查看: 16088|回复: 1
What's New for MoldWizard in Unigraphics NX 1.0.2
发表于 2003-3-22 04:51:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1. Ejector pin length recommend
When adding a ejector pin, you just need to select a diameter, then Mold Wizard will recommend a pin length for you after you select a eject pin position.
2. Following PRs are fixed in Mold Wizard NX 1.0.2
PR#
  Short Description
1224786
  Moldwizard database error
1230031
  Hasco_mm Z518 sprue bushing has wrong location for NULL
1236557
  KDA:-MOLDBASE- HASCO_E Type 5+6 K30 does not take care about plate_h
1239302
  Moldwizard 1.0.1 Standard parts Ejector Pin
1242170
  Z46 and Z465 - SHOULDER LENGTH isnt correct
1242192
  Z46 Z465 - HEAD HEIGHT isnt correct
2020847
  200 Option missing in Universal MoldBase "cfg_ej_plt" pull-down menu
4670335
  MoldWizard - can't select dme_interchangeable ejector box in graphic area
4684993
  Moldwizard - failed to update expressions. when loading dme english base
4686186
  MW - Standard part and screw dims not available to edit - Pattern
4687276
  Unsuppressing moldbase components
4690483
  Hasco-E can not be edited using Standard Parts as it should be used
4692931
  Missing Ejector Guide Bushings in DME mold base
4705765
  profile split does not work, but no errors generated to screen
4710209
  Moldwizard- Return Pin Set X and Y dimensions not working
发表于 2003-3-24 08:58:54 | 只看该作者
can you upload!!!
GMT+8, 2026-7-2 14:00 , Processed in 0.069447 second(s), 12 queries , Gzip On, Redis On.
