查看: 16036|回复: 2
VB.NET FOR UG 二次开发教程
头像被屏蔽
发表于 2006-10-13 13:24:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2006-10-15 11:28:32 | 只看该作者
发表于 2006-10-15 15:11:52 | 只看该作者
How to Build VB examples
1. Open Microsoft Visual Studio .Net 2003.
2. Create new project as :
        1. File->New->Project.
        2. Select Visual Basic Projects, Console Application, Enter
           name as VB_NXOpen_UF_Examples(you can specify name of your choice).
        3. Click on Ok.
3. Remove the AssemblyInfo.vb file from the project.  Highlight it in the Solution Explorer
   and use the 3rd mouse button and pull to Delete it.  You will receive a pop-up
   that says it will be permanently removed. Hit OK.
4. Remove Module1.vb. Follow the same steps followed for removing AssemblyInfo.vb(step 3).
5. Add references of following files :
           1. NXOpen.dll
           2. NXOpenUI.dll
           3. NXOpen.Utilities.dll
           4. NXOpen.UF.dll.
           To do this, right click on "References" under the project in Solution
           Explorer. Pick Add Reference->Browse->Go to %UGII_ROOT_DIR%\out\managed,
           select DLL ( since here there are multiple dll, press CTRL Key and then
           start selecting DLLs).
6. In the Solution Explorer highlight the project name and use the 3rd mouse
  button and drag to Add.  Choose Add Existing Item.  Navigate to and add any
  of the *.vb file. (Please Note each vb file is a example, so add one at a time)
7. Go to Project Menu -> Properties. If you see "Module1" in "Startup Project" push down list,
   select "uf_curve_CreateArc". Click on Ok.
8. Go to Build Menu -> Build Solution or Ctrl + Shift + B or go to Solution Explorer, right
   click on project name and select Build.
How to Run VB Examples
Once you have successfully finished with "How to Build VB examples" steps, it will
create executable called VB_NXOpen_UF_Examples.exe in bin of the project dir.
How to Run VB example in the interactive mode
Here you have to choices : ( follow any one of these)
1. Thru Tools Menu :
        1. Start NX.
        2. Go to Tools Menu -> Journal -> Play.
        3. You will lead to window called "Journal Manager".
        4. Navigate to the location of the Vb file using Browse Button.
        5. Click on Run Button.
2. Thru File Menu :
        1. Start NX.
        2. Go to File Menu -> Execute ->NX Open.
        3. You will lead to window called "Execute User Function".
        4. Navigate to the location of the exe file.  It will be in the <Project Folder>\bin
           directory under the directory named for VB project.
        5. Select .exe filename and Click ok.
GMT+8, 2026-7-6 20:04 , Processed in 0.125773 second(s), 10 queries , Gzip On, Redis On.
