查看: 17386|回复: 10
【分享】在Drawing中和SnapLine来对齐尺寸等
发表于 2002-1-26 23:48:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Drawing Snap Lines
Here is a little tip to speed up drawing cleaning up.  It is a snap line.  A snap line is a line that shows up on the screen but not on the printed drawing.  It allows you to line up balloons, notes, or any draft entities that can be moved using the normal move command.  When an entity is moved near the snap line, it "snaps" to it.  The moved entity will change colors from red to violet when it is attached to the snap line.  Using the snap line, balloons can be lined up in a perfect straight line.  No more eyeballing to try to get them straight.  Figure 1 shows several balloons lined up on two snap lines.
Snap lines can be assigned to a view, a datum plane or any geometry edge and then move with that view.  A snap line can be moved by the normal move command, or it can be moved using Modify > Snap Line.  The great thing is that when the snap line is moved, all the entities aligned to it move with it.
To create a snap line pick Create > Snap Line and follow the prompts.  The units for placement are in millimeters no matter what the drawing units are so you will need to pick an offset value like 10 or 50.  Play around with different attachments.  Now it is easy to align draft entities and have them all move together.
发表于 2006-1-14 23:43:07 | 只看该作者
发表于 2006-1-15 08:37:57 | 只看该作者
发表于 2006-1-15 08:43:31 | 只看该作者
发表于 2006-1-15 08:48:42 | 只看该作者
发表于 2006-1-15 08:49:05 | 只看该作者
发表于 2006-1-15 09:25:29 | 只看该作者
发表于 2006-1-15 10:03:38 | 只看该作者
发表于 2006-1-15 10:09:03 | 只看该作者
发表于 2006-1-15 10:09:47 | 只看该作者
GMT+8, 2026-8-18 10:14 , Processed in 0.066139 second(s), 12 queries , Gzip On, Redis On.
