查看: 16952|回复: 6
[原创] solidwork小技巧接龙
发表于 2006-10-12 15:53:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1,字符插入---参考WORD代码
In SOLIDWORKS, start your note annotation and type in 2122. Then highlight it and key ALT+X. The TM symbol will be there. (Hint: Look at the bottom of the symbol dialog box in Word when selecting the TM symbol on the Symbols tab. It will show its "code". When you enter the sequence and hit ALT+X, it will "cut" the code and replace it with its hexadecimal equivalent. Weird!!
发表于 2006-10-12 15:55:58 | 只看该作者
2,零件镜像
To create a mirrored, derived part:
In an open part document, click a model face or plane about which to mirror the part.
Click Insert, Mirror Part.
A new part window appears.
In the PropertyManager, select one or more items:
Axis. Transfers the axis information.
Plane. Transfers all planes from the original part.
Cosmetic Thread. Transfers cosmetic threads.
Surface. Transfers surfaces.
Click OK .
The mirrored part appears.
发表于 2006-10-12 16:02:07 | 只看该作者
3,用WRAP来做弹簧.
  首先做一个圆柱面
  然后做一个3段线
  在做WRAP
  后扫描
发表于 2006-10-12 17:03:56 | 只看该作者
给别人机会提高,就是给自己提高的动力,请大家积极分享经验.
发表于 2006-10-12 19:31:07 | 只看该作者
难道就没有高手顶一下,多介绍一点
发表于 2006-10-12 22:31:11 | 只看该作者
顶一下,给别人机会提高,就是给自己提高的动力!
发表于 2006-10-13 07:30:06 | 只看该作者
字符插入怎么运用?放在哪里呢?
GMT+8, 2026-7-4 06:49 , Processed in 0.116963 second(s), 10 queries , Gzip On, Redis On.
