查看: 17774|回复: 1
[求助] 用Restmill清角参数怎么设?
发表于 2006-5-12 14:51:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
用Restmill清角参数怎么设?
     total tolerance   <                              >
     maximum stepdown                                   <                   >
    corner  rounding                                           <                 >
    stepover                                                      <                  >
     extension distance                                      <                 >
        (     )  All previous operations
        (     )Dne other operation
       (    )Use regen file
      (   )  roughing  tool
      adjustments to rematning stock
         use remaining stock as comput
        adjust remining stock to ignore small
        ad just remaining stock to mill small
      分别是什么意思 ,怎么用,请哪位大师指教谢谢
   本人刚编程不久,还在试用期,请多多指教一些关于清角的方式,
发表于 2006-5-13 18:48:09 | 只看该作者
total tolerance   <          公差                    >
     maximum stepdown                                   <    最大层降步距               >
    corner  rounding                                           <  (直角走圆角的)半径               >
    stepover                                                      <          层间步距           >
     extension distance                                      <         延伸(上次加工残料的)距离        >
        ( 用所有之前的操作后的 残料计算   )  All previous operations
        (    选一个操作来 计算残料)Dne other operation
       (    使用再生文件来 计算残料)Use regen file             计算最快
      (   定义开粗刀距来 计算残料)  roughing  tool             计算慢,但效果好
      adjustments to rematning stock     残留余量调整量
         use remaining stock as comput    使用残留余量
        adjust remining stock to ignore small  调整残留余量忽略小区域
        ad just remaining stock to mill small    调整残留余量加工小区域
GMT+8, 2026-6-22 02:14 , Processed in 0.063318 second(s), 11 queries , Gzip On, Redis On.
