查看: 16064|回复: 5
[原创] 请问这是怎么回事?
发表于 2006-5-14 21:00:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
** ERROR 1300270 ** No sprue, runners or gates located.
** ERROR 1300080 ** Geometry not suitable for analysis.
我在分析充填的时候出现的,
发表于 2006-5-15 00:39:26 | 只看该作者
第一个是没做流道和胶口,
第二个是单元不适合分析,可能面还没修好。配合率太低吧。。
发表于 2006-5-15 16:24:57 | 只看该作者
谢谢你的帮助,我初学,有很多基础的都不懂,嘻嘻
发表于 2006-5-15 16:27:34 | 只看该作者
这样的分析结果有参考价值吗?
分析冷却的时候为什么有十几个错误,怎么还可以分析呢?
这样的分析结果有参考价值吗?
以下是分析出来错误的地方.请大家帮帮我,分析一下是什么原因,还有这样的分析出来的结果有没有参考价值?
** WARNING 701360 ** Beam element    3865  has a very bad length/diameter ratio
** WARNING 701360 ** Beam element    3866  has a very bad length/diameter ratio
** WARNING 701380 ** Warnings were reported in the model
                     Check the mesh quality of the model
   Total Mbytes required for cooling analysis         =    24.88
   Total Mbytes available for cooling analysis        =  1468.03
** WARNING 702352 ** Element     670  and    3807  are overlapping or too
                     close. The analysis may not be able to resolve these
                     problem elements during analysis. It is recommended
                     that you improve the mesh in the region of these
                     elements.
** WARNING 702352 ** Element     695  and    3693  are overlapping or too
                     elements.
** WARNING 702352 ** Element    1362  and    1388  are overlapping or too
                     elements.
** WARNING 702352 ** Element    2334  and    2345  are overlapping or too
                     elements.
** WARNING 702352 ** Element    2356  and    3694  are overlapping or too
                     elements.
** WARNING 702352 ** Element    2358  and    2360  are overlapping or too
                     elements.
** WARNING 702352 ** Element    2363  and    3725  are overlapping or too
                     elements.
** WARNING 702352 ** Element    2374  and    2376  are overlapping or too
                     elements.
** WARNING 702352 ** Element    2398  and    2400  are overlapping or too
                     elements.
** WARNING 702352 ** Element    2401  and    2403  are overlapping or too
                     elements.
** WARNING 702352 ** Element    2547  and    2553  are overlapping or too
                     elements.
** WARNING 702352 ** Element    2549  and    3723  are overlapping or too
                     elements.
** WARNING 702352 ** Element    2559  and    2561  are overlapping or too
                     elements.
** WARNING 702352 ** Element    2561  and    2562  are overlapping or too
                     elements.
** WARNING 702352 ** Element    2562  and    2563  are overlapping or too
                     elements.
** WARNING 702352 ** Element    2570  and    2574  are overlapping or too
                     elements.
分析检查成功完成,发现 22 个警告
发表于 2006-5-20 12:00:36 | 只看该作者
楼上的大哥
能不能传个MOLDFLOw给我啊
我的地址hk.liu@163.com
很感谢
发表于 2006-5-20 15:22:38 | 只看该作者
你这个是警告,并不是错误.
GMT+8, 2026-7-2 12:50 , Processed in 0.077509 second(s), 11 queries , Gzip On, Redis On.
