查看: 17130|回复: 1
[求助] 在李军整车模型中添加轮胎和路面文件后,出现下面的警告
发表于 2006-10-26 10:48:04 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请各位看官指点迷津,如何修改才能避免出错,谢谢!
WARNING: Model .model_1 is no longer compatible with the ADAMS/Solver (C++).
.model_1.TIRE_1 is causing the incompatibility because:
   1) Objects of type Tire are not compatible with the
      ADAMS/Solver (C++).
   2) The topology of the model has changed so .model_1.TIRE_1
      is no longer connected in a way that is compatible with the
      ADAMS/Solver (C++).
   3) An attribute of .model_1.TIRE_1 is no longer compatible with
If you intend to use the ADAMS/Solver (C++), then be sure that you
set your preferences so ADAMS/Solver (C++) is the default as follows:
   - From the Settings menu, point to Solver and select either
     Solver Executable or Preferences, depending on the product
     you are using.
   - Press F1 in the dialog box that appears to learn more.
If you do not want to use the ADAMS/Solver (C++), you must change
your model to eliminate the incompatibilty.  See the online help
for the object listed for more information.
发表于 2007-12-10 14:44:19 | 只看该作者
GMT+8, 2026-8-2 19:57 , Processed in 0.054503 second(s), 13 queries , Gzip On, Redis On.
