查看: 19247|回复: 2
[求助] 【请教】adams函数bistop的参数含义
发表于 2007-1-24 12:06:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
bistop(x,x',x1,x2,k,e,cmax,d)
x:计算力的距离或角度变量
x':距离或角度变量的一阶导数,也就是线速度或角速度
x1:x值的上限值
x2:x值的下限值
K:借助表面的刚度系数
e:描述力变化的系数,对于一个硬弹簧e>1,对于软性弹簧e在0~1之间
cmax :最大阻尼系数
d:
这个函数的最后一个参数什么意思呢?我把函数的英文解释贴出来麻烦大家给看看什么意思呢
x The distance variable you want to use to compute the force. For example, if you want to use the x displacement of Marker 0201 with respect to 0301, then x is DX(0201,0301,0301).
The time derivative of x to BISTOP. For example, if x is DX(0201,0301,301) then is VX(0201,0301,0301,0301).
x1 The lower bound of x. If x is less than x1 ADAMS/Solver (C++) calculates a positive value for the force. The value of x1 must be less than the value of x2.
x2 The upper bound of x. If x is greater than x2 ADAMS/Solver (C++) calculates a negative value for the force. The value of x2 must be greater than the value of x1.
k A non-negative value that specifies the stiffness of the boundary surface interaction.
e A positive value that specifies the exponent of the force deformation characteristic. For a stiffening spring characteristic, e > 1.0. For a softening spring characteristic, 0 < e < 1.0.
cmax A non-negative variable that specifies the maximum damping coefficient.
d A positive real variable that specifies the penetration at which the full damping coefficient is applied.
发表于 2007-3-4 10:20:08 | 只看该作者
发表于 2007-5-10 15:36:12 | 只看该作者
GMT+8, 2026-8-3 01:58 , Processed in 0.054318 second(s), 13 queries , Gzip On, Redis On.
