查看: 15669|回复: 0
UG NX 1.022
 关闭 [复制链接]
发表于 2003-3-8 04:35:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
        Unigraphics. (c) Copyright 2003 EDS-PLM, Inc.  All rights reserved.
        https://support.plms-eds.com
        _______________________________________________________________________
  UNIGRAPHICS II      VERSION   1.0.2.2
  Windows 2000      Issued:   March 2003
  Files on this CDROM are for use on the Windows Intel platform only.
  UPDATE INSTRUCTIONS:
  This CDROM contains Maintenance Release files provided as
  replacements for previously installed Unigraphics NX products.
        Note: The Unigraphics NX Maintenance Releases follow the old numbering
              conventions for Unigraphics e.g. 19.0.2.2.
  The base release is a prerequisite to this maintenance release.
  To use this update, change directory to the CDROM 'update' directory,
  then execute the 'ugs_update.bat' script i.e:
    cd ugs_update1902_02
    ugs_update.bat
  Before running the ugs_update script, please make sure that the
  variable UGII_BASE_DIR is set to the base directory of the
        Unigraphics NX release. e.g:
    set UGII_BASE_DIR="c:\Program Files\EDS\Ungraphics NX"
  Or set to the appropriate installed directory on your system.
        DOCS:
        The docs directory contains an electronic snapshot of the Unigraphics
        Release Letter.  This is provided in Hyper Text Mark Up Language format
        and is viewable with standard Web Browsers such as Internet Explorer.
        Begin browsing with the following initial files:
          docs/release_notes/index.htm
GMT+8, 2026-8-15 12:47 , Processed in 0.062019 second(s), 10 queries , Gzip On, Redis On.
