查看: 16300|回复: 3
Cam-yp VB.net 和 grip接口
发表于 2007-12-1 08:08:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
VB.net
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Imports NXOpen.UI
Imports NXOpen.Utilities
Module call_grip_from_vb_and_print_args
  Dim s As Session = Session.GetSession()
  Dim ui As UI = GetUI()
Sub Main()
Try
    Dim num1 As Double = 2.0
    Dim num2 As Double = 55.2
    Dim text1 As String = "Otto"
    Dim text2 As String = "Karl"
    Dim inputArgs(3) As Object
    Dim gripObj() As Object
    inputArgs(0) = num1
    inputArgs(1) = num2
    inputArgs(2) = text1
    inputArgs(3) = text2
    ui.LockAccess()
    Dim grip_executable As String = "c:\print_api_args.grx"
    gripObj = s.ExecuteGrip(grip_executable, inputArgs)
    ui.UnlockAccess()
Catch ex As Exception
    s.ListingWindow.Open()
    s.ListingWindow.WriteLine("Error: ")
    s.ListingWindow.WriteLine(ex.GetBaseException.ToString())
End Try
End Sub
  Public Function GetUnloadOption(ByVal dummy As String) As Integer
      Return Session.LibraryUnloadOption.Immediately
  End Function
End Module
'$$ GRIP Source called by VB.NET
'$$ Please remove the first character
'$$ in each line to compile!
'$$ Declarations.
'    number / zahl1, zahl2
'    entity / object
'    string / text1(132), text2(132)
'$$ Register and initialize the argument list
'    ufargs / zahl1, zahl2, text1, text2
'$$ Print the arguments
'    PRINT/ 'Argument1 = ' + FSTR(zahl1)
'    PRINT/ 'Argument2 = ' + FSTR(zahl2)
'    PRINT/ 'Argument3 = ' + text1
'    PRINT/ 'Argument4 = ' + text2
'$$ Return control to the VB program.
'    halt: halt
发表于 2007-12-1 08:38:49 | 只看该作者
谢谢,不过我现在暂时不打算用.NET开发
VB.NET开发的程序不能在网络上运行,不知道为什么?
在本机上运行是没问题的
发表于 2007-12-1 09:06:57 | 只看该作者
谢谢。。。
发表于 2007-12-8 19:37:08 | 只看该作者
找寻很久,在这里撞到了
谢谢
GMT+8, 2026-7-6 14:27 , Processed in 0.101971 second(s), 11 queries , Gzip On, Redis On.
