查看: 16388|回复: 7
【求助】检查几何产生的许多问题如何解决?
发表于 2003-2-24 15:39:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
如图:
Info Analysis - Examine Geometry
Tiny Objects - Tolerance  =       0.025400000
Tiny objects found =  42
Please determine if these objects are correct or should be deleted
Misaligned Objects
Misaligned objects =  11
Please determine if objects are correct or edit them to be correctly aligned.
Data Structures
Bodies passed Structure test
Consistency
Degenerate geometry detected
Please replace incorrect geometry
Face-Face Intersections
Body failed other checks, test not run
Sheet Boundaries
Number of boundaries found =  47
Face Smoothness
Faces passed smoothness check
Face Self-intersection
Spikes/Cuts
Faces passed spikes/cuts check
Edge Smoothness - Angle tolerance  =       0.500000000
No unsmooth edges found
Edge Tolerances - Tolerance  =       0.025400000
All edges within specified tolerance
发表于 2003-2-24 16:01:20 | 只看该作者
发表于 2003-2-24 17:22:27 | 只看该作者
发表于 2003-2-25 13:10:59 | 只看该作者
发表于 2003-2-26 07:27:48 | 只看该作者
发表于 2003-2-26 08:29:42 | 只看该作者
发表于 2003-2-26 08:32:18 | 只看该作者
发表于 2007-11-18 19:03:33 | 只看该作者
GMT+8, 2026-8-20 21:32 , Processed in 0.070788 second(s), 11 queries , Gzip On, Redis On.
