查看: 21593|回复: 24
今天受刺激了
发表于 2006-12-18 19:52:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Technical data
Working ranges
  X-axis  3 000 – 10 000 mm
  Y-axis  2 000 – 3 000 mm
  Z-axis  1 000 – 2 000 mm
Work-table size
  Length  3 000 – 10 000 mm
  Width  2 000 – 3 000 mm
  Height  370 mm
  Max. work-table loading  30 000 kg/m2
  T-slots (longitudinal)  18 H12 (optional 18 H8)
  Distance T-slots  250 mm
Feed drives
  Feed linear axes
Linear mot.  0 – 20 000 mm/min.
0 - 40 000 mm/min.
  Rotation Speed of rotary axes  50°/s
  Acceleration on linear axes  2.5 -4.5 m/s2
Accuracy (axis)
to VDI/DGQ 3441
  Positioning accuracy (X)  0.030 mm
  Positioning accuracy (Y, Z)  0.020 mm
  Repeatability (X)  0.015 mm
  Repeatability (Y, Z)  0.010 mm
  Res. of measuring systems
(A, C)  0.0001°
  Positioning accuracy (A, C)  15" = 0.004°
  Repeatability (A, C)  10" = 0.002°
Milling head AC 3 (1)
  Max. spindle power (2)  28 kW
  Max. spindle speed  24 000 rpm
  Max. torque  89 Nm
  Constant power range  3 000 - 18 000 rpm
  Tool holder  HSK 63 A
  Torque on A and C-axes (3)  1 500 Nm
  Working range A-axis  ± 110°
  Working range C-axis  >± 300° (opt. ±360°)
  Distance swivel axis to
spindle nose  300 mm
  Tool clamping  spring clamp
  Tool unclamping  hydraulic
  Max. spindle power (2)  40 kW
  Max. torque  95.5 Nm
  Constant power range  4 000 - 20 700 rpm
spindle nose  300 mm
Milling head AC 2S (1)
  Max. spindle power (2)  20 kW
  Max. spindle speed  28 000 rpm
  Max. torque  63.7 Nm
  Torque on A and C-axes (3)  1 000 Nm
  Working range A-axis  + 95°/- 125°
  Working range C-axis  ± 275°
spindle nose  300 mm
发表于 2006-12-18 19:55:53 | 只看该作者
发表于 2006-12-18 20:04:45 | 只看该作者
发表于 2006-12-18 21:27:24 | 只看该作者
发表于 2006-12-18 21:42:43 | 只看该作者
发表于 2006-12-19 14:18:04 | 只看该作者
发表于 2006-12-19 21:14:50 | 只看该作者
发表于 2006-12-19 21:19:13 | 只看该作者
发表于 2006-12-20 16:03:43 | 只看该作者
发表于 2006-12-20 19:02:57 | 只看该作者
GMT+8, 2026-8-16 07:40 , Processed in 0.055978 second(s), 11 queries , Gzip On, Redis On.
