返回列表 发新帖
UG/KF中trim_body命令怎么用?帮我看看这个谢谢了
发表于 2007-10-14 00:53:13 | 只看该作者
对不起,最近有点事,没能给你解答问题。我现在想要的就是你将这3个文件串起来的、相互调用的那个dfa文件,你在qq上发给过我,但不全。你提到不知道怎么用ug_trim_body这个命令,但是你上面提到的程序中没有ug_trim_body这个命令。其实它的用法很简单,你可以参考清华的那本kf的书,也可以看帮助文档,而且就我看你的语法是没错的。可能就是那个用到ug_trim_body的dfa文件在定义大类、子类的时候有问题(注意:调用的时候也分大类子类依顺序写),你可以查一下。
发表于 2007-10-14 21:16:43 | 只看该作者
程序改成如下,应该就可以了。因为没用ug调试,如若不行,但思路应该没问题。
#! NX/KF 3.0
Defclass:  rengou (ug_base_part);
(Number Parameter Modifiable) r:      15;
(Number Parameter Modifiable) t:      1.875;
(Number Parameter Modifiable) r1: (2*r:*t:*sin(belta1-r:*r:-t:*t/(2*t:-2*r:*sin(belta1);
(Number Parameter Modifiable) r3:     0.9375;
(Number Parameter Modifiable) r2: ((r:-r3*(r:-r3-(r3:-t*(r3:-t)/(2*(r3:-t+2*sin(belta2*(r:-r3)-t:;
(Number Parameter Modifiable) belta1: 37.5;
(Number Parameter Modifiable) belta2: 37.5;
(Number Parameter Modifiable) yo2:    ((r:-r3*(r:-r3-(r3:-t*(r3:-t)/(2*(r3:-t+2*sin(belta2:)*(r:-r3:));
(Number Parameter Modifiable) belta:  30;
(Number Parameter Modifiable) L1:     84;
(Frame Parameter Modifiable) RF: FrameXY(Point(0,0,0),Vector(1,0,0),Vector(0,1,0));
(child) arc1:
   class,            ug_arc;
   center,           Point(0, t: + r1:, 0);
   start_angle,      270;
   end_angle,        270 + arccos((r1:*r1:+(r1:+t:)*(r1:+t:)-r:*r:)/(2*r1:*(r1:+t:)));
   radius,           r1:;
   ReferenceFrame,   RF:;
(child)  arc2:
   class,              ug_arc;
   center,             Point(0, yo2:, 0);
   start_angle,        270-arcsin(cos(belta2:)*(r:-r3:)/(r2:+r3:));
   end_angle,          270;
   radius,             r2:;
(child)   arc3:
    class,              ug_arc;
    center,             Point(-(r:-r3:)*cos(belta2:), (r:-r3:)*sin(belta2:), 0);
    start_angle,        arcsin((yo2:-(r:-r3:)*sin(belta2:))/(r2:+r3:));
    end_angle,          180-belta2:;
    radius,             r3:;
(child)    arc4:
    class,              ug_arc;
    center,             Point(0, -t: - r1:, 0);
    start_angle,        90;
    end_angle,          90 + arccos((r1:*r1:+(r1:+t:)*(r1:+t:)-r:*r:)/(2*r1:*(r1:+t:)));
    radius,             r1:;
(child)     arc5:
    class,              ug_arc;
    center,             Point(0, -yo2:, 0);
    start_angle,        90-arcsin(cos(belta2:)*(r:-r3:)/(r2:+r3:));
    end_angle,          90;
    radius,             r2:;
(child)      arc6:
    class,              ug_arc;
    center,             Point((r:-r3:)*cos(belta2:), -(r:-r3:)*sin(belta2:), 0);
    start_angle,        180 + arcsin((yo2:-(r:-r3:)*sin(belta2:))/(r2:+r3:));
    end_angle,          360-belta2:;
    radius,             r3:;
(child)       arc7:
    class,              ug_arc;
    center,             Point(0,0,0);
    start_angle,        -belta2:;
    end_angle,          belta1:;
    radius,             r:;
(child)       arc8:
    class,              ug_arc;
    start_angle,        180-belta2:;
    end_angle,          180+belta1:;
    radius,             r:;
(child)       line0:
    class,              ug_line;
    start_point,        Point(0,0,0);
    end_point,          Point(0,0,L1:);
(child)       spline0:
      class,            ug_spline_cntl;
      degree,           3;
      periodic?,        false;
      Points,           {{Point(-15,0,0)},
                         {Point(-15,-1.96349540849362,3.39914970985392)},
                         {Point(-14.2188846573523,-5.88965486689402,10.1974491295618)},
                         {Point(-10.8827676956358,-10.8827676956358,20.3948982591236)},
                         {Point(-5.88965486689402,-14.2188846573523,30.5923473886853)},
                         {Point(-4.44089209850063e-016,-15.3905576713239,40.7897965182471)},
                         {Point(5.88965486689402,-14.2188846573523,50.9872456478089)},
                         {Point(10.8827676956357,-10.8827676956358,61.1846947773706)},
                         {Point(14.2188846573522,-5.88965486689402,71.3821439069324)},
                         {Point(15.0927004876722,-1.49724026278194,78.9872456478089)},
                         {Point(14.9779971536968,0.931956052365471,83.1931976788314)},
                         {Point(14.9343901688416,1.39593601201134,84)}};
(Child) swept:
     Class,              ug_swept;
     Guide,              {{Forward,line0:},{Forward,spline0:}};
     Section,            {{Forward,arc8:,arc4:,arc5:,arc6:,arc7:,arc1:,arc2:,arc3:}};
     Alignment,          Parameter;
     Interpolation,      None;
     Tolerances,         {0,0,0};
(Child) trim_zuanti:{
Class, zuanjian;
(Child) tdtr1:
   Class,              ug_trim_body;
   Target,             {swept:};
   Trimming_Geometries,{trim_zuanti:revolved1:};
   Reverse?, False;
(Child) tdtr2:
   Target,             {tdtr1:};
   Trimming_Geometries,{trim_zuanti:revolved2:};
   Reverse?, False;
   EduControl,         Continue;
钻尖的程序:
#! NX/KF 3.0
Defclass: zuanjian (ug_base_part);
(Number Parameter Modifiable) cy:     t:;
(Number Parameter Modifiable) cx:     50;
(Number Parameter Modifiable) phi:    59;
(Number Parameter Modifiable) Theta:  30;
(Number Parameter Modifiable) cz1:    cx:*tan(90-phi;
(Number Parameter Modifiable) cz2:    cx:*tan(90-Theta;
(Number Parameter Modifiable) angle_start: -70;
(Number Parameter Modifiable) angle_end: 60;
(child) line1:
  class,               ug_line;
  start_point,         Point(cx:,cy:,cz1;
  end_point,           Point(-cx:,cy:,-cz1;
  ReferenceFrame,      FrameXY(Point(0,0,L1,Vector(1,0,0),vector(0,1,0));
(child) line2:
  class,               ug_line;
  start_point,         line1:start_point:;
  end_point,           point(-cx:,cy:,-cz2:);
  ReferenceFrame,      FrameXY(Point(0,0,L1:),Vector(1,0,0),vector(0,1,0));
(child) revolved1:
  class,               ug_revolved;
  Start_Limit,         angle_start:;
  End_Limit,           angle_end:;
  Thru_Point,          Point(cx:,cy:,cz1:);
  Direction,           vector(cx:,cy:,cz1:)-vector(-cx:,cy:,-cz2:);
  Profile,             {line1:};
(child) line3:
  class,               ug_line;
  start_point,         Point(-cx:,-cy:,cz1:);
  end_point,           Point(cx:,-cy:,-cz1:);
(child) line4:
  class,               ug_line;
  start_point,         line3:start_point:;
  end_point,           point(cx:,-cy:,-cz2:);
(child) revolved2:
  class,               ug_revolved;
  Thru_Point,          Point(-cx:,-cy:,cz1:);
  Direction,           vector(-cx:,-cy:,cz1:)-vector(cx:,-cy:,-cz2:);
  Profile,             {line3:};
发表于 2007-11-15 14:51:04 | 只看该作者
谢谢魏师兄了 我也好久没看贴了 谢谢了
GMT+8, 2026-7-6 15:28 , Processed in 0.050209 second(s), 10 queries , Gzip On, Redis On.
