ALLOW_SKIRT_EXT_SURF (hidden)
ALLOW_SMALL_CHORD_HEIGHT (hidden)
ALLOW_SMM_ASSY_RETR (hidden)
ALLOW_SOLID_SPLIT (hidden)
ALLOW_VISUALIZER_EXPORT (hidden)
ALLOW_WIRE_ATTACH_TO_SYMBOLS (hidden)
ALWAYS_DO_FIRST_SLICE (hidden)
ALWAYS_FREEZE_MIS_SIMPREP (hidden)
ALWAYS_USE_BOTTOM_STOCK (hidden)
ANALYSIS_OUTPUT_TO_DISK (hidden)
ARC_RADIUS_LIMIT (hidden)
ASSEMBLY_LODS (hidden)
ATB_IDENT_CADDS_FILES (hidden)
ATTACH_MENUMANAGER
AUTODRILL_REORDER (hidden)
AUTODRILL_REPLACE_REMOVED_UDF (hidden)
AUTOFIX_INTF_ROUNDS (hidden)
AUTOROUTE_PATH_PARAM_NAME
AUTO_BODY_FEATURES (hidden)
AUTO_CONSTR_ALWAYS_USE_OFFSET
AUTO_CONSTR_OFFSET_TOLERANCE
AUTO_CUSTOMIZE (hidden)
AUTO_DES_ILINK_FILEBASED_ATTRS (hidden)
AUTO_GET_FLOAT_MODULES (hidden)
AUTO_XML_ON_RETRIEVE
AUTO_XML_ON_SAVE
AVOID_PPFM_MS_SHEETS (hidden)
AXIS_DEF_ALONGCUTLINE (hidden)
AXIS_DISPLAY (hidden)
BENCHMARK_MODE (hidden)
BLANK_INT_CATIA_FACET_EDGES (hidden)
BM_GRAPH_TOOL
BNDRY_BLEND_GHOST2DIR (hidden)
BNDRY_BLEND_TANG_FLD (hidden)
BULKHEAD_STOOL_GAP
CADDS_EXPORT_EXACT_ENTITIES (hidden)
CADDS_IMPORT_HUGHES_NAMING (hidden)
CADDS_MTLAYER_EXPORT (hidden)
CAT_CL_MODE (hidden)
CHECK_RESOURCE_FILES (hidden)
CHECK_SAME_ASSY_PARTS
CLEANUP_DRAWING_DEPENDENCIES (hidden)
CLEANUP_LAYOUT_DEPENDENCIES (hidden)
CLEARANCE_TRIANGULATION
CLEAR_MECHANICA_ATTRIBUTE (hidden)
CL_ROTATE_SIGN_CONVENTION
CMDMGR_TRAIL_OUTPUT (hidden)
COLOR_PS_RAMP_SIZE (hidden)
COMPLETE_COPY_GEOM_UPDATE (hidden)
COMP_GEN_WITH_INST_FAIL_ACT (hidden)
COMP_INSTANCE_FAIL_ACT (hidden)
COMP_OFFSET_DEC_PLACES (hidden)
COMP_PLACE_W_TABLES (hidden)
COMP_SNAP_DIST_TOLERANCE
COPYGEOM_22 (hidden)
COPY_DXF_DIM_PICT
COPY_GEOM_UPDATE_PRE_2000I_DEP
CORN_ROUND_TRIM_OPT (hidden)
CPUS_TO_USE
CRASH_AT_COMMAND (hidden)
CREATE_DRAWING_DIMS_ONLY
CREATE_FRACTION_DIM
CREATE_NUMBERED_LAYERS
CSYS_COPY_GEOM_PLACE (hidden)
CUBIC_CHECK_SRF_INTERSECTION (hidden)
CURR_PROC_COMP_DEF_COLOR
CURR_PROC_COMP_DEF_FONT
CURVE_CREATION_FROM_ANALYSIS (hidden)
CURVE_TAG_DISPLAY
CUSTOMIZE_AUTOCUT (hidden)
CUSTOM_LOCALE_DEFAULT_FONT_CS0 (hidden)
CUSTOM_LOCALE_DEFAULT_FONT_CS1 (hidden)
CUSTOM_LOCALE_DEFAULT_FONT_CS2 (hidden)
CUSTOM_LOCALE_DEFAULT_FONT_CS3 (hidden)
CUSTOM_LOCALE_MENU_FONT_CS0 (hidden)
CUSTOM_LOCALE_MENU_FONT_CS1 (hidden)
CUSTOM_LOCALE_MENU_FONT_CS2 (hidden)
CUSTOM_LOCALE_MENU_FONT_CS3 (hidden)
CUSTOM_LOCALE_STROKE_FONT_DIR (hidden)
CUSTOM_LOCALE_TITLE_FONT_CS0 (hidden)
CUSTOM_LOCALE_TITLE_FONT_CS1 (hidden)
CUSTOM_LOCALE_TITLE_FONT_CS2 (hidden)
CUSTOM_LOCALE_TITLE_FONT_CS3 (hidden)
CUSTOM_RAINBOW
CUTCOM_ON_SPIRAL (hidden)
CUTCOM_UTILS (hidden)
CUTLINE_FROM_MACH_AREA (hidden)
CUTLINE_SURF_ADJ (hidden)
DATUM_DISPLAY (hidden)
DATUM_POINT_DISPLAY (hidden)
DATUM_POINT_SYMBOL
DATUM_POINT_TAG_DISPLAY (hidden)
DAZIX_DEFAULT_PLACEMENT_UNIT
DAZIX_EXPORT_MOUNTHOLE
DAZIX_NEUTRAL_FILE_V1_3 (hidden)
DAZIX_Z_TRANSLATION
DBMS_SAVE_CHANGED (hidden)
DECORRUPT_DIMENSIONS (hidden)
DEFAULT_ABS_ACCURACY
DEFAULT_ALL_MILL_SRF (hidden)
DEFAULT_ANG_DEC_PLACES
DEFAULT_DEC_PLACES
DEFAULT_DIM_NUM_DIGITS_CHANGES
DEFAULT_DRAW_SCALE
DEFAULT_EXT_REF_SCOPE
DEFAULT_FONT
DEFAULT_GEOM_SCOPE
DEFAULT_MOLD_BASE_VENDOR
DEFAULT_OBJECT_INVALID_REFS
DEFAULT_OBJECT_SCOPE_SETTING
DEFAULT_PLACEMENT_SCOPE (hidden)
DEFAULT_RAMP_SIZE
DEFAULT_SHIP_BREADTH
DEFAULT_SHIP_LBP
DEF_LAYER
DELETE_AFTER_PLOTTING
DEL_GP_MEMB_IND
DEL_NOTE_SYM_WITH_BAD_VIEW (hidden)
DEPTHCUE_ALWAYS
DEPTHCUE_VALUE
DIAGRAM_PIN_EDIT_MULTI_LINE
DIALOG_TRANSLATION
DIM_FRACTION_DENOMINATOR
DIM_FRACTION_FORMAT
DIM_OFFSCREEN_LIMIT
DIRECT_VRML (hidden)
DIR_CACHE_MAX
DISABLE_COINC_REL_CHECK (hidden)
DISABLE_PROG_REPLS_ON_RETR (hidden)
DISABLE_SEARCH_PATH_CHECK (hidden)
DISPLAY
DISPLAY_AXES
DISPLAY_AXIS_TAGS
DISPLAY_COAXIAL_AXES (hidden)
DISPLAY_COMPS_TO_ASSEMBLE
DISPLAY_COORDINATE_SYS (hidden)
DISPLAY_COORD_SYS
DISPLAY_COORD_SYS_TAGS
DISPLAY_DWG_TOL_TAGS
DISPLAY_FULL_OBJECT_PATH
DISPLAY_INTERNAL_CABLE_PORTION
DISPLAY_IN_ADDING_VIEW
DISPLAY_LAYER
DISPLAY_PLANES
DISPLAY_PLANE_TAGS
DISPLAY_POINTS
DISPLAY_POINT_TAGS
DISPLAY_SILHOUETTE_EDGES
DISPLAY_THICK_CABLES
DISP_TRIMETRIC_DWG_MODE_VIEW
DONT_SHOW_SYMBOL_NODES
DRAFT_STD (hidden)
DRAWING_FILE_EDITOR
DRAWING_SETUP_FILE
DRAWING_VIEW_ORIGIN_CSYS
DRAW_DYNAMIC_MOVE (hidden)
DRAW_LAYER_FIX_ON_RETR (hidden)
DRAW_MODELS_READ_ONLY
DRAW_POINTS_IN_MODEL_UNITS
DRILL_PARAMS_FILE (hidden)
DRV_SRF_AXDEF_OPT (hidden)
DWG_EXPORT_FORMAT
DWG_OO_180 (hidden)
DWG_SELECT_ACROSS_PICK_BOX
DXFIO_IN_SJIS
DXF_EXPORT_EXTRACT (hidden)
DXF_EXPORT_FORMAT
DXF_EXPORT_MAPPING_FILE
DXF_OUT_COMMENTS (hidden)
DXF_OUT_DRAWING_SCALE
DXF_OUT_SCALE_VIEWS
DXF_OUT_SEP_DIM_W_BREAKS
DXF_OUT_STROKE_TEXT
DYNAMIC_HIGHLIGHTS (hidden)
DYNAMIC_SURF_DIALOG (hidden)
ECAD_AREA_DEFAULT_IMPORT
ECAD_BOARD_CSYS_DEF_NAME
ECAD_COMP_CSYS_DEF_NAME
ECAD_COMP_LAYER_MAP
ECAD_CREATE_HINT_ADD
ECAD_DEFAULT_COMP_HEIGHT
ECAD_DEFAULT_COMP_PLACE_STATUS (hidden)
ECAD_EXPORT_HOLES_AS_CUTS
ECAD_EXP_BOTH_TWO_AREAS
ECAD_IMPORT_HOLES_AS_FEATURES
ECAD_MAPPING_FILE
ECAD_OTHER_OUTL_CSYS_DEF_NAME
ECAD_PANEL_CSYS_DEF_NAME
ECO_FORMAT (hidden)
EDGE_DISPLAY_QUALITY
EDGE_ED_DOMAIN (hidden)
EDIT_BNDRY_DEL_CONF (hidden)
ENABLE_ABSOLUTE_ACCURACY
ENABLE_ACIS_INTERFACE (hidden)
ENABLE_ASSEMBLY_ACCURACY
ENABLE_ASSY_REFS_TEST (hidden)
ENABLE_AUTO_CONSTR (hidden)
ENABLE_CADRA_EXPORT
ENABLE_COMPONENT_INTERFACES (hidden)
ENABLE_DESIGN_MGR_UI (hidden)
ENABLE_FIAT_EXPORT (hidden)
ENABLE_FREEFORM_MOVEMENT (hidden)
ENABLE_HLR_HASHING
ENABLE_MECH_CONN_UI (hidden)
ENABLE_POPUP_HELP
ENVIRONMENT (hidden)
ERV_GRAPH_DEBUG (hidden)
ERV_GRAPH_GET_SEL (hidden)
ERV_SHOW_EXTERNAL_ONLY
EXCEL_ANALYSIS_DIRECTORY
EXEC_INSTANCE_ALWAYS (hidden)
EXEC_PROG_ON_ASSEM_RETR
EXPAND_VERIFY_CYCLE (hidden)
EXPERT_TOOLMAKER_STRATEGY (hidden)
EXPERT_TOOLMAKER_VISIBLE (hidden)
EXPLODE_IGES_DIMENSION_NOTE
EXPORT_3D_FORCE_DEFAULT_NAMING
EXPORT_CDRS_FEAT_OPTS (hidden)
EXPORT_CSYS_TO_MEDUSA (hidden)
EXPORT_TO_SHIPIT
EXTEND_CVPATH
EXT_PARAM_OBJ_ALLOWED (hidden)
EXT_SRF_TYPES_FOR_MODIFICATION (hidden)
FACE_TURN_CUT_DIRECTION (hidden)
FAIL_EMPTY_DRILLING_SEQ (hidden)
FAIL_IF_SEC_REFS_MISSING (hidden)
FAIL_IF_SEC_REGEN_WARNING
FAIL_REF_COPY_WHEN_MISSING_ORIG
FAIL_UNATTACHED_FEATURE
FAMILY_TABLE_EDITOR
FAMILY_TABLE_UI_IN_ONE_DIALOG (hidden)
FAMTABUI_22 (hidden)
FANNING_TRAJECTORY (hidden)
FASTHLR
FEATURE_CREATE_AUTO_BEGIN
FEATURE_CREATE_AUTO_OK
FEMANSYS_ANNOTATIONS
FEM_ACCURACY_CONTROL (hidden)
FEM_ANSYS_ANNOTATIONS
FEM_ANSYS_GROUPING
FEM_ASP_RATIO
FEM_CHECK_ON_FMD_RETRIEVE (hidden)
FEM_DEFAULT_SOLVER
FEM_DIST_INDEX
FEM_EDGE_ANGLE
FEM_FEAS_CONVERTOR
FEM_GEOMETRY_CHECK (hidden)
FEM_GEOM_ASSOCIATIVITY
FEM_GLOB_MIN_FACTOR (hidden)
FEM_IGNORE_UNPAIRED
FEM_IGNORE_VOLUMES (hidden)
FEM_IMPROVEMENT_STEPS (hidden)
FEM_KEEP_SOLVER_FILES (hidden)
FEM_MAX_MEMORY_USAGE
FEM_MESH_OPERATIONS
FEM_MESH_PRESERVE
FEM_MID_RATIO
FEM_NEUTRAL_FORM (hidden)
FEM_NEUTRAL_VERSION
FEM_OLD_QUAD_MESHER
FEM_PARTIAL_SHELL_MESH (hidden)
FEM_REMOVE_UNOPPOSED
FEM_SHOW_OUTP_BAR_CSYS (hidden)
FEM_SKEW_ANGLE
FEM_SOLID_SHELL_AUTO_CONSTRAINT
FEM_SOLVER_TIME_LIMIT
FEM_SORT_ELEMENTS (hidden)
FEM_SORT_NODES (hidden)
FEM_SUPERTAB_VERSION
FEM_TAPER
FEM_TWIST_ANGLE
FEM_WARP_ANGLE
FEM_WHICH_ANSYS_SOLVER
FEM_Y_DIR_COMPRESS
FILE_OPEN_DEFAULT_FOLDER
FIT_OBJECT_IN_WINDOW
FIX_140_PROJ_BROKEN_VIEWS (hidden)
FIX_AUTOCAD_IGES_TEXT_SCALE
FIX_BOUNDARIES_ON_IMPORT
FIX_CADDS4X_SET_DWG_ENT_XFORM (hidden)
FIX_CADDS4X_SET_VIEW_ORIENT (hidden)
FIX_CADDS4X_SET_VIEW_SCALE (hidden)
FIX_CATIA_IGES_6004 (hidden)
FIX_CATIA_IGES_SYM_NOTE
FIX_CORRUPT_INT_DTMS (hidden)
FIX_DATUM_ARR_DIM_SIGN (hidden)
FIX_DUP_IDS_IN_CHAIN (hidden)
FIX_FIND_ALL_TANGENTS_DIMS (hidden)
FIX_FTCOPYCOMP_EXPLD (hidden)
FIX_IMPORTED_SET_VIEW_ORIENT
FIX_LAYER_DISPLAY_BUG (hidden)
FIX_REFS_TO_INTERSECTIONS
FIX_TOPL_DISPL_OPT (hidden)
FIX_TOPL_RGL_SPLIT (hidden)
FIX_TOPL_SPLIT (hidden)
FLIP_ARROW_SCALE
FLIP_ARROW_SHAPE (hidden)
FLYOUT_RESET_TIME (hidden)
FLYOUT_TIME (hidden)
FOLEY_SPLINE (hidden)
FOLLOW_BOTTOM_SURFACES (hidden)
FONTS_SIZE
FORCE_ASMCUT_REGEN_ON_RETRIEVAL (hidden)
FORCE_BASE_SIZE (hidden)
FORCE_NEW_FILE_OPTIONS_DIALOG
FORCE_WIREFRAME_IN_DRAWINGS
FORMAT_SETUP_FILE
FRAMES_PER_SEC
FRAMES_PER_SEC_VALUE
FRAME_NUMBER_INTERVAL
FREEFORM_TOOLPATH_MATREM
FREEZE_FAILED_ASSY_COMP
FREEZE_OLD_EMPTY_PART_SIZES (hidden)
FREEZE_SYMBOL_CHARACTERS (hidden)
FULL_HLR_FOR_CABLES
FWD_EXPL_TO_SUBST_ASM_MEMBS (hidden)
GCPY_NOTES (hidden)
GERBER_360_INTERPOLATION
GPOSTPP_DIR
GRAPHICS
GRID_SNAP
GROOVE_PARAMS_FILE (hidden)
GTOL_DIM_PLACEMENT
HARN_TANG_LINE_DISPLAY
HELP_TRANSLATION
HIDDEN_LINE_DISPLAY (hidden)
HIGHLIGHT_ERASED_DWG_VIEWS
HIGHLIGHT_NEW_DIMS
HLR_FOR_QUILTS
HOLE_DIAMETER_OVERRIDE
HOLE_PARAMETER_FILE_PATH
HULL_BRACKET_PREFIX
HULL_BRACKET_SECTION_FILE
HULL_COLLAR_PLACEMENT
HULL_COLLAR_PREFIX
HULL_COLLAR_SECTION_FILE
HULL_COMPT_PREFIX
HULL_CRV_FONT_COLOR_FILE
HULL_CUTOUT_SECTION_FILE
HULL_ENDCUT_SECTION_FILE
HULL_FLANGE_WIDTH
HULL_HOLE_SECTION_FILE
HULL_MATERIAL_CODE
HULL_MATERIAL_DESC_FILE
HULL_PILLAR_PREFIX
HULL_PLATE_BRADIUS
HULL_PLATE_PREFIX
HULL_PLATE_STOCK_FILE
HULL_PLATE_THICKNESS
HULL_PLATE_THICKNESS_X
HULL_PLATE_THICKNESS_Y
HULL_PLATE_THICKNESS_Z
HULL_STIFFENER_FLANGE_X
HULL_STIFFENER_FLANGE_Y
HULL_STIFFENER_FLANGE_Z
HULL_STIFFENER_PREFIX
HULL_STIFFENER_SECTION_FILE
HULL_STIFFENER_SECTION_FILLET
HULL_STIFFENER_STOCK_FILE
HULL_STIFFENER_WEB_X
HULL_STIFFENER_WEB_Y
HULL_STIFFENER_WEB_Z
HULL_STIFF_END1_ALLOWANCE
HULL_STIFF_END2_ALLOWANCE
HULL_STIFF_PLATE_THICKNESS_TOL
HULL_WELD_FLANGE_PREFIX
ICONIFY_ENTIRE_PRO
IGES_CLIP_VIEW_ENT
IGES_CLIP_VIEW_NOTE
IGES_DRAWING_NUMBER (hidden)
IGES_DRAWING_SCALING (hidden)
IGES_EXPORT_DWG_VIEWS
IGES_IN_106_F2_AS_SPLINE
IGES_IN_ASSOC_DIM_GEOM_21
IGES_IN_DWG_COLOR
IGES_IN_DWG_LINE_FONT
IGES_IN_DWG_VIEW
IGES_IN_FIX_ANVIL_SPL_BUG (hidden)
IGES_IN_GROUP_TO_DWG_LAYER
IGES_NOTE_DISP
IGES_OUT_ALL_SRFS_AS
IGES_OUT_ASSEMBLY_DEFAULT_MODE
IGES_OUT_CATIA_GDT_WIDTH
IGES_OUT_CATIA_NOTES
IGES_OUT_DWG_COLOR
IGES_OUT_DWG_LINE_FONT
IGES_OUT_DWG_PNT_ENT
IGES_OUT_ENT_AS_BSPLINE
IGES_OUT_JAMAIS_COMPLIANT
IGES_OUT_MIL_D_28000
IGES_OUT_PROP_CATIA_STYLE (hidden)
IGES_OUT_SPL_CRVS_AS_126
IGES_OUT_SPL_SRFS_AS_128
IGES_OUT_START_NOTE
IGES_OUT_SYMBOL_ENTITY
IGES_OUT_TRIM_CURVE_DEVIATION
IGES_OUT_TRIM_XYZ
IGES_OUT_TRM_SRFS_AS_143
IGES_USE_VARIABLE_SIZE
IGES_ZERO_VIEW_DISP
IGNORE_ALL_REF_SCOPE_SETTINGS
IGNORE_COOLANT_IN_WEDM (hidden)
IGNORE_DEFDRW_ASMNTFY (hidden)
IGNORE_EXPORT_GEOM_DECLARATION
IGNORE_FAMILY_TYPE (hidden)
IMPORT_ATTR_JOIN_LAYERS (hidden)
IMPORT_ATTR_JOIN_SRFS (hidden)
IMPORT_ATTR_MAKE_SOLID (hidden)
IMPORT_GRANITE (hidden)
IMPORT_GTOOLS_MODEL (hidden)
IMP_SPL_APPROX_TOL (hidden)
INFO_OUTPUT_MODE
INHERITANCE_FEATURE (hidden)
INITIAL_BEND_Y_FACTOR
INSTANCE_SEARCH_EXHAUSTIVE
INTERFACE_QUALITY
INTF2D_FIT_INCOMPATIBLE_DATA
INTF2D_OUT_ENHANCED_ENTS
INTF3DIN_UPDATE_VIA_IDS (hidden)
INTF3DIN_UPDATE_VIA_NAMES (hidden)
INTF3D_IN_CLOSE_OPEN_BOUNDARIES
INTF3D_IN_ENABLE_LAYER_JOIN
INTF3D_IN_INCLUDE_ITEMS
INTF3D_IN_MEDUSA (hidden)
INTF3D_IN_POLTXT (hidden)
INTF3D_IN_PROFILES
INTF3D_IN_SHOW_JOIN_LAYERS_ATTR
INTF3D_OUT_CAT2_IDENT_CRV (hidden)
INTF3D_OUT_CAT2_IDENT_PT (hidden)
INTF3D_OUT_CAT2_INFINITY (hidden)
INTF3D_OUT_CAT2_MODEL_SZ (hidden)
INTF3D_OUT_CAT2_SAG (hidden)
INTF3D_OUT_CAT2_STEP (hidden)
INTF3D_OUT_DATUMS_BY_DEFAULT
INTF3D_OUT_DEFAULT_OPTION
INTF3D_OUT_EXTEND_SURFACE
INTF3D_OUT_FORCE_SURF_NORMALS
INTF3D_OUT_SURFACE_DEVIATION
INTF_CATIA_VERSION
INTF_COLLAPSE_GEOM
INTF_FORCE_DTL_VIEW_DISP_LIST (hidden)
INTF_IN_ARCLENGTH_CRV_REPARAM (hidden)
INTF_IN_ARCLENGTH_REPARAM
INTF_IN_ASSIGN_PNT_LABEL (hidden)
INTF_IN_BACKUP_BSPLRF (hidden)
INTF_IN_BLANKED_ENTITIES
INTF_IN_DWG_PNT_ENT
INTF_IN_DWG_VIEW
INTF_IN_EXCL_DISCONT_GEOM (hidden)
INTF_IN_EXTERNAL_ACCURACY (hidden)
INTF_IN_EXTRACT_PROFILES
INTF_IN_KEEP_BEZIER_SURFACE (hidden)
INTF_IN_KEEP_HIGH_DEG_BSPL_SRFS (hidden)
INTF_IN_LAYER_ASM_DIALOG
INTF_IN_LAYER_NAME_MSGS (hidden)
INTF_IN_SIMPLIFY_SURFACE (hidden)
INTF_IN_SURF_BOUNDARY_PREF
INTF_IN_TREAT_POLYLINE_AS
INTF_OUT_ASM_MAPPED_ITEM
INTF_OUT_ASSIGN_NAMES
INTF_OUT_AS_BEZIER
INTF_OUT_AUTO_LAYER_IDS
INTF_OUT_BLANKED_ENTITIES
INTF_OUT_CADDS_NAME_SPLIT (hidden)
INTF_OUT_LAYER
INTF_OUT_LAYER_RENAME_TABLE
INTF_OUT_MAX_BSPL_DEGREE
INTF_OUT_TEXT_LENGTH
INTF_PDGS_VERSION
INVENTOR_EXPORT_CURV_SURF (hidden)
ISITE_PROMPT (hidden)
ISOGEN_ENDTYPE_MAP_FILE
ISOGEN_MANDATORY_ATTR_FILE
ISOGEN_NOMINAL_SIZE_MAP_FILE
ISOGEN_OUTPUT_FILES_DIR
ISOGEN_PCF_FILENAME_FORMAT
ISOGEN_SYMBOL_MAP_FILE
ISOSPLT_MRG_IN_IMP_FIX (hidden)
JPEG_EXPORT_OFF_SCREEN (hidden)
KBD_CMD_ABBREVIATION
KBD_SELECTION
KEEP_60_EXPLODE (hidden)
KEEP_INFO_DATUMS
LANG_PROPAGATE
LAYER_CHANGE_REGEN_DRAWING
LAYER_INTCHG_FUNCT
LAYER_INTCHG_SIMP
LCG_REFERENCE_OPTION
LET_PROE_RENAME_ILINK_OBJECTS
LET_PROE_RENAME_PDM_OBJECTS
LINEAR_TOL
LINEAR_TOL_0.000000
LINEAR_TOL_0.00000
LINEAR_TOL_0.0000
LINEAR_TOL_0.000
LINEAR_TOL_0.00
LINEAR_TOL_0.0
LODS_ENABLED
LODS_VALUE
LOGICAL_OBJECTS
MAINTAIN_LIMIT_TOL_NOMINAL
MAKE_GROUP_FEATURE_WITH_TABLE (hidden)
MAKE_LOGOBJ (hidden)
MAKE_PARAMETERS_FROM_FMT_TABLES
MAKE_PROJ_VIEW_NOTES
MAPKEY
MARK_APPROXIMATE_DIMS
MAXIMUM_TEXTURE_SIZE
MAX_ANIMATION_TIME
MAX_COLORMAP_SIZE (hidden)
MAX_LO_ELEMS_NUM (hidden)
MAX_SEQ (hidden)
MAX_VERSIONS (hidden)
MDL_TREE_CFG_FILE
MDO_DENSITY
MDO_SPRING_WIRE_RADIUS
MEASURE_SIG_FIGURES
MECHANICA_IS_RUNNING (hidden)
MECHANISM_ALERT (hidden)
MECHANISM_ENABLE_WELDS (hidden)
MEDUSA_2D_CONFIG_FILE
MEMORYMAP_OUTPUT_FILES (hidden)
MENTOR_VER_2_0
MENU_ACTIVATE_ON_PRESS
MENU_FONT
MENU_HORIZONTAL_HINT
MENU_PLACEMENT (hidden)
MENU_SHOW_INSTANCES
MENU_STATISTICS_FILENAME (hidden)
MENU_TRANSLATION
MERGE_SMT_SRFS_WITHOUT_SEAM
MESH_SPLINE_SURF
MFG_AUTO_LOCAL_CORNER (hidden)
MFG_AUTO_REF_PRT_AS_CHK_SRF
MFG_CL_ARCHIVE (hidden)
MFG_CONNECT_MAX_DIST (hidden)
MFG_CROSS_CUT (hidden)
MFG_CUSTOMIZE_DIALOG
MFG_CVNC_PROJ_MODE (hidden)
MFG_DISPLAY_MC (hidden)
MFG_EXCL_SRFS_BY_SLOPE_ANGLE (hidden)
MFG_IJK_NUM_DIGITS
MFG_INFO_DLG_DISPLAY (hidden)
MFG_INFO_LOCATION
MFG_LOCAL_SLOPE_REJECT (hidden)
MFG_LOC_HANDLE_FLAT_TOOLS (hidden)
MFG_MACH_AREA_SRF (hidden)
MFG_MODAL_COMMAND_FILE
MFG_NEW_HOR_MILL (hidden)
MFG_NEW_NC_CHECK (hidden)
MFG_NEW_ROT_CL_FORMAT (hidden)
MFG_NEW_TRAJECTORY (hidden)
MFG_NEW_WINDOW (hidden)
MFG_PARAMETERS_22 (hidden)
MFG_PARAM_MODE
MFG_POCKET_EXTEND (hidden)
MFG_PROD20_UTILS (hidden)
MFG_R20_BLADE_MILL (hidden)
MFG_REGION_DEFAULT (hidden)
MFG_SLOPE_ANGLE_PROJ (hidden)
MFG_TEMPLATE_DIR
MFG_TOOL_DATABASE (hidden)
MFG_TOOL_FEED_SPEED (hidden)
MFG_TOOL_WITHOUT_SPEED (hidden)
MFG_TRAJECTORY_PREVIEW (hidden)
MFG_USE_NEW_SRF_MILL (hidden)
MFG_USE_REF_TREE (hidden)
MFG_XYZ_NUM_DIGITS
MILL_HEAD_OUTPUT (hidden)
MILL_PARAMS_FILE (hidden)
MIN_ANIMATION_STEPS
MODDIM_EMB (hidden)
MODELCHECK_ENABLED
MODEL_ALLOW_REF_SCOPE_CHANGE
MODEL_GRID_BALLOON_DISPLAY
MODEL_GRID_NEG_PREFIX
MODEL_GRID_NUM_DIG
MODEL_GRID_SPACING
MODEL_NOTES_AS_LABELS
MODEL_NOTE_DISPLAY
MODEL_RENAME_TEMPLATE
MODEL_TREE_START
MOLD_AUTO_WP_REC (hidden)
MOLD_AUTO_WP_ROUND (hidden)
MOLD_LAYOUT20 (hidden)
MOLD_LAYOUT_ORIGIN_NAME
MOLD_SHRINK_DATUM (hidden)
MOLD_TOP_MENUS_VISIBLE (hidden)
MOLD_VOL_SURF_NO_AUTO_ROLLBACK
MOTION_ENVLP_ALERT
MSG_TRANSLATION
MULTIPLE_SKELETONS_ALLOWED
MULTIPOINT_LOCATION_COUNT
NAME_EMB (hidden)
NATIVE_KBD_MACROS
NCCHECK_TYPE
NCL_FILE_EXTENSION
NCMDL_BAR_STOCK_PART_PATH
NCMDL_BILLET_STOCK_PART_PATH
NCMDL_MIN_STOCK_ALLOWANCE (hidden)
NCPOST_TYPE
NCX_WIZARD (hidden)
NC_CORNER_MILL (hidden)
NC_LOCAL_MACHSRFS (hidden)
NC_LOCAL_MULTISLICE (hidden)
NC_PENCIL_TRACE (hidden)
NEUTRAL_FILE_WITH_VERSION (hidden)
NEW_ASM_REGEN_REVNUMS
NEW_CONV_3AX (hidden)
NEW_CUTLINE (hidden)
NEW_DIALOG_UI_TEMP (hidden)
NEW_DIEFACE_ANALYSIS (hidden)
NEW_DIEFACE_FUNCS (hidden)
NEW_DISPLAY_ANALYSIS (hidden)
NEW_FREEFORM_TOOLS (hidden)
NEW_IGES_IMPORT (hidden)
NEW_IMPORT_MENUS (hidden)
NEW_INST_ACC_UI (hidden)
NEW_MDO_API (hidden)
NEW_MFG_DIALOG (hidden)
NEW_NC_FIXTURE (hidden)
NEW_PARAMETER_UI
NEW_PIPCONN_UI (hidden)
NEW_REF_PART_NAME_DISABLED (hidden)
NEW_RELATION_KERNEL (hidden)
NEW_RELATION_UI
NEW_RENAME_ASSEM_UI (hidden)
NEW_REPORT_FUNCS (hidden)
NEW_SCAN_MENUS (hidden)
NEW_SEL_UI (hidden)
NEW_STYLING (hidden)
NEW_THREAD_MILL (hidden)
NEW_TRAJECTORY_CR_FLAG (hidden)
NEW_UDF_FT_UI (hidden)
NEW_UDF_UI (hidden)
NEW_UI_REGRESS (hidden)
NEW_VERIFY_FUNC (hidden)
NOTCH_UTILS (hidden)
NSIDED_STRETCH (hidden)
NT_CACHE_DIRS
NUMBER_USER_COLORS
NUMBER_WIREFRAME_COLORS
NUM_MSGS_IN_HIST_NEW_UI (hidden)
OFFSET_LINE_DEF_COLOR
OFFSET_LINE_DEF_FONT
OFFSET_LINE_SNAP_ACCURACY (hidden)
OLD_AREA_UNFOLD_XSEC_VIEWS (hidden)
OLD_PLAY_PATH_UI (hidden)
OLD_PLUNGE_MOTION (hidden)
OLD_REP_REGEN (hidden)
OLD_STYLE_CURVE_OPER (hidden)
OLD_STYLE_SIZING (hidden)
OPEN_SIMPLIFIED_REP_BY_DEFAULT
OPTIMIZE_REV21 (hidden)
ORIENTATION
ORTHOGONAL_SNAP
OUTPUT_REGEN_LOG (hidden)
OVERLAYS_ENABLED
OVERRIDE_STORE_BACK
PACKAGE_CONSTRAINTS
PACKAGE_REF_ALERT
PARENTHESIZE_REF_DIM
PART_TABLE_EDITOR
PATT_MODEL_COLUMN (hidden)
PDM_REV
PEN1_LINE_WEIGHT
PEN2_LINE_WEIGHT
PEN3_LINE_WEIGHT
PEN4_LINE_WEIGHT
PEN5_LINE_WEIGHT
PEN6_LINE_WEIGHT
PEN7_LINE_WEIGHT
PEN8_LINE_WEIGHT
PEN_SLEW
PEN_SLEW_XY
PEN_TABLE_FILE
PHONG_SHADING (hidden)
PHOTORENDER_DEFAULT_HEIGHT
PHOTORENDER_DEFAULT_WIDTH
PHOTORENDER_MAX_SHARED_MEM_SIZE
PHOTORENDER_MEMORY_USAGE
PHOTORENDER_PREVIEW_SCALE
PHOTORENDER_SHARED_MEM_FILENAME
PHOTORENDER_TIMEOUT
PICK_APERTURE_RADIUS
PICK_CHAIN_REL_EPS (hidden)
PICK_CHAIN_TANGENT_ONLY
PIPELINE_ASSEMBLY_NAME_FORMAT
PIPELINE_LABEL_FORMAT
PIPELINE_MIN_SEGMENT_LENGTH
PIPELINE_SOLID_START_PART_NAME
PIPELINE_SPOOL_LABEL_FORMAT
PIPELINE_START_ASSEMBLY_NAME
PIPE_3D_BEND_THEOR_INT_PTS
PIPE_ALLOW_SCHEMATIC_CHECK (hidden)
PIPE_BEND_LOCATIONS_CSYS_UNITS (hidden)
PIPE_PRE_22_BENDINFO_CONV
PIPE_SOLID_CENTERLINE
PIPE_UPDATE_PRE_20_INT_PTS
PIPING_APPEARANCE_MAP_FILE
PIPING_DESIGN_METHOD
PIPING_END_COMPATIBILITY_FILE
PIPING_FITT_ANGLE_TOLERANCE
PIPING_FITT_CATEGORY_MAP_FILE
PIPING_FITT_LIBRARY_DIR
PIPING_FITT_LIB_DIR
PIPING_FLUID_PARAMETER
PIPING_INSULATION_DIR_FILE
PIPING_MANUFACTURE_DIR_FILE
PIPING_MATERIAL_FILE
PIPING_MCAT_DIR
PIPING_MCAT_DIR_FILE
PIPING_MIN_BOLTING_CLEARANCE
PIPING_PROJECT_DATA_DIR
PIPING_SPEC_DIR_FILE
PIPING_SYSTEM_TREE_FORMAT
PIPING_THUMB_WHEEL_INCREMENT
PIPING_THUMB_WHEEL_RATIO_INC (hidden)
PLOTTER
PLOTTER_COMMAND
PLOTTER_HANDSHAKE
PLOT_DRAWING_FORMAT (hidden)
PLOT_FILE_DIR
PLOT_LINESTYLE_SCALE
PLOT_NAMES
PLOT_PROCEED_DIALOG
PLOT_TO_SCALE_FULL_WINDOW
POPUPHELP_FONT
POPUP_MENU_DELAY (hidden)
POSTSCRIPT_COMPRESSION
POSTSCRIPT_LEVEL (hidden)
PPRINT_EXTENDED_INFO (hidden)
PREFERRED_EDITOR (hidden)
PREFERRED_SAVE_AS_TYPE
PREHIGHLIGHT
PREV_PROC_COMP_DEF_COLOR
PREV_PROC_COMP_DEF_FONT
PROCESS_ASM_RETRIEVE_ALL_COMPS (hidden)
PRODEVDAT
PROFILE_OUTPUT_UTILS
PROF_LOOP_CONNECT (hidden)
PROG_SUPP_EXT_REF_REGEN (hidden)
PROJ_SKETCH_ORIGIN (hidden)
PROMPT_ON_ERASE_NOT_DISP
PROMPT_ON_EXIT
PRONCPOST_DBF
PROPAGATE_CHANGE_TO_PARENTS
PROREMBATCH_QUEUE_MANAGER
PROTABLE_IN_BACKGROUND
PROTKDAT
PROVIDE_PICK_MESSAGE_ALWAYS
PRO_ANSYS_PATH
PRO_CATALOG_DIR
PRO_CAV_LAY_RULE_DIR
PRO_COLORMAP_PATH
PRO_COSMOS_PATH
PRO_CROSSHATCH_DIR
PRO_DATUM_TARGET_DIR (hidden)
PRO_DELTA_ENABLED (hidden)
PRO_DTL_SETUP_DIR
PRO_EDITOR_COMMAND
PRO_FONT_DIR
PRO_FORMAT_DIR
PRO_GPLUG_DIR
PRO_GROUP_DIR
PRO_INSULATION_DIR
PRO_LIBRARY_DIR
PRO_MATERIAL_DIR
PRO_MDB_DIR
PRO_MFG_CMDSYN_DIR
PRO_MF_CLAMP_DIR
PRO_MF_CL_DIR
PRO_MF_PARAM_DIR
PRO_MF_TPRM_DIR
PRO_MF_WORKCELL_DIR
PRO_NASTRAN_CONV
PRO_NASTRAN_PATH
PRO_NOTE_DIR
PRO_PIP_FITT_DIR
PRO_PIP_LNSTK_DIR
PRO_PLOT_CONFIG_DIR
PRO_RMDT_DATA_DIR (hidden)
PRO_SHEET_MET_DIR
PRO_SMT_PARAMS_DIR
PRO_SOLVER_FORMAT (hidden)
PRO_SOLVER_NAME
PRO_SOLVER_PATH
PRO_SPOOL_DIR
PRO_SURFACE_FINISH_DIR
PRO_SYMBOL_DIR
PRO_TEXTURE_LIBRARY
PRO_UNIT_LENGTH
PRO_UNIT_MASS
PRO_UNIT_SYS
PRO_WELD_PARAMS_DIR
PRO_XOFFSET (hidden)
PS_OUTPUT_WITH_PAGESIZE
PTNCPOST_DBF
PUNCH_AXIS_POINTS
PUNCH_AXIS_REF_POINTS (hidden)
PUNCH_COSMETIC_THREAD (hidden)
PUSH_TXT_WIN_FOR_TRAIN (hidden)
PUT_FREE_CABLES_ON_SURF (hidden)
PUT_IGES_DRAWING_ENTITY
QUERY_BIN_START
RADIAL_HOLE_LINEAR_DIM
RASTER_PLOT_DPI
READ_FAMTAB_FILE_ON_RETRIEVE
READ_VDA_IN_PSET_AS_SPLINE
RECOMPUTE_IGES_DIM_VALUE
RECOVER_CG_REFS_ON_RETRIEVE (hidden)
REDUCE_SPIN_FLASH
REF_DES_DISPLAY (hidden)
REF_SCOPE_COPY_COLOR (hidden)
REF_SCOPE_COPY_COLOR_CHANGE (hidden)
REF_SCOPE_NO_PICK_TO_COPY (hidden)
REF_SCOPE_NO_PICK_TO_PROHIBIT (hidden)
REF_SCOPE_PROHIBIT_COLOR (hidden)
REF_SCOPE_PROHIBIT_COLOR_CHANGE (hidden)
REF_SCOPE_TEST_MODE_ON (hidden)
REGENERATE_READ_ONLY_OBJECTS (hidden)
REGEN_BACKUP_DIRECTORY
REGEN_BACKUP_USING_DISK
REGEN_INT_MDLS_ON_RETR
REGEN_LAYOUT_W_ASSEM
REGEN_PLAYER
REGEN_READ_ONLY_INSTS (hidden)
RELATION_FILE_EDITOR
RELAT_MARKS_OBJ_MODIFIED (hidden)
REL_DRIVEN_VAL_CHECK (hidden)
REMEMBER_LAST_GET_POINT_OPTION
REMOVE_UNUSED_TOL_TABLES (hidden)
RENAME_DRAWINGS_WITH_ASSEM (hidden)
RENAME_DRAWINGS_WITH_OBJECT
REPEAT_DATUM_CREATE
REPLACE_COMP_NAME_METHOD
REPLACE_COMP_NOTES_METHOD
REROUTE_OWN_REF_ID (hidden)
RESERVED_MENU_SPACE
RESTRICTED_GTOL_DIALOG
RETAIN_DISPLAY_MEMORY
RETAIN_PATTERN_DEFINITION (hidden)
RETRIEVE_DISPLAY (hidden)
RETRIEVE_MERGE_REF_PARTS
RIGHT_MOUSE_BUTTON_POPUP
RMDT_WORKPIECE_ALLOWANCE (hidden)
ROTATE_POSTSCRIPT_PRINT
ROTATE_VIEW_ANGLE_FOR_Z_DRAG (hidden)
SAVE_BITMAP
SAVE_BITMAP_TYPE
SAVE_DISPLAY
SAVE_DRAWING_PICTURE_FILE
SAVE_FULL_TOP_LEVEL_DISPLAY (hidden)
SAVE_INSTANCE_ACCELERATOR
SAVE_MODEL_DISPLAY
SAVE_MODIFIED_DRAW_MODELS_ONLY
SAVE_OBJECTS
SAVE_OBJECT_IN_CURRENT
SAVE_TRIANGLES_FLAG
SAVE_UNCHANGED_PDM_OBJECT
SAW_PARAMS_FILE (hidden)
SCAN_CLOUD_ADV_FLTR (hidden)
SCAN_CLOUD_VISIBLE (hidden)
SCAN_TOOLS_GLB_ANLS (hidden)
SCOPE_INVALID_REFS
SEARCH_PATH
SEARCH_PATH_FILE
SECTION_COLOR
SELECTION_OF_REMOVED_ENTITIES
SELECT_HIDDEN_EDGES_IN_DWG
SELECT_ON_DTM_EDGES
SEL_INSTS_ON_COMP_RETRIEVAL
SETBUTTON (hidden)
SET_MENU_WIDTH
SET_MODEL_TYPES_TO_SAVE
SET_PPRINT_DIALOG (hidden)
SET_SMART_PARAM (hidden)
SET_TRAIL_SINGLE_STEP
SET_ZERO_CURVATURE_COLOR
SHADED_POSTSCRIPT_BACKGROUND
SHADE_BOTH_SIDE_SRF (hidden)
SHADE_DATUM_SURFACES (hidden)
SHADE_MFG_REF_MODELS
SHADE_MOVING_COMP
SHADE_SURFACE_FEAT
SHADE_WINDOWS
SHADE_WITH
SHELLEXP_SWITCH_HULL_SIDE
SHELLEXP_TO_SCALE_GAP
SHIP_BUTT_PREFIX
SHIP_COAMING_PREFIX
SHIP_COMPT_SPEC_FILE
SHIP_DECK_PREFIX
SHIP_DRAW_PARAM_FILE
SHIP_FRAME_LANDING_PREFIX
SHIP_FRAME_PREFIX
SHIP_LONG_BULKHEAD_PREFIX
SHIP_NAME
SHIP_SEAM_PREFIX
SHIP_TRANS_BULKHEAD_PREFIX
SHOW_AUTODRILLING_TABLE (hidden)
SHOW_AXES_FOR_EXTR_ARCS
SHOW_CAV_FIT_LOC_SYS
SHOW_DIM_SIGN
SHOW_GEOM_CHECKS_ON_CREATION
SHOW_PREVIEW_DEFAULT
SHOW_REFDES_COLORS
SHOW_SHADED_EDGES
SHOW_SHELL_ELEMENTS
SHOW_SURFACE_INFO (hidden)
SHRINKAGE_VALUE_DISPLAY
SHRINKWRAP_ALERT
SHRINK_CACHE_ENABLE (hidden)
SHTMTL_UTILS (hidden)
SILHOUETTES
SILH_CURVE_21 (hidden)
SIMP_REP_RETR_UPDATE (hidden)
SIMULATION_FEM_MODE
SIM_DISPLAY_ARROW_SCALE
SIM_DISPLAY_ARROW_TOUCHING
SIM_DISPLAY_BARS
SIM_DISPLAY_BEAMS
SIM_DISPLAY_BEAM_RELEASE
SIM_DISPLAY_BEAM_SECTIONS
SIM_DISPLAY_CONNECTIONS
SIM_DISPLAY_GAPS
SIM_DISPLAY_INDIVIDUAL_COLORS
SIM_DISPLAY_LOAD_DISTRIBUTION
SIM_DISPLAY_LOAD_ICONS
SIM_DISPLAY_LOAD_TEXT
SIM_DISPLAY_MASSES
SIM_DISPLAY_MOTION_CAMS
SIM_DISPLAY_MOTION_CONNECTIONS
SIM_DISPLAY_MOTION_CONTACT_RGNS
SIM_DISPLAY_MOTION_DESIGN_VARS
SIM_DISPLAY_MOTION_DRIVERS
SIM_DISPLAY_MOTION_GEARS
SIM_DISPLAY_MOTION_GROUND_PNTS
SIM_DISPLAY_MOTION_LCS
SIM_DISPLAY_MOTION_LOADS
SIM_DISPLAY_MOTION_SLOTS
SIM_DISPLAY_RIGID_CONNECTIONS
SIM_DISPLAY_SHELLS
SIM_DISPLAY_SPOT_WELDS
SIM_DISPLAY_SPRINGS
SIM_DISPLAY_STRUCT_CONSTRAINTS
SIM_DISPLAY_STRUCT_CONTACT_RGNS
SIM_DISPLAY_STRUCT_LOADS
SIM_DISPLAY_STRUCT_MASSES
SIM_DISPLAY_STRUCT_SPRINGS
SIM_DISPLAY_THERM_CONSTRAINTS
SIM_DISPLAY_THERM_LOADS
SIM_MESH_ASSOCIATIVITY (hidden)
SIM_REGEN_ON_ENTRY
SIM_UNIT_INFO_DIALOG (hidden)
SKELETON_IN_PART_MODE (hidden)
SKELETON_MODEL_DEFAULT_COLOR
SKETCHER_3D_DRAG (hidden)
SKETCHER_ANIMATED_MODIFY
SKETCHER_BLENDED_BACKGROUND
SKETCHER_CONVERT_SPLINES (hidden)
SKETCHER_DEC_PLACES
SKETCHER_DIMENSION_BLANKING (hidden)
SKETCHER_DISP_CONSTRAINTS
SKETCHER_DISP_DIMENSIONS
SKETCHER_DISP_GRID
SKETCHER_DISP_KNOWN_ENTS (hidden)
SKETCHER_DISP_VERTICES
SKETCHER_DXF_IMPORT
SKETCHER_DYNAMIC_DIMENSIONING (hidden)
SKETCHER_INTENT_MANAGER
SKETCHER_NEW_UI
SKETCHER_OLD_DEFAULT_GRID (hidden)
SKETCHER_OVERVIEW_ALERT
SKETCHER_README_BUTTON
SKETCHER_REFIT_AFTER_DIM_MODIFY
SKETCHER_STARTS_IN_2D
SKETCHER_UNDO (hidden)
SKETCHER_UNDO_STACK_LIMIT200
SKIP_PREWRITE_SPL_OPTION (hidden)
SKIP_SMALL_SURFACES (hidden)
SMM_INDX_STN_PRTY (hidden)
SMM_INFO_STYLE (hidden)
SMM_NCSEQ_NEW_REGEN (hidden)
SMM_TOOLNO_CMD_OUTPUT (hidden)
SMOOTH_LINES
SMOOTH_LODS
SMT_ADD_ALLOW_DIMS (hidden)
SMT_CONVERT_SWEPT_WALLS_2001 (hidden)
SMT_CRN_REL_DISPLAY
SMT_EXTRACT_ASSEMBLY (hidden)
SMT_FIX_FORM_PLACEMENT (hidden)
SMT_MERGE_FORM_SIDES (hidden)
SMT_MFG_AUTOMATION_EDITOR (hidden)
SMT_MP_METHOD
SMT_OUTSIDE_MOLD_LINES
SMT_QUILT_OPERATION (hidden)
SPEED_UP_INSTANCE_RETRIEVAL (hidden)
SPIN_CENTER_DISPLAY
SPIN_CONTROL
SPIN_RATE_ZOOM_SENSITIVE
SPIN_SURFACE_MESH (hidden)
SPIN_WITH_NOTES
SPIN_WITH_PART_ENTITIES
SPIN_WITH_SILHOUETTES
SPLIT_FOLLOW_CUT (hidden)
START_APPMGR
START_MODEL_DIR
STD_NASTRAN_TEMPLATE
STEPIN_STYLE_BNDRY_AS_FILL_AREA (hidden)
STEP_APPEARANCE_LAYERS_GROUPS
STEP_APPEARANCE_LAYER_GROUPS
STEP_EXPORT_AP214_ASM_DEF_MODE
STEP_EXPORT_DWG_VIEWS
STEP_EXPORT_FORMAT
STEP_IN_FACETED_BREP (hidden)
STEP_IN_STYLE_BNDRY_AS_FILL_AREA
STEP_WITH_DIALOGS (hidden)
STORE_TOOL_PATH_FILE
STP_IMPT_VAL_PROPS_DELTA_ERROR (hidden)
STRONG_TREE_LOCKING (hidden)
ST_CRV_FIT_WITH_BNDS (hidden)
SUMMARY_HELP
SUPERTAB_MESH_GEOM
SUPPRESS_DLG_LICENSE_EXPIRED
SUPPRESS_LICENSE_LOSS_DIALOG
SWARF_VERTICAL_START_END (hidden)
SWITCH_DIMS_FOR_NOTES
SYMBOL_INSTANCE_PALETTE_FILE
SYMBOL_PALETTE_INPUT
SYM_LEADER_ORIENT_MOVE_TEXT
SYNCHRONIZE_MILLING (hidden)
SYSTEM_BACKGROUND_COLOR
SYSTEM_COLORS_FILE
SYSTEM_CURVES_COLOR
SYSTEM_DIMMED_MENU_COLOR
SYSTEM_EDGE_HIGH_COLOR
SYSTEM_GEOMETRY_COLOR
SYSTEM_HIDDEN_COLOR
SYSTEM_HIGHLIGHT_COLOR
SYSTEM_IGES_HEADER_FILE
SYSTEM_LETTER_COLOR
SYSTEM_SECTION_COLOR
SYSTEM_SHEETMETAL_COLOR
SYSTEM_VOLUME_COLOR
TABLET_DEVICE_NAME
TANGENT_APPR_ADJ (hidden)
TANGENT_DRAFT_OPTIONS_ALLOWED (hidden)
TANGENT_EDGE_DISPLAY
TAN_ANGLE_FOR_DISP
TDD_DEBUG (hidden)
TEMPLATE_DESIGNASM
TEMPLATE_DRAWING
TEMPLATE_ECADASM
TEMPLATE_ECADPART
TEMPLATE_MFGCAST
TEMPLATE_MFGMOLD
TEMPLATE_MOLD_LAYOUT (hidden)
TEMPLATE_SHEETMETALPART
TEMPLATE_SOLIDPART
TERMINAL_COMMAND
TEST_WORKSPACE (hidden)
TEXTURE
TEXTURE_SEARCH_PATH
TEXT_HEIGHT_FACTOR (hidden)
THERMO_POSITION_HINT
TIFF_COMPRESSION
TIFF_TYPE
TIMEOUT_MULTIPLIER
TODAYS_DATE_NOTE_FORMAT
TOLERANCE_CLASS
TOLERANCE_STANDARD
TOLERANCE_TABLE_DIR
TOL_DISPLAY
TOL_MODE
TOOLKIT_DB_CHANNEL (hidden)
TOOLKIT_REGISTRY_FILE
TOPOBUS_DASA_LAYER_SCHEME (hidden)
TOPOBUS_ENABLE
TOPOBUS_FORCE_REPAINT (hidden)
TOPOBUS_QA_TIM_CONVERT (hidden)
TRAIL_DELAY
TRAIL_DIR
TRAIN_FILE_PATH
TRAJECTORY_OPTIMIZE (hidden)
TRAJ_MATREM (hidden)
TRANSPARENCY
TRIM_LINE_ACCURACY (hidden)
TRI_QUALITY (hidden)
TRNG_DONT_SHRINK (hidden)
TRY_G2_FIX_ON_IMPORT
TRY_NONINST_ON_FAIL (hidden)
TURN_PARAMS_FILE (hidden)
TURN_PROFILE_OUT_OF_PLANE (hidden)
TUTOR_ENABLED
TUTOR_PATH (hidden)
TUTOR_ROUNDS (hidden)
UI_FILES_HAVE_VERSIONS (hidden)
UNLOCK_PIPCONN_DIMS (hidden)
UNSETBUTTON (hidden)
UPDATE_FLAT_LOC_PACKING (hidden)
UPDATE_HARNESS_MFG_LINE_COLOR
UPDATE_PRE_130_HARNESS
UPDATE_PRE_16_CABLE_LAYERS
UPDATE_REP_REFS (hidden)
USER_DEFINED_PLOT_SEGMENTS (hidden)
USER_IGES_HEADER_FILE
USER_MENUS_DIR (hidden)
USE_15_STYLE_ASMFEATS (hidden)
USE_8_PLOTTER_PENS
USE_ASSEM_FUNC_19 (hidden)
USE_CADAM_PLOT_DATA
USE_DIFF_CHORD_HEIGHTS (hidden)
USE_FAMTAB_TREE_TOOL (hidden)
USE_IGES_FONT_1003
USE_IGES_KANJI_FONT_2001
USE_INPUT_DLG_IN_TRAIL (hidden)
USE_INTEG_REPS (hidden)
USE_LAYER_DISPLAY_DIALOG (hidden)
USE_LIFT_TOOL_CLR (hidden)
USE_MAJOR_UNITS
USE_MASTER_FOR_BAD_DISP_REPS
USE_NEW_ASM_INFO_REGEN (hidden)
USE_NEW_CUT_LINE_UI (hidden)
USE_NEW_INTCHG
USE_NEW_ODUI (hidden)
USE_NEW_SELSPEC_UI
USE_NEW_STEP_ELEMENTS (hidden)
USE_NOM_DIM_VAL_IN_EXP
USE_NOM_DIM_VAL_IN_EXPR
USE_PARCHILD_INFO_DLG (hidden)
USE_PART_COLOR_FOR_HIDDEN_LINES
USE_POWER_FOR_SMM_CONT_OUTPUT (hidden)
USE_SESSION_ID_DLG (hidden)
USE_SHRUNK_STATE_IN_MEM
USE_SMT_TURRET_DIALOG
USE_SOFTWARE_LINEFONTS
USE_SPEEDY_TREE_NAME (hidden)
USE_STD_ODUI (hidden)
USE_TEMP_DIR_FOR_INST
USE_TRAIL_PICKS (hidden)
USE_TURN_REV_22 (hidden)
USE_V19_CLEAN_DIMS (hidden)
VARIABLE_PLOTS_IN_INCHES
VARIANT_DRAWING_ITEM_SIZES
VDA_HEADER
VERSATEC_CUTTER_INSTALLED
VISIBLE_MAPKEYS
VISIBLE_MESSAGE_LINES
VOL_ROUGH_AND_CLEAN_UP (hidden)
VRML_ANCHOR_URL
VRML_ASM_REP_EXPORT (hidden)
VRML_BACKGROUND_COLOR
VRML_EXPLODE_LINES
VRML_EXPORT
VRML_EXPORT_RESOLUTION
VRML_FILE_DUPLICATE_MATERIAL
VRML_LOD_SCALE (hidden)
VRML_MULTIPLE_VIEWS
VRML_PARAMETERS
VRML_SIMPREP_EXPORT
WARN_FOR_UNLOCKED_OBJ
WEB_LINK_FILE_READ
WEB_LINK_FILE_WRITE
WEB_LINK_PROE_READ
WEB_LINK_PROE_WRITE
WEB_LINK_SECURITY_AUTOPROMPT
WEDM_UTILS (hidden)
WEDM_UTILS_NEW (hidden)
WELD_ASK_XSEC_REFS
WELD_COLOR
WELD_DEC_PLACES
WELD_EDGEPREP_FUNCTIONALITY (hidden)
WELD_EDGE_PREP_DRIVEN_BY
WELD_EDGE_PREP_GROOVE_ANGLE
WELD_EDGE_PREP_GROOVE_DEPTH
WELD_EDGE_PREP_INSTANCE
WELD_EDGE_PREP_NAME_SUFFIX
WELD_EDGE_PREP_ROOT_OPEN
WELD_EDGE_PREP_VISIBILITY
WELD_UI_STANDARD
WF_FIX_CAN_ADD_SINGS (hidden)
WF_FIX_KEEP_ANLYT_SRF (hidden)
WF_FIX_LOCAL_CHANGE (hidden)
WF_FIX_SKIP_DIALOG (hidden)
WINDOW_GAMMA (hidden)
WRITE_CATII_SOLIDS (hidden)
WRITE_MMB_DEFAULT_TO_TRAIL (hidden)
WWW_EXPORT_CGM_CARB (hidden)
WWW_TARGET_LOCATION (hidden)
XSEC_UNBEND_FLATTEN (hidden)
ZIP_GAPS_KEEP_SRFS (hidden)
发表于 2003-2-15 18:25:19 | 只看该作者
ALLOW_ROUND_ALL  yes
(hidden)
这个我已经研究出来啦,
加入已后再倒圆,里面会多出一些功能!
发表于 2003-2-15 18:39:21 | 只看该作者
这么多?厉害!
发表于 2003-2-15 18:43:30 | 只看该作者
什么来,这么多,选一两个常用来讲下好吧,而且要实用性高来讲,可以吗,,我看下高手怎样做,thanks
发表于 2003-2-15 20:06:32 | 只看该作者
设置太繁复啦,请送给我你的config.pro文件,谢谢~~
netess@cmmail.com
发表于 2003-2-15 20:24:05 | 只看该作者
哗,上楼的大虾,你不研究它吗,,只要设置,不要方法是无用的
发表于 2003-2-16 10:52:19 | 只看该作者
孤独剑 wrote:
ALLOW_ROUND_ALL  yes
  (hidden)
  这个我已经研究出来啦,
  加入已后再倒圆,里面会多出一些功能!
allow_round_all                =yes
如图,选要倒圆角的边时,增加了选项目:
ALL EDGES :选所有的边倒圆角
CONVEX EDGES:选模型的凸边倒圆角
CONCAVE EDGES:选模型的凹边倒圆角
发表于 2003-2-16 10:53:36 | 只看该作者
期待继续研究……………………
GMT+8, 2026-6-13 20:31 , Processed in 0.201104 second(s), 10 queries , Gzip On, Redis On.
