查看: 27613|回复: 31
[原创] 关于emx自动控制零件名以及bom表的相关研究
发表于 2006-5-9 08:55:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我们打开配置选项就可以看到下表
! Konfiguration of partnames and layernames
! Dont modify the first five columns (SYSTEMNAME INDEX1-3, SIDE)
! Add the new partname in the column NAME. Add a "#" at the position, you want the project-prefix to
! be inserted. (Take care for the name is a valid ProENGINEER-name with less than 32 characters, even
! if the internal number and side-marker are added, so use maximum 26 characters-prefix length)
! With the PART_NO you define the position of the part in the bom. Insert a fix value or a "*" for let
! the system add a running number (format as a 3char-string) to the ID!
! If you have set the CREATE_LAYER or CREATE_GROUP_LAYER option in buw_mold.cfg, you can
! define the names of these layers in the last two columns.
! With the BOM_NAME you can define the bom-entry for this part, if you dont want to see the partname
! here, e.g. you dont need the project_prefix, etc. In addition to the conversions made for the
! NAME, you can define blanks in this name, substituted by a *. See example Clamping plate!
! IMPORTANT: Dont delete any entry. If you want a part not to have any layers, add "-" instead of the name.
! SYSTEMNAME                INDEX1        INDEX2        INDEX3        SIDE        NAME(no blanks)                PART_NO                SINGLE_LAYER        GROUP_LAYER        BOM_NAME
CLAMPINGPLATE                1        1        0        ES        #_L_*                1                CLPL_MH                02_PLATES        底板
CLAMPINGPLATE                1        1        0        IS        #_T_*                2                CLPL_FH                02_PLATES        面板
CAVITYPLATE                1        2        0        ES        #_S2_*                3                CAPL_MH                02_PLATES        水口推板
CAVITYPLATE                1        2        0        IS        #_S2_*                4                CAPL_FH                02_PLATES        水口推板
INTERMEDIATEPLATE        1        3        0        ES        #_U_*                5                INPL_MH                02_PLATES        垫板
INTERMEDIATEPLATE        1        3        0        IS        #_U_*                6                INPL_FH                02_PLATES        垫板
RISERS                        1        4        0        ES        #_C_*                7                RAIL_MH                02_PLATES        方铁
RISERS                        1        4        0        IS        #_C_*                8                RAIL_FH                02_PLATES        方铁
B_PLATE                        1        5        0        ES        #_B_*                9                B_PLATE                02_PLATES        B板
A_PLATE                        1        5        0        IS        #_A_*                10                A_PLATE                02_PLATES        A板
EJECTORPLATE                1        6        0        ES        #_E_*                17                EJPL_MH                02_PLATES        面针板
EJECTORPLATE                1        6        0        IS        #_E_*                18                EJPL_FH                02_PLATES        面针板
EJECTORBASEPLATE        1        7        0        ES        #_F_*                19                EBPL_MH                02_PLATES        底针板
EJECTORBASEPLATE        1        7        0        IS        #_F_*                20                EBPL_FH                02_PLATES        底针板
STRIPPERPLATE                1        8        0        ES        #_S1_*                21                STPL_MH                02_PLATES        推板
STRIPPERPLATE                1        8        0        IS        #_S2_*                22                STPL_FH                02_PLATES        水口推板
CENTERINGSLEEVE                2        1        0        IS        #_SLEEVE**                3**                SLEEVE_FH        03_GUIDES        Sleeve
BUSH_SHOULDER                2        2        0        IS        #_GBB_**                3**                BUSHINGS_FH        03_GUIDES        直身导套
BUSH                        2        3        0        IS        #_GBA_**                3**                BUSHINGS_FH        03_GUIDES        有托导套
PILLAR_SHOULDER                2        4        0        IS        #_SP_**                3**                PILLARS_FH        03_GUIDES        拉杆导柱
PILLAR                        2        5        0        IS        #_SP_**                3**                PILLARS_FH        03_GUIDES        拉杆导柱
EJECTOR_BUSH                2        6        0        IS        #_EJP_BUSH**                3**                BUSHINGS_FH        03_GUIDES        Guide*Bush
EJECTOR_PILLAR                2        7        0        IS        #_EJP_PILLAR**                3**                PILLARS_FH        03_GUIDES        Leaderpin
CENTERINGSLEEVE                2        1        0        ES        #_SLEEVE**                3**                SLEEVE_MH        03_GUIDES        Sleeve
BUSH_SHOULDER                2        2        0        ES        #_GBB_**                3**                BUSHINGS_FH        03_GUIDES        直身导套
BUSH                        2        3        0        ES        #_GBA_**                3**                BUSHINGS_MH        03_GUIDES        有托导套
PILLAR_SHOULDER                2        4        0        ES        #_GP_**                3**                PILLARS_MH        03_GUIDES        导柱
PILLAR                        2        5        0        ES        #_GP_**                3**                PILLARS_MH        03_GUIDES        导柱
EJECTOR_BUSH                2        6        0        ES        #_EJP_BUSH**                3**                BUSHINGS_MH        03_GUIDES        Guide*Bush
EJECTOR_PILLAR                2        7        0        ES        #_EJP_PILLAR**                3**                PILLARS_MH        03_GUIDES        Leaderpin
LOCATING_RING                3        1        1        ES        #_LOC_MH1                3001                LOCATING_MH        04_EQUIPMENT        Locating*Ring
LOCATING_RING                3        2        1        IS        #_LOC_FH1                3002                LOCATING_FH        04_EQUIPMENT        Locating*Ring
LOCATING_RING                3        1        2        ES        #_LOC_MH2                3001                LOCATING_MH        04_EQUIPMENT        Locating*Ring
LOCATING_RING                3        2        2        IS        #_LOC_FH2                3002                LOCATING_FH        04_EQUIPMENT        Locating*Ring
LOCATING_RING                3        1        3        ES        #_LOC_MH3                3001                LOCATING_MH        04_EQUIPMENT        Locating*Ring
LOCATING_RING                3        2        3        IS        #_LOC_FH3                3002                LOCATING_FH        04_EQUIPMENT        Locating*Ring
LOCATING_RING                3        1        4        ES        #_LOC_MH4                3001                LOCATING_MH        04_EQUIPMENT        Locating*Ring
LOCATING_RING                3        2        4        IS        #_LOC_FH4                3002                LOCATING_FH        04_EQUIPMENT        Locating*Ring
LOCATING_RING                3        1        5        ES        #_LOC_MH5                3001                LOCATING_MH        04_EQUIPMENT        Locating*Ring
LOCATING_RING                3        2        5        IS        #_LOC_FH5                3002                LOCATING_FH        04_EQUIPMENT        Locating*Ring
LOCATING_RING                3        1        6        ES        #_LOC_MH6                3001                LOCATING_MH        04_EQUIPMENT        Locating*Ring
LOCATING_RING                3        2        6        IS        #_LOC_FH6                3002                LOCATING_FH        04_EQUIPMENT        Locating*Ring
LOCATING_RING                3        1        7        ES        #_LOC_MH7                3001                LOCATING_MH        04_EQUIPMENT        Locating*Ring
LOCATING_RING                3        2        7        IS        #_LOC_FH7                3002                LOCATING_FH        04_EQUIPMENT        Locating*Ring
LOCATING_RING                3        1        8        ES        #_LOC_MH8                3001                LOCATING_MH        04_EQUIPMENT        Locating*Ring
LOCATING_RING                3        2        8        IS        #_LOC_FH8                3002                LOCATING_FH        04_EQUIPMENT        Locating*Ring
LOCATING_RING                3        1        19        ES        #_LOC_MH19                3001                LOCATING_MH        04_EQUIPMENT        Locating*Ring
LOCATING_RING                3        2        19        IS        #_LOC_FH19                3002                LOCATING_FH        04_EQUIPMENT        Locating*Ring
EXT_NOZZLE_SPRUEBUSH        3        2        2        IS        #_EXT_NSPRUEBUSH        3012                LOCATING_FH        04_EQUIPMENT        Extensionnozzle*Spruebushing
INSULATION                3        3        1        ES        #_INS_MH                3003                INSULATION_MH        04_EQUIPMENT        Insulation
INSULATION                3        3        2        ES        #_INS_MH                3003                INSULATION_MH        04_EQUIPMENT        Insulation
INSULATION                3        4        1        IS        #_INS_FH                3004                INSULATION_FH        04_EQUIPMENT        Insulation
INSULATION                3        4        2        IS        #_INS_FH                3004                INSULATION_FH        04_EQUIPMENT        Insulation
SPRUE_BUSH                3        5        1        ESIS        #_SPRBUSH1                3005                SPRUEBUSH        04_EQUIPMENT        Sprue*Bushing
SPRUE_BUSH                3        5        2        ESIS        #_SPRBUSH2                3005                SPRUEBUSH        04_EQUIPMENT        Sprue*Bushing
SPRUE_BUSH                3        5        3        ESIS        #_SPRBUSH3                3005                SPRUEBUSH        04_EQUIPMENT        Sprue*Bushing
SPRUE_BUSH                3        5        4        ESIS        #_SPRBUSH4                3005                SPRUEBUSH        04_EQUIPMENT        Sprue*Bushing
SPRUE_BUSH                3        5        5        ESIS        #_SPRBUSH5                3005                SPRUEBUSH        04_EQUIPMENT        Sprue*Bushing
RUNNER_BUSHING                3        5        2        IS        #_RUNNER_BUSH                3012                RUNNERBUSH        04_EQUIPMENT        Runner*Bushing
SUPPORT_BUSH                3        6        1        ESIS        #_SUPBUSH                3006                SUPPORTBUSH        04_EQUIPMENT        Sprue*Bushing
EJECTOR_ROD                3        7        1        ES        #_KNOCKOUT_MH                3007                KNOCKOUT        04_EQUIPMENT        Knockout
EJECTOR_ROD                3        7        2        ES        #_KNOCKOUT_MH                3007                KNOCKOUT        04_EQUIPMENT        Knockout
EJECTOR_ROD                3        7        1        IS        #_KNOCKOUT_FH                3007                KNOCKOUT        04_EQUIPMENT        Knockout
EJECTOR_ROD                3        7        2        IS        #_KNOCKOUT_FH                3007                KNOCKOUT        04_EQUIPMENT        Knockout
SIDE_INTERLOCK                3        8        1        ES        #_INTERLOCK_MH                3007                INTERLOCK_MH        04_EQUIPMENT        Side*Interlock
SIDE_INTERLOCK                3        8        1        IS        #_INTERLOCK_FH                3007                INTERLOCK_FH        04_EQUIPMENT        Side*Interlock
SIDE_INTERLOCK                3        9        1        ES        #_INTERLOCK_MH                3007                INTERLOCK_MH        04_EQUIPMENT        Side*Interlock
SIDE_INTERLOCK                3        9        1        IS        #_INTERLOCK_FH                3007                INTERLOCK_FH        04_EQUIPMENT        Side*Interlock
SIDE_INTERLOCK                3        8        2        ES        #_INTERLOCK_MH                3007                INTERLOCK_MH        04_EQUIPMENT        Side*Interlock
SIDE_INTERLOCK                3        8        2        IS        #_INTERLOCK_FH                3007                INTERLOCK_FH        04_EQUIPMENT        Side*Interlock
SIDE_INTERLOCK                3        9        2        ES        #_INTERLOCK_MH                3007                INTERLOCK_MH        04_EQUIPMENT        Side*Interlock
SIDE_INTERLOCK                3        9        2        IS        #_INTERLOCK_FH                3007                INTERLOCK_FH        04_EQUIPMENT        Side*Interlock
SIDE_INTERLOCK                3        8        3        ES        #_INTERLOCK_MH                3007                INTERLOCK_MH        04_EQUIPMENT        Side*Interlock
SIDE_INTERLOCK                3        8        3        IS        #_INTERLOCK_FH                3007                INTERLOCK_FH        04_EQUIPMENT        Side*Interlock
SIDE_INTERLOCK                3        9        3        ES        #_INTERLOCK_MH                3007                INTERLOCK_MH        04_EQUIPMENT        Side*Interlock
SIDE_INTERLOCK                3        9        3        IS        #_INTERLOCK_FH                3007                INTERLOCK_FH        04_EQUIPMENT        Side*Interlock
SCREW_912_88                4        1        0        IS        #_SCREW**                4**                HSC_SCREW_FH        05_SCREWS        内六角螺钉
SCREW_912_109                4        2        0        IS        #_SCREW**                 4**                HSC_SCREW_FH        05_SCREWS        内六角螺钉
SCREW_6912_88                4        3        0        IS        #_SCREW**                4**                HSC_SCREW_FH        05_SCREWS        内六角螺钉
SCREW_7991_88                4        4        0        IS        #_FHSCREW**                4**                CON_SCREW_FH        05_SCREWS        内六角平头螺钉
SHOULDERSCREW                4        5        0        IS        #_SHSCREW**                4**                SHO_SCREW_FH        05_SCREWS        带肩螺钉
SPRING_PLUNGER                4        6        0        IS        #_SPRINGPL**                4**                SPRING_PL_FH        05_SCREWS        弹簧柱塞
SETSCREW                4        7        0        IS        #_SETSCREW**                4**                SET_SCREW_FH        05_SCREWS        紧定螺钉
HOISTRING                4        8        0        IS        #_HOIST_RING**                4**                HOIST_RING_FH        05_SCREWS        吊环螺钉
SCREW_912_88                4        1        0        ES        #_SCREW**                4**                HSC_SCREW_MH        05_SCREWS        内六角螺钉
SCREW_912_109                4        2        0        ES        #_SCREW**                 4**                HSC_SCREW_MH        05_SCREWS        内六角螺钉
SCREW_6912_88                4        3        0        ES        #_SCREW**                4**                HSC_SCREW_MH        05_SCREWS        内六角螺钉
SCREW_7991_88                4        4        0        ES        #_FHSCREW**                4**                CON_SCREW_MH        05_SCREWS        内六角平头螺钉
SHOULDERSCREW                4        5        0        ES        #_SHSCREW**                4**                SHO_SCREW_MH        05_SCREWS        带肩螺钉
SPRING_PLUNGER                4        6        0        ES        #_SPRINGPL**                4**                SPRING_PL_MH        05_SCREWS        弹簧柱塞
SETSCREW                4        7        0        ES        #_SETSCREW**                4**                SET_SCREW_MH        05_SCREWS        紧定螺钉
HOISTRING                4        8        0        ES        #_HOIST_RING**                4**                HOIST_RING_MH        05_SCREWS        吊环螺钉
SPRING_WASHER                5        1        0        IS        #_SPRWASHER**                5**                SCREW_EQUIP_FH        05_SCREWS        Spring*Washer
STOP_DISC                5        2        0        IS        #_STOPDISC**                5**                SCREW_EQUIP_FH        05_SCREWS        Stop*Disc
STOP_PIN                5        3        0        IS        #_STOPPIN**                5**                SCREW_EQUIP_FH        05_SCREWS        Stop*Pin
TUBULAR_DOWEL                5        4        0        IS        #_TUBDOWEL**                5**                SCREW_EQUIP_FH        05_SCREWS        TUBULAR*DOWEL
SPRINGS                        5        5        1        IS        #_SPRING**                5**                SPRING_FH        04_EQUIPMENT        Spring
SPRINGS                        5        5        2        IS        #_SPRING**
这个表就是控制装配进来的emx零件后的零件名以及相关层
下面给大家讲解下相关选项的运用
SYSTEMNAME表示零件名称
INDEX1表示类型 比如1就是板 2是导向系统4是螺丝 等等
INDEX2表示零件的型号 对应<emx_loadpoint>mm/\parts里面文件名的后缀的数字
发表于 2006-5-9 09:08:34 | 只看该作者
发表于 2006-5-9 09:16:56 | 只看该作者
发表于 2006-5-9 12:42:07 | 只看该作者
发表于 2006-5-10 11:06:52 | 只看该作者
发表于 2006-5-10 15:28:34 | 只看该作者
发表于 2006-5-14 20:22:35 | 只看该作者
发表于 2006-5-15 13:06:20 | 只看该作者
发表于 2006-5-16 12:21:12 | 只看该作者
发表于 2006-5-22 01:25:46 | 只看该作者
GMT+8, 2026-8-20 22:22 , Processed in 0.068412 second(s), 11 queries , Gzip On, Redis On.
