查看: 16467|回复: 2
[求助] 气辅,分析结果关于注气在速度压力转换之前的问题
发表于 2007-5-8 15:51:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我设置速度压力控制转换于5毫米的地方,设置气体延迟为1秒,其它的就不细说了。
看分析输出似乎正常,但总是有一行提示:
** NOTE ** Try to inject gas before velocity/pressure switch-over
这是为什么呢,速度压力控制转换不是早就已经完成了吗?
下面是我的分析结果输出:
Filling Analysis
Packing Analysis
Residual Stress Analysis
Gas-assisted Injection Molding Analysis
analysis is beginning ....
  Filling phase:                               Status: V  = Velocity control
                                                       P  = Pressure control
                                                       V/P= Velocity/pressure switch-over
                                                       G  = Gas injection
|  Time  | Volume|  Pressure   |  Clamp  |Flow rate|  Ram    |   Gas Injection   |Status |
|        |       |             |  force  |         |position |Inlet#|  Pressure  |       |
|  (s)   |  (%)  |    (MPa)    | (tonne) |(cm^3/s) |  (mm)   |      |   (MPa)    |       |
|   0.69 | 96.66 |       20.35 |       6.20 |   34.33 |   5.00 |V/P by ram pos.|
|   0.70 | 97.53 |       16.28 |     5.12|      |            |         |   P   |
|   0.73 | 98.77 |       16.28 |     5.14|      |            |         |   P   |
|   0.76 | 99.96 |       16.28 |     5.46|      |            |         |   P   |
|   0.76 |100.00 |       16.28 |     5.47|         |      |            |         | Filled|
  Execution time in Filling Phase =       172.99 s
  Packing phase:
|  Time  |Packing|  Pressure   |  Clamp  |   Gas Injection   |      Status     |
|        |       |             |  force  |Inlet#|  Pressure  |                 |
|  (s)   |  (%)  |    (MPa)    | (tonne) |      |   (MPa)    |                 |
| ** NOTE ** Try to inject gas before velocity/pressure switch-over            |
| End of polymer injection/packing, polymer injection location is now closed.  |
|   1.69 |       |             |         |   1  |            |   Gas started   |
|   1.69 |  3.13 |             |     5.15|   1  |        4.00|        G        |
| WARNING: Possible backflow at gas entrance no.   1                            |
|   3.01 |  7.51 |             |     1.18|   1  |        4.00|        G        |
|   4.51 | 12.52 |             |     0.95|   1  |        4.00|        G        |
|   6.01 | 17.53 |             |     0.85|   1  |        4.00|        G        |
|   7.51 | 22.54 |             |     0.76|   1  |        4.00|        G        |
|   9.01 | 27.55 |             |     0.64|   1  |        4.00|        G        |
|  10.51 | 32.56 |             |     0.53|   1  |        4.00|        G        |
|  10.71 | 33.23 |             |     0.51|   1  |        4.00|        G        |
|  10.71 |       |             |         |      |            |Pressure released|
|  11.69 |       |             |         |   1  |            |   Gas stopped   |
|  11.99 | 37.54 |        0.00 |     0.28|      |            |        P        |
|  13.49 | 42.55 |        0.00 |     0.00|      |            |        P        |
|  14.99 | 47.56 |        0.00 |     0.00|      |            |        P        |
|  16.49 | 52.57 |        0.00 |     0.00|      |            |        P        |
|  17.99 | 57.58 |        0.00 |     0.00|      |            |        P        |
|  19.49 | 62.59 |        0.00 |     0.00|      |            |        P        |
|  20.99 | 67.60 |        0.00 |     0.00|      |            |        P        |
|  22.49 | 72.61 |        0.00 |     0.00|      |            |        P        |
|  23.99 | 77.62 |        0.00 |     0.00|      |            |        P        |
|  25.49 | 82.63 |        0.00 |     0.00|      |            |        P        |
|  26.99 | 87.64 |        0.00 |     0.00|      |            |        P        |
|  28.49 | 92.65 |        0.00 |     0.00|      |            |        P        |
|  29.99 | 97.67 |        0.00 |     0.00|      |            |        P        |
|  30.69 |100.00 |        0.00 |     0.00|      |            |        P        |
发表于 2007-5-8 16:40:45 | 只看该作者
设置气体在0.5秒进气试试。
你的CASE 在0.69S 已经转换了。
发表于 2007-5-9 10:04:36 | 只看该作者
对呀,V/P转换是在0.69秒,然后气体开始在1.69秒,
气体注射不是已经在V/P转换之后了吗?
GMT+8, 2026-5-1 07:36 , Processed in 0.159904 second(s), 10 queries , Gzip On, Redis On.
