查看: 17917|回复: 4
[原创] I-DEAS 字体
发表于 2007-2-4 18:41:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
I-DEAS Wireframe Fonts
I-DEAS字体线架构
There are two types of fonts available: standard drafting fonts (available on both Unix and Microsoft® Windows), and True Type fonts (available on MS Windows only). The standard fonts include: Simplex, Din, Military, ISO, Lightline, IGES 100, IGES 1002, IGES 1003, and Century.
有2种可以得到的字体:标准的字体<unix和windows>和True Type字体.标准字体包括Simplex, Din, Military, ISO, Lightline, IGES 100, IGES 1002, IGES 1003, and Century.
The standard fonts can be used to create toolpaths for NC machining, using manual milling.
标准字体可以用来创建NC刀路。
The True Type fonts include all the fonts installed on your MS Windows computer. They typically trace around the border of each letter, which makes them suitable for extruding or embossing to create 3D text.
The True Type字体包括安装在的MS Windows机器上.他们常常跟着每一个字母的边界走,使他们能够用来拉伸或者embossing 3维的文字.
True Type fonts range widely in style and quality, and some may not produce the results you expect. For this reason, we have made True Type fonts an option on MS Windows machines, rather than the default. To activate them, you need to create the following entry in your param file:
UseNTTrueTypeFonts: 1
To turn them off, change the 1 to 0.
True Type字体广泛地用于字体设计上, 而且会得到一些不您象想象地结果.由于这个原因,我们在MS Windows机器上提供这个选项,,而不是缺省地就有. 如果想激活他们.您需要在您地参数文件上加如下地操作:
要关掉地话,就把1变成0.
参数文件在以下路径可以找到:X(安装路径):\Team\Master\username(使用者)_param用记事本打开在最后加上上面一行就可以了。
效果看附件
[ 本帖最后由 ken.ye 于 2007-2-4 18:55 编辑 ]
发表于 2007-2-5 09:52:05 | 只看该作者
发表于 2007-2-6 11:57:42 | 只看该作者
发表于 2007-2-6 14:38:13 | 只看该作者
发表于 2007-6-6 08:28:18 | 只看该作者
GMT+8, 2026-8-3 19:45 , Processed in 0.127472 second(s), 13 queries , Gzip On, Redis On.
