查看: 16663|回复: 2
[求助] 分析失敗
发表于 2006-7-23 10:52:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我分析時冷卻出現錯誤  請問是什麼原因  如何修改  謝謝
** ERROR 701010 ** Cooling analysis has not converged
发表于 2006-7-26 09:27:21 | 只看该作者
是不是無法得到有效冷卻
我是否可以加大冷卻水管或降低水溫試試
发表于 2006-8-3 21:52:59 | 只看该作者
是冷却分析不收敛,mf 帮助中的建议有二:
1.在process setting中增加叠代次数
2.还不能收敛,则增大叠代公差
701010 Cooling analysis has not converged
Explanation: The solution has not converged before the maximum number of iterations has been reached.
Cause/Cure: On the Cool Settings page of the Process Settings Wizard, click Cool solver parameters to display the solver settings for the analysis. Increase the Maximum number of mold temperature iterations value and rerun the analysis. If, and only if, the problem cannot be resolved by increasing the maximum iterations value, try increasing the Mold temperature convergence tolerance value.
另外建议最好检查一下网格,特别是两网格法矢角太小的要修。
GMT+8, 2026-5-2 01:00 , Processed in 0.097497 second(s), 11 queries , Gzip On, Redis On.
