查看: 16348|回复: 9
【讨论】请大家讨论一下这个汤匙的做法。
发表于 2003-3-1 16:13:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
PRAT文档如下:
转自:https://www.icax.net/viewthread. ... %3D1&page=#pid=&age=60
发表于 2003-3-1 17:19:03 | 只看该作者
如果要搞上面那个,我会重新作,线很烂,以现在的线作也能搞出来,但没有意义,是否同感?:-O:-O
头像被屏蔽
发表于 2003-3-1 18:44:59 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2003-3-2 12:45:41 | 只看该作者
Ding !!!
发表于 2003-3-2 12:52:08 | 只看该作者
zhai Ding !!!!
发表于 2003-3-3 00:01:54 | 只看该作者
Part ...a very typical NURBS problem, in 3 sided edge problem, we make it 4, as in this case, it is a 5 edge problem, so we make it to 4 also . hope you can get what i mean .
enjoy
发表于 2003-3-3 16:29:44 | 只看该作者
请问你是一步把它作完的
是不是先建立小的四方面
然后用connect surfaces连接起来呢
你如何保证小的四方面之间过度光华呢
仅仅是定义边界线的端点吗?
请你们细心帮助
发表于 2003-3-3 16:59:41 | 只看该作者
  我的加多了线.
发表于 2003-3-3 21:10:27 | 只看该作者
H i,
希望你能明白,我写华语太慢了。 To get a smooth surface you must had smooth curve , the smooth curve can be obtain by watching the transition of the curvature plot of the curve, in ISDX. After create the 4 edge surface , you can connect the surface created with the neighbour surface . There will be showing a "one arrow " for tangency connection & "double arrow" for curvature connection. Of course all surface connection must had higher or same degree curve .
In this spoon seem it is simple case , you can create it in one feature . You can add draft to the spoon by setting the angle of the tangency of the curve. The typical case you can refer to the sample in PTC ISDX tutorial. Such as the "pump ", 'samsung monitor" and also the joy stick which i had upload before this . cheer, hope you can get what i mean .
发表于 2003-3-4 08:20:48 | 只看该作者
CCF大佬能出个教程吗?我认为这个还是挺典型的?
GMT+8, 2026-6-26 13:31 , Processed in 0.059489 second(s), 11 queries , Gzip On, Redis On.
