查看: 16145|回复: 0
Solidworks TV
发表于 2008-3-16 05:59:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Solidworks TV
Categories
https://solidworkstv.blogspot.com/2008/03/categories.html
AutoCAD to SOLIDWORKS
AutoCAD Files (Unit)
169-Moving from AutoCAD
170-Import Options
171-DWGeditor
172-Maintaining AutoCAD Files
173-Communicate with eDrawings
174-Add to PDMWorks Workgroup Vault
175-DWGgateway
176-Accessing AutoCAD Data
2D to 3D Conversion
177-Import DWG as a Part Sketch
178-Editing Imported Data
179-Extracting Sketches
180-Align Sketches
181-Extruding in 2D to 3D
182-Multiple Profiles
183-Cutting in 2D to 3D
184-Create Sketch from Selections
185-Completing a Model
186-Defining Sketches
187-Defining Features
188-Removing Construction Geometry
189-2D to 3D Conversion
190-Import DXF as a Part Sketch
191-Removing Unneeded Data
192-Creating Profiles
193-Check Sketch for Feature
194-Revolving in 2D to 3D
195-Combined Technique
196-DXF Conversion
197-Copy-Paste from DWGeditor
198-Convert to Solid Model
199-Generate Features
200-Using the DWGeditor
AutoCAD Data & Drawings (Unit)
201-AutoCAD Drawing
202-Convert Drawing
203-Accessing AutoCAD Data
204-Add Intelligence
205-Sketch from Drawing
206-Replace Hatching
207-Edit Block
208-Reuse Block Data
209-Paper Space Drawing
210-Resolving Scale Problems
211-Embed Drawing
212-Edit Embedded Drawing
213-Batch Print Drawings
214-Import Drawing
Models & Layouts Introduction
215-Exporting 3D from AutoCAD
216-Importing 3D from AutoCAD
217-Feature Recognition
218-Import Layout Sketch
219-Mate Components
220-Export/Import Model
Sketch
53-Bend Allowance
54-Applying K-Factor
55-Bend Allowance /Deduction
56-Bend Table
57-Gauge Table
58-Creating Base Flange
59-Edge Flange
60-Trim Side Bends-Offset
61-Auto Relief
62-Custom Relief
63-Miter Flange
64-Hem Tool
65-Skeched Bend
66-Closed Corner
67-Jog
68-Break Corner/Corner Trim
69-Break Flat Pattern
70-Tab
71-Lofted Bend
72-Extruded Cut
73-Simple Hole
74-Unfold-Fold
75-Flattened State
76-Using The Design Library
77-Creating a Library Feature
78-Creating a Forming Tool
79-Using a Forming Tool
80-Forming Tool Comand
81-Inserd Bends
82-Vent
83-Fill Pattern
GMT+8, 2026-8-19 23:55 , Processed in 0.087027 second(s), 12 queries , Gzip On, Redis On.
