查看: 16036|回复: 0
[求助] 这样的警告是怎么意思?
发表于 2006-12-15 08:13:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
分析过程中出现这样的警告,是怎么意思?
** WARNING 1714020 ** The CRYSTALLINITY term in the PARALLEL strain model had
                      values which were too HIGH in 100.0 % of part elements
                      (volume fraction). The upper limit has been used for
                      these elements.
** WARNING 1714060 ** The ORIENTATION term in the PARALLEL strain model had
                      values which were too HIGH in  40.4 % of part elements
                      these elements.
** WARNING 1714030 ** The CRYSTALLINITY term in the PERPENDICULAR strain
                      model had values which were too HIGH in 100.0 % of
                      part elements (volume fraction). The upper limit has
                      been used for these elements.
** WARNING 1714070 ** The ORIENTATION term in the PERPENDICULAR strain model
                      had values which were too HIGH in  32.5 % of part
                      elements (volume fraction). The upper limit has been
** WARNING 1714140 ** The MOLD RESTRAINT term in the PARALLEL strain model
                      had values which were too LOW in 100.0 % of part
                      elements (volume fraction). The lower limit has been
** WARNING 1714160 ** The ORIENTATION term in the PARALLEL strain model had
                      values which were too LOW in   0.2 % of part elements
                      (volume fraction). The lower limit has been used for
                      these elements.
** WARNING 1714150 ** The MOLD RESTRAINT term in the PERPENDICULAR strain
                      model had values which were too LOW in 100.0 % of part
** WARNING 1714170 ** The ORIENTATION term in the PERPENDICULAR strain model
                      had values which were too LOW in   0.1 % of part
GMT+8, 2026-7-25 08:50 , Processed in 0.039455 second(s), 10 queries , Gzip On, Redis On.
