查看: 22110|回复: 14
[求助] 紧急求助:MOLDFLOW中结果超过材料的许用剪切率问题
发表于 2006-10-11 15:51:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
最近我分析了一个汽车上的副仪表板的产品,用的是PP+20%的碳酸钙,发现在屏幕信息中FILL中显示的摘要中发现最大剪切率超过了材料的最大许用剪切率,这个情况的话,在实际中肯定是不行的,因为材料发生降解了!我想问一下!在MOLDFLOW中除了上述信息中给出提示外,其它地方还会有什么提示,或是显示其危害?我把信息摘录了下 了:
材料数据报告:
制造商                    Ferro
材料编号                      GPP20CS39GY
材料种类                PP
纤维 / 充填物                20% Calcium Carbonate 填充物
Moldflow 材料编号        1052
Moldflow 等级编号         CM1052
Filling phase results summary :
   Maximum injection pressure          (at   2.495 s) =     58.7216 MPa
End of filling phase results summary :
   Time at the end of filling                         =      2.6503 s
   Total weight (part + runners)                      =   1085.4900 g
   Maximum Clamp force - during filling               =    303.8923 tonne
   Recommended ram speed profile (rel):
          % stroke             % speed
            0.0000            16.7004
           10.0000            38.5031
           20.0000            56.9507
           30.0000            80.6993
           40.0000            93.6967
           50.0000           100.0000
           60.0000            95.6350
           70.0000            80.8437
           80.0000            54.4960
           90.0000            37.1491
          100.0000            16.4176
   Melt front is entirely in the cavity at % fill     =      0.0000 %
Filling phase results summary for the part :
   Bulk temperature - maximum          (at   2.506 s) =    239.1300 C
   Bulk temperature - 95th percentile  (at   2.495 s) =    234.4640 C
   Bulk temperature - 5th percentile   (at   2.650 s) =    213.9580 C
   Bulk temperature - minimum          (at   2.650 s) =     73.5270 C
   Wall shear stress - maximum         (at   2.185 s) =      0.3838 MPa
   Wall shear stress - 95th percentile (at   0.116 s) =      0.1708 MPa
   Shear rate - maximum                (at   1.844 s) =  3.4725E+04 1/s
  Shear rate - 95th percentile        (at   0.116 s) =   6074.2798 1/s
End of filling phase results summary for the part :
   Total part weight (excluding runners)              =   1085.4900 g
   Bulk temperature - maximum                         =    237.8060 C
   Bulk temperature - 95th percentile                 =    233.5700 C
   Bulk temperature - 5th percentile                  =    213.9610 C
   Bulk temperature - minimum                         =     73.5270 C
   Bulk temperature - average                         =    222.6170 C
   Bulk temperature - root-mean-square deviation      =     10.9694 C
   Wall shear stress - maximum                        =      0.1983 MPa
   Wall shear stress - 95th percentile                =      0.0894 MPa
   Wall shear stress - average                        =      0.0326 MPa
   Wall shear stress - root-mean-square deviation     =      0.0255 MPa
   Frozen layer fraction - maximum                    =      1.0000
   Frozen layer fraction - 95th percentile            =      0.2312
   Frozen layer fraction - 5th percentile             =      0.0673
   Frozen layer fraction - minimum                    =      0.0000
   Frozen layer fraction - average                    =      0.1683
   Frozen layer fraction - root-mean-square deviation =      0.0752
   Shear rate - maximum                               =  1.3478E+04 1/s
   Shear rate - 95th percentile                       =    479.5600 1/s
   Shear rate - average                               =    105.8480 1/s
   Shear rate - root-mean-square deviation            =    275.1480 1/s
Packing phase results summary :
   Peak pressure - minimum             (at   0.000 s) =      0.0000 MPa
   Clamp force - maximum               (at   4.560 s) =    437.2186 tonne
   Total weight - maximum              (at  12.060 s) =   1173.6900 g
End of packing phase results summary :
   Time at the end of packing                         =     32.6548 s
   Total weight (part + runners)                      =   1170.8200 g
Packing phase results summary for the part :
   Bulk temperature - maximum          (at   2.650 s) =    237.8010 C
   Bulk temperature - 95th percentile  (at   2.650 s) =    233.5710 C
   Bulk temperature - 5th percentile   (at  32.655 s) =     53.7600 C
   Bulk temperature - minimum          (at  26.905 s) =     50.0000 C
   Wall shear stress - maximum         (at   9.060 s) =      4.0098 MPa
   Wall shear stress - 95th percentile (at  12.508 s) =      0.1104 MPa
   Volumetric shrinkage - maximum      (at   2.650 s) =     16.3553 %
   Volumetric shrinkage - 95th %ile    (at   2.650 s) =     13.5879 %
   Volumetric shrinkage - 5th %ile     (at  32.655 s) =      2.0501 %
   Volumetric shrinkage - minimum      (at   6.060 s) =     -0.2425 %
   Total part weight - maximum         (at  12.060 s) =   1173.6900 g
End of packing phase results summary for the part :
   Total part weight (excluding runners)              =   1170.8200 g
   Bulk temperature - maximum                         =     94.5460 C
   Bulk temperature - 95th percentile                 =     65.2840 C
   Bulk temperature - 5th percentile                  =     53.7600 C
   Bulk temperature - minimum                         =     50.0000 C
   Bulk temperature - average                         =     60.3300 C
   Bulk temperature - root-mean-square deviation      =      3.2764 C
   Frozen layer fraction - 95th percentile            =      1.0000
   Frozen layer fraction - 5th percentile             =      1.0000
   Frozen layer fraction - minimum                    =      1.0000
   Frozen layer fraction - average                    =      1.0000
   Frozen layer fraction - root-mean-square deviation =      0.0000
   Volumetric shrinkage - maximum                     =     11.8736 %
   Volumetric shrinkage - 95th percentile             =      7.4253 %
   Volumetric shrinkage - 5th percentile              =      2.0501 %
   Volumetric shrinkage - minimum                     =      0.5023 %
   Volumetric shrinkage - average                     =      4.0689 %
   Volumetric shrinkage - root-mean-square deviation  =      1.5782 %
   Sink index - maximum                               =      0.4774 %
   Sink index - 95th percentile                       = -1.2167E-05 %
   Sink index - minimum                               =     -0.0282 %
   Sink index - root-mean-square deviation            =      0.1175 %
Preparing interface data...
  Preparing PPC file for cooling analysis...
  Preparing LSP file for warpage analysis...
Finished preparing the interface data
收藏收藏1 分享淘帖 赞一下!赞一下!
发表于 2006-10-11 15:58:17 | 只看该作者
个人认为只要不是镜面的产品一般都没有问题。通常针点进胶和潜伏进胶都会在剪切速率及剪切应力上超标。如果你想不超标那加大浇口降低流速就行了。
       版主睡大觉去了哦,我这菜菜鸟出来抛块砖。这个版块冷成这样,关了算了。
发表于 2006-10-11 16:15:46 | 只看该作者
降低流速看看,调整工艺。
不过moldflow计算的shear rate 不是很准。
发表于 2006-10-11 20:39:11 | 只看该作者
我感觉点浇口剪切速率经常都会超,但时间短,位置小,一般是没问题
发表于 2006-10-12 12:21:16 | 只看该作者
是的啊,在窗口中显示又是正常的!
发表于 2006-10-12 12:32:53 | 只看该作者
此产品造成翘曲变形最大因素是体积收缩不均匀,冷却,和分子取向影响较小!请问还有一项“conner effect"怎么理解?是什么意思呢,在这个案例里它对变形也影响不大!
发表于 2006-10-12 12:37:25 | 只看该作者
我想请问,造型收缩不均匀的因素是什么呢?是不是充填不均匀造成的啊!当然PP+CaCo3的收缩是比较大的,设定为1.1%的收缩率!对此问题有没有好的解决措施!
发表于 2006-10-12 12:42:07 | 只看该作者
来个填充时间图(FILL TIME)我觉得略有些流动不太平衡!请大家看一下!来参考参考!
发表于 2006-10-12 12:51:07 | 只看该作者
对了,来张用MF分析的最佳浇口位置图!大家有什么好的建议浇口做在哪里较好(热流道)是不是MF分析的也不准啊!
发表于 2006-10-13 15:14:28 | 只看该作者
我顶一下!
GMT+8, 2026-5-1 11:45 , Processed in 0.162561 second(s), 10 queries , Gzip On, Redis On.
