查看: 18075|回复: 6
[求助] 请大家帮忙修改下错误,急!
发表于 2006-6-26 21:10:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
小第在做二次开发中遇到了如下问题,在运行VB程序时,老是出现“变量未定义”这错误,具体指出为以下句子的红色部分请高手门指点下,应该如何修改。粘贴的可能太多,请原谅~
Private Declare Function ShellExecute Lib "shell32.dll" Alias "ShellExecuteA" (ByVal hwnd As Long, ByVal lpOperation As String, ByVal lpFile As String, ByVal lpParameters As String, ByVal lpDirectory As String, ByVal nShowCmd As Long) As Long
Private Sub Command1_Click()
If Dir(App.Path & "\公差零件.SLDDRW") = "" Then
    Call MsgBox("此文件不存在!", vbExclamation)
    Exit Sub
End If
'使用默认程序打开文件
Call ShellExecute(hwnd, "Open", App.Path & "\公差零件.SLDDRW", "", App.Path, 1)
End Sub
Private Sub Command2_Click()
Set swApp = Application.SldWorks
Set Part = swApp.ActiveDoc
Set SelMgr = Part.SelectionManager
boolstatus = Part.ActivateView("工程视图4")
boolstatus = Part.Extension.SelectByID2("RD5@工程视图4", "DIMENSION", 1.064601075149, 0.6697319222769, 0, False, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("图纸1", "SHEET", 1.067232377125, 0.6657849693126, 0, False, 0, Nothing, 0)
Dim DatumTag As Object
Dim Annotation As Object
Set DatumTag = Part.InsertDatumTag2()
If Not DatumTag Is Nothing Then
   DatumTag.FilledTriangle = 1
   DatumTag.Shoulder = 0
   Set Annotation = DatumTag.GetAnnotation()
   If Not Annotation Is Nothing Then
      boolstatus = Annotation.SetPosition(1.067232377125, 0.6552597614075, -3.550623543045E-15)
   End If
End If
Part.WindowRedraw
boolstatus = Part.Extension.SelectByID2("RD5@工程视图4", "DIMENSION", 1.065916726137, 0.7868248602204, 0, False, 0, Nothing, 0)
Dim Gtol As Object
Set Gtol = Part.InsertGtol()
If Not Gtol Is Nothing Then
   Gtol.SetFrameSymbols2 1, "<IGTOL-CONC>", 1, "", 0, "", "", "", ""
   Gtol.SetFrameValues 1, "0.03", "", "A", "", ""
   Gtol.SetFrameSymbols2 2, "", 0, "", 0, "", "", "", ""
   Gtol.SetFrameValues 2, "", "", "", "", ""
   Gtol.SetPTZHeight "", 0
   Gtol.SetCompositeFrame 0
   Gtol.SetBetweenTwoPoints 0, "", ""
   Set Annotation = Gtol.GetAnnotation()
      boolstatus = Annotation.SetPosition(1.052105684718, 0.7261915134276, 0)
      longstatus = Annotation.SetLeader2(0, 0, 1, 1, 0, 0)
   End If
End If
Part.WindowRedraw
boolstatus = Part.Extension.SelectByID2("RD8@工程视图4", "DIMENSION", 0.3673060514411, 0.7605118404578, 0, False, 0, Nothing, 0)
   Gtol.SetFrameValues 1, "0.008", "", "A", "", ""
      boolstatus = Annotation.SetPosition(0.3418670761091, 0.7300920523966, 0)
   End If
End If
Part.WindowRedraw
boolstatus = Part.ActivateView("工程视图2")
boolstatus = Part.Extension.SelectByID2("RD1@工程视图2", "DIMENSION", 0.130488873578, 0.6513128084431, 0, False, 0, Nothing, 0)
   Gtol.SetFrameSymbols2 1, "<IGTOL-SYMMETRY>", 0, "", 0, "", "", "", ""
   Gtol.SetFrameValues 1, "0.02", "", "A", "", ""
      boolstatus = Annotation.SetPosition(0.1078748499866, 0.644280195078, 0)
   End If
End If
Part.WindowRedraw
boolstatus = Part.Extension.SelectByID2("", "EDGE", 0.8593595210011, 0.6671006203024, 249.96, False, 0, Nothing, 0)
   Gtol.SetFrameSymbols2 1, "<IGTOL-CYL>", 0, "", 0, "", "", "", ""
   Gtol.SetFrameValues 1, "0.005", "", "", "", ""
      boolstatus = Annotation.SetPosition(0.8657095210011, 0.6380144473886, 0.03)
      longstatus = Annotation.SetLeader2(1, 0, 1, 1, 0, 0)
   End If
End If
Part.WindowRedraw
Dim SFSymbol As Object
Set SFSymbol = Part.Extension.InsertSurfaceFinishSymbol3(1, 0, 0.1376677562039, 0.6445320878061, 0, 0, 1, "", "", "", "", "", "3.2", "")
boolstatus = Part.Extension.SelectByID2("", "EDGE", 0.429134917448, 0.7015137128612, 249.96, False, 0, Nothing, 0)
Set SFSymbol = Part.Extension.InsertSurfaceFinishSymbol3(1, 0, 0.42913812772, 0.7014153921985, 0.03, 0, 1, "", "", "", "", "", "0.8", "")
boolstatus = Part.Extension.SelectByID2("工程视图4", "DRAWINGVIEW", 0.633694851992, 0.7921103972968, 0, False, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("", "EDGE", 0.6263159365175, 0.7900606985556, 249.96, False, 0, Nothing, 0)
Set SFSymbol = Part.Extension.InsertSurfaceFinishSymbol3(1, 0, 0.6263159365175, 0.7905144473886, 0.03, 0, 1, "", "", "", "", "", "0.4", "")
boolstatus = Part.Extension.SelectByID2("", "EDGE", 0.95590749438, 0.697824255124, 249.96, False, 0, Nothing, 0)
Set SFSymbol = Part.Extension.InsertSurfaceFinishSymbol3(1, 0, 0.95590749438, 0.6985144473886, 0.03, 0, 1, "", "", "", "", "", "1.6", "")
boolstatus = Part.ActivateSheet("图纸1")
boolstatus = Part.Extension.SelectByID2("图纸1", "SHEET", 0.2956175413338, 0.8144111196199, 0, False, 0, Nothing, 0)
Set SFSymbol = Part.Extension.InsertSurfaceFinishSymbol3(1, 0, 0.2956175413338, 0.8144111196199, 0, 0, 1, "", "", "", "", "", "12.5", "")
Part.FontFace "仿宋_GB2312"
Part.FontPoints 20
Dim Note As Object
Dim TextFormat As Object
Set Note = Part.InsertNote("<FONT name=""仿宋_GB2312"" size=20PTS><FONT color=D><FONT name=""Century Gothic"" size=3.5 style=RB effect=RU><FONT style=RI effect=RS>其余")
If Not Note Is Nothing Then
   Note.Angle = 0
   boolstatus = Note.SetBalloon(0, 0)
   Set Annotation = Note.GetAnnotation()
      longstatus = Annotation.SetLeader2(False, 0, True, False, False, False)
      boolstatus = Annotation.SetPosition(0.2690534456254, 0.8237577458876, 0)
      Set TextFormat = Part.GetUserPreferenceTextFormat(swDetailingNoteTextFormat)
      TextFormat.Italic = False
      TextFormat.Underline = False
      TextFormat.Strikeout = False
      TextFormat.Bold = False
      TextFormat.Escapement = 0
      TextFormat.LineSpacing = 0.001
      TextFormat.CharHeight = 0.0035
      TextFormat.TypeFaceName = "Century Gothic"
      TextFormat.WidthFactor = 1
      TextFormat.ObliqueAngle = 0
      TextFormat.LineLength = 0
      TextFormat.Vertical = False
      TextFormat.BackWards = False
      TextFormat.UpsideDown = False
      TextFormat.CharSpacingFactor = 1
      boolstatus = Annotation.SetTextFormat(0, False, TextFormat)
   End If
End If
Part.ClearSelection2 True
Part.WindowRedraw
End Sub
发表于 2006-6-26 22:44:15 | 只看该作者
发表于 2006-6-27 09:14:21 | 只看该作者
发表于 2006-6-27 09:23:47 | 只看该作者
发表于 2006-6-27 09:27:45 | 只看该作者
发表于 2006-6-28 09:43:20 | 只看该作者
发表于 2006-6-28 10:05:58 | 只看该作者
GMT+8, 2026-8-23 04:47 , Processed in 0.057775 second(s), 11 queries , Gzip On, Redis On.
