查看: 17047|回复: 3
点云数据在UG界面上的显示的问题
发表于 2006-4-15 12:17:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我最近在UG平台上做逆向工程的二次开发,需要把点云数据显示在UG界面上,怎么做都显示不出来,实在想不出来办法了,所以在这里向各位高手请教,帮我看一下下面的一段程序:谢谢!
我的邮箱:libo_conquer@163.com
void DisplayDialog()
        AFX_MANAGE_STATE(AfxGetStaticModuleState());
        FILE *myfile;
        double solid_pnts_in[3];
        double solid_pnts_out[3];
        tag_t  point;
        tag_t  points;
        tag_t  feature_tag;
        myfile = fopen("D:\\a1.dat", "r+");                 // 打开文件
        rewind(myfile);
        while (!feof(myfile))
                fscanf(myfile, "%f   %f   %f\n", &solid_pnts_in[0], &solid_pnts_in[1],
                        &solid_pnts_in[2]);
                solid_pnts_out[0] = (double)solid_pnts_in[0];
                solid_pnts_out[1] = (double)solid_pnts_in[1];
                solid_pnts_out[2] = (double)solid_pnts_in[2];
                UF_CURVE_create_point(solid_pnts_out, &point);
                UF_MODL_create_points_feature(1,&points, &feature_tag);
        fclose(myfile);
发表于 2006-4-17 00:42:24 | 只看该作者
呵呵,我做的东西和楼上差不多,也没有解决这个问题,希望能得到高手指点,楼上大哥如果先解决了这个问题的话,能否也告诉我一下呢?谢谢哦!我的信箱ywsqq@hotmail.com
发表于 2006-4-18 22:51:51 | 只看该作者
我已经实现了这段程序了:
FILE *myfile;
        float fx,fy,fz;
        int count;
        tag_t   Point, feature_tag;
        double P[3];
        count = 0;
        myfile = fopen("D:\\Start.dat", "r.");
        rewind(myfile);
        while(!feof(myfile))
                fscanf(myfile, "%f %f %f\n", &fx, &fy, &fz);
                count++;
        fclose(myfile);
        rewind(myfile);
        for (int i=0; i<count; i++)
                        P[0] = (double)fx;
                P[1] = (double)fy;
                P[2] = (double)fz;
                UF_CURVE_create_point (P, &Point);
                UF_MODL_create_points_feature (1, &Point, &feature_tag );
        fclose(myfile);
    uc1601("ok",1);
发表于 2006-4-19 08:54:14 | 只看该作者
呵呵,好啊!谢谢!我试试!
GMT+8, 2026-4-28 14:17 , Processed in 0.467729 second(s), 13 queries , Gzip On, Redis On.
