查看: 17215|回复: 9
[求助] 版大,我这个fill案例为什么会失败
发表于 2006-8-11 14:30:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
网格应该没问题吧?
Entity counts--------------------------------
    Surface triangles                 92582
    Nodes                         46250
    Beams                         0
    Connectivity regions        1
    Mesh volume                         689.816 cm^3
    Mesh area                         5322.31 cm^2
Edge details---------------------------------
    Free edges                        0
    Manifold edges                 138873
    Non-manifold edges                 0
Orientation details--------------------------
    Elements not oriented        0
Intersection details-------------------------
    Element intersections        0
    Fully overlapping elements         0
    Duplicate beams                  0
Surface triangle aspect ratio----------------
    Minimum aspect ratio         1.154883
    Maximum aspect ratio         12.555230
    Average aspect ratio         2.061324
Match ratio----------------------------------
    Match ratio                        88.6%
   Reciprocal ratio                 79.2%
[ 本帖最后由 cbrmbz75 于 2006-8-11 14:40 编辑 ]
发表于 2006-8-11 14:36:15 | 只看该作者
但是分析结果却是这样
Filling Analysis
Residual Stress Analysis
Date : AUG11-06
Time : 12:25:26
Allocating memory for analysis...
... finished allocating memory
Processing fusion mesh...
... finished processing fusion mesh
Reading input data...
  File name : aw56202-00f_study~1
  Reading solver parameters...
  Reading material data...
  Reading process settings...
  Reading finite element mesh...
  Reading cooling data...
NOTE: In the analysis sequence for this study, a cooling analysis has not
      been run before the flow analysis.  The flow analysis will use the
      constant mold temperature setting in the Process Settings Wizard.
      Running a cooling analysis before flow provides more detailed information
      about mold temperatures and heat fluxes.
Finished reading input data
  No mesh for the cores was found.
  Core shift analysis switched OFF
Checking input data...
** ERROR 99780 ** Zero diameter/thickness for element   94889 . An element
                  must have a non-zero value for the diameter or
                  thickness. Identify this element and
                  use an appropriate value for the diameter or thickness,
                  re-mesh the part, and re-run the analysis.
** ERROR 99780 ** Zero diameter/thickness for element   94890 . An element
** ERROR 99780 ** Zero diameter/thickness for element   94892 . An element
** ERROR 99780 ** Zero diameter/thickness for element   94893 . An element
** ERROR 99780 ** Zero diameter/thickness for element   94894 . An element
** ERROR 99780 ** Zero diameter/thickness for element   94895 . An element
** ERROR 99780 ** Zero diameter/thickness for element   94896 . An element
** ERROR 99780 ** Zero diameter/thickness for element   94897 . An element
** ERROR 99780 ** Zero diameter/thickness for element   94898 . An element
** ERROR 99780 ** Zero diameter/thickness for element   94899 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95025 . An element
[ 本帖最后由 cbrmbz75 于 2006-8-11 14:41 编辑 ]
发表于 2006-8-11 14:36:52 | 只看该作者
** ERROR 99780 ** Zero diameter/thickness for element   95026 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95027 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95028 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95029 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95030 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95031 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95032 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95033 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95034 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95035 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95036 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95037 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95038 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95039 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95040 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95041 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95044 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95045 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95046 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95047 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95048 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95049 . An element
[ 本帖最后由 cbrmbz75 于 2006-8-11 14:42 编辑 ]
发表于 2006-8-11 14:37:22 | 只看该作者
** ERROR 99780 ** Zero diameter/thickness for element   95052 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95053 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95055 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95056 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95057 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95058 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95059 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95060 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95061 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95062 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95064 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95065 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95066 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95067 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95069 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95070 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95071 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95073 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95074 . An element
[ 本帖最后由 cbrmbz75 于 2006-8-11 14:44 编辑 ]
发表于 2006-8-11 14:38:05 | 只看该作者
** ERROR 99780 ** Zero diameter/thickness for element   95170 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95171 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95172 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95173 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95174 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95175 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95176 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95177 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95178 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95179 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95180 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95181 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95182 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95183 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95184 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95185 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95186 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95187 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95188 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95189 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95190 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95191 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95192 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95193 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95194 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95195 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95196 . An element
** ERROR 99780 ** Zero diameter/thickness for element   95197 . An element
... finished checking input data
** ERROR 99980 ** Correct the above error and re-run the analysis
** ERROR 99002 ** The following error messages occurred more than 5 times:
                  Message No. Number of occurrences
                   99780         80
[ 本帖最后由 cbrmbz75 于 2006-8-11 14:45 编辑 ]
发表于 2006-8-11 14:47:52 | 只看该作者
6/9--9/9
[ 本帖最后由 cbrmbz75 于 2006-8-11 15:01 编辑 ]
发表于 2006-8-11 14:59:25 | 只看该作者
你的网格厚度属性不对,检查网格厚度,重新给网格赋予厚度属性。
发表于 2006-8-11 15:09:56 | 只看该作者
谢谢版大,我试试看
发表于 2006-8-18 14:52:01 | 只看该作者
网格厚度属性不对~~~
发表于 2006-8-18 15:11:53 | 只看该作者
错误原因见图:
GMT+8, 2026-7-10 22:25 , Processed in 0.074722 second(s), 10 queries , Gzip On, Redis On.
