查看: 25195|回复: 18
[推荐] T-Splines 1.2 for Rhino
 关闭 [复制链接]
发表于 2008-2-29 08:55:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
T-Splines 1.2 for Rhino boasts several improvements: additions to the toolbar, polish items, bugfixes, and new tutorials.
Paid users have received a direct download link and this release is now the current version at our web store for free trials and purchases.
New Toolbar items:
The Rhino MeshBox command, a common starting point for T-Splines geometry, is now included in the T-Splines toolbar.
T-Splines now loads the full T-Splines toolbar when the plugin is installed. Previously just the container was loaded, which was confusing for some new users. The container is still accessible in the toolbar options.
Two commonly-used scripts from the jb Toolbars (Extrude Cage From Existing Curves and Flatten Control Points) were implemented and included in the T-Splines toolbar as tsScriptExtrudeControlPolygon and tsScriptFlattenPoints. Thanks, Jonah Barnett!
New command tsConvertToRhinosurf. This replaces Explode and DivideAlongCreases as the recommended way to convert to NURBS. It boasts two major improvements: first, it works on a single T-Splines surfaces (without T-Points or star points), and second, it strips away all T-Splines information from the surface, which fixes a number of reported bugs.
Polish:
tsManip now uses the Rhino selection pop up box for selecting objects.
TsManip observes Osnap options.
tsExtrude user interface is much cleaner--now, selected faces for extrusion are shaded in a solid color, and can be deselected by CTRL+clicking on the face.
The T-Splines surface now updates in real time when dragging control points in Shaded Viewport.
Several command line prompts were modified for clarity.
tsCrease selection interface is cleaner.
Activating licenses using tsActivateLicense is now more user friendly. A crasher associated with installing full licenses on top of beta licenses has been fixed, and the command line messages are more clear.
Error messages have been rewritten for clarity.
Isocurve display can now be turned off and on for each T-Spline, like with native Rhino objects.
Installer now remembers previous installation directory.
Bug fixes:
Infinite loop associated with the tsSkin chord length option has been fixed.
tsMerge crasher fixed.
tsSplitCurves no longer goes into an infinite loop when tolerance = 0.
tsSkin: creasing option crash has been fixed.
tsControlPolygonToSrf infinite loop has been fixed.
T-Splines no longer claims the F3 key.
T-Splines used to not interact reliably with Rhino's Flow command. This has now been fixed and there is no longer a problem.
tsControlPolygonToSrf and tsSkin used to not quit when another command was entered. This is now fixed.
T-Splines licensing experienced some crashing on XP 64 bit machines which is now fixed.
tsSkin: ESC can now be used to cancel out of the command.
Tutorials:
New kayak and rubber duck tutorials were prepared especially for the release of 1.2.
发表于 2008-2-29 09:00:52 | 只看该作者
,由于限制,附件分成12个
发表于 2008-2-29 09:02:30 | 只看该作者
还有呢!!!
3-4
发表于 2008-2-29 09:03:21 | 只看该作者
5-6
gfdg
发表于 2008-2-29 09:04:09 | 只看该作者
7-8
gfg
发表于 2008-2-29 09:07:27 | 只看该作者
9-10
ghj
发表于 2008-2-29 09:08:58 | 只看该作者
11-12
jgh
发表于 2008-3-2 17:23:23 | 只看该作者
ddddddddd
发表于 2008-3-23 12:46:01 | 只看该作者
去死吧。下不了
发表于 2008-5-2 01:58:26 | 只看该作者
能下的谁讲不能下啊,我都下了,要一个一个的点才好下,一下子一起下有点难度
GMT+8, 2026-7-13 12:31 , Processed in 0.144426 second(s), 12 queries , Gzip On, Redis On.
