查看: 16593|回复: 4
[求助] 如何使拐角变速在程式中输出
发表于 2006-5-18 12:00:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
高手指教
怎样修改后处理才使拐角的速度在NC程式中输出
即corner feed 的数值能输出
corner feed的变量值是怎样的?
如下的变量参数找不到
谢谢指教
变量名   变量说明   数据类型   所应用的模块位子
ABS_ANG  Start angle + Delta angle  2  CIRCULAR MOTION:
ARC_ANG  Arc angle  2  CIRCULAR MOTION:
AXIS_ANGLE  Tool axis angle  2  TOOL CHANGE:
AXIS_NUM  Number of axes being used  6  AXIS CHANGE:BEGINNING OF TAPE:
BLOCK_NUM  Current block number as appears in the TP_LIST  6  All Blocks
CIR_INTERP  Circular interpolation mode   7  ORIGIN CHANGE
CIRC_MOV  Circular movement code  0  CIRCULAR MOTION:
CLEAR_LENG  Distance between holder [$ tool tip&nbsp] 1  TOOL CHANGE:
COMP_3X  3-D cutter compensation  7  LINEAR MOTION:
CURR_NAME  Current tool holder name  0  TOOL CHANGE:
CURR_ORIG  Controller/Cimatron origin no.  7  ORIGIN CHANGE: BEGINNING OF TAPE:
CURR_START  Number of current start  7  START THREAD:
CURR_TOOL  Current tool holder number  7  TOOL CHANGE:
CUT_LENGTH  Length of cutting edge of tool  1  TOOL CHANGE:
CUT_SPEED  Velocity of cutting (Vc)  1  CONSTANT SPEED:
CUT_WIDTH  Width of the tool  1  TOOL CHANGE:
CUTCOM_OFF  Cutter Compensation off code  0  CUTTER COMPENSATION:
CUTCOM_ON  Cutter Compensation on code   0  CUTTER COMPENSATION:
CYC_2PLN  Not in use.  1  CYCLE:
CYC_CLEAR  Cycle clear height  1  CYCLE:
CYC_CODE  Cycle code  0  CYCLE:
CYC_DEPTH  Cycle depth increment  1  CYCLE: GROOVE CYCLE:
CYC_DWELL  Cycle dwell time  5  CYCLE:
CYC_DZINIT  The DRILL procedure DEL INIT value  1  CYCLE:
CYC_PECK  Cycle PECK value  1  CYCLE: GROOVE CYCLE:
CYC_REDUC  Cycle DECREASE value  1  CYCLE: GROOVE CYCLE:
CYC_RETR  Cycle retract code  0  CYCLE:
CYC_TIMES  Number of pecks/cycle  7  CYCLE:
CYC_XSHFT  Cycle shift along the X axis  1  CYCLE:
CYC_YSHFT  Cycle shift along the Y axis  1  CYCLE:
CYCLE_1  Spot Drill  7  CYCLE:
CYCLE_2  High Speed Peck  7  CYCLE:
CYCLE_3  Left Hand Tapping  7  CYCLE:
CYCLE_4  Fine Boring   7  CYCLE:
CYCLE_5  Counter Boring  7  CYCLE:
CYCLE_6  Deep Hole Peck  7  CYCLE:
CYCLE_7  Tapping  7  CYCLE:
CYCLE_8  Boring  7  CYCLE:
CYCLE_9  Bore + Spindle Stop   7  CYCLE:
CYCLE_10  Back Boring   7  CYCLE:
CYCLE_11  Bore + Dwell + Manual  7  CYCLE:
CYCLE_12  Bore + Dwell + Feed   7  CYCLE:
DATE_SDD  The current day  6  BEGINNING OF TAPE:
DATE_SMM  The current month  6  BEGINNING OF TAPE:
DATE_SYY  The current year  6  BEGINNING OF TAPE:
DEL_Z_UP  Procedure DEL Z UP  1  BEGINNING OF PROC:
DIA_COMP  Diameter compensation index   1  TOOL CHANGE:
DIAMETER_  Tool diameter  1  TOOL CHANGE:
DOWN_STEP  The procedure DOWN STEP value  1  BEGINNING OF PROC:
END_ANG  End angle  2  CIRCULAR MOTION: THREAD CYCLE: THREAD CANNED CYCLE:
FACE_ANGLE  Tool face angle  2  TOOL CHANGE:
FACE_GROV  Face groove   7  GROOVE CYCLE:
FACE_THRD  Face thread   7  THREAD CYCLE: THREAD CANNED CYCLE:
FIN_BYAREA  Downstep by area - fine  7  THREAD CYCLE: THREAD CANNED CYCLE:
FIN_BYSTEP  Downstep by distance - fine   7  THREAD CYCLE: THREAD CANNED CYCLE:
FIN_DEPTH  Depth for fine machining  1  THREAD CYCLE: THREAD CANNED CYCLE:
FIN_DSTEP  Downstep for fine machining   1  THREAD CYCLE: THREAD CANNED CYCLE:
FIN_MNSTEP  Minimumdownstep-roughmachining  1  THREAD CYCLE: THREAD CANNED CYCLE:
FIN_NORMAL  Perpendicular entrance - fine  7  THREAD CYCLE: THREAD CANNED CYCLE:
FIN_ZIGZAG  Zigzag entrance for fine machining  7  THREAD CYCLE: THREAD CANNED CYCLE:
FIXT_COMP  Fixture compensation index  1  TOOL CHANGE:
GAUGE_LEN  Gauge length of tool  1  TOOL CHANGE:
GROV_CNTRL  Control point of groove tool 1=center, 2=left, 3=right  6  TOOL CHANGE:
GROV_DEL  Slow down distance in approach  1  GROOVE CYCLE:
GROV_STEP  Width of each groove pass  1  GROOVE CYCLE:
GROV_WIDTH  Total width of machined area  1  GROOVE CYCLE:
HOLD_LENG  Holder length  1  TOOL CHANGE:
HOLD_WIDTH  Holder width  1  TOOL CHANGE:
I_COORD  I component of tool axis/wire vector  1  LINEAR MOTION:
I_ORIGIN  Origin, I vector component  1  BEGINNING OF TAPE: ORIGIN CHANGE:
I_START  Initial direction, I vector component  1  BEGINNING OF PROC:
发表于 2006-5-18 12:01:10 | 只看该作者
海域眼
发表于 2006-5-27 13:07:32 | 只看该作者
发表于 2006-5-27 17:54:29 | 只看该作者
发表于 2006-5-27 19:35:46 | 只看该作者
GMT+8, 2026-8-18 01:27 , Processed in 0.064010 second(s), 11 queries , Gzip On, Redis On.
