查看: 18048|回复: 1
安装Teamcenter Engineering常见问题及解决方法
发表于 2006-11-25 22:43:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
SYMPTOM/PROBLEM:
ORA-12638 Credentail retrieval failed when install Oracle
SOLUTION:
Re-logon as LOCAL administrator, not domain member
SYMPTOM/PROBLEM:
ORA-01031 Insufficient privilegeswhen install tceng instance
SOLUTION:
Under DOS Prompt, Enter sqlplus /nolog, Oracle Sql*Plus starts.
Under Sql*Plus Prompt, Enter
>connect sys/sys_password as sysdba;
>grant connect, resource, dba to infodba identified by infodba;
SYMPTOM/PROBLEM:
Unable to connect to the databasewhen install TcEng
SOLUTION:
If no other oracle applications run on this machine, remove NLS_LANG from registry,
HKEY_LOCAL_MACHINE\SOFTWARE\ORACLE\NLS_LANG
发表于 2009-12-30 00:57:27 | 只看该作者
受教了....
GMT+8, 2026-7-8 17:23 , Processed in 0.051621 second(s), 11 queries , Gzip On, Redis On.
