查看: 18702|回复: 4
[求助] proe二次开发遇到问题!!!
发表于 2008-5-4 16:56:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我是新手,还没入门,在练习的时候遇到了一个问题:
--------------------Configuration: hello - Win32 Debug--------------------
Compiling...
hello.cpp
D:\test\hello\hello.cpp(93) : error C2065: 'ProStringToWstring' : undeclared identifier
Error executing cl.exe.
hello.dll - 1 error(s), 0 warning(s)
我的程序也很简单:
// hello.cpp : Defines the initialization routines for the DLL.
#include "stdafx.h"
#include "hello.h"
#include "ProToolkit.h"
#include "ProGraphics.h"
#ifdef _DEBUG
#define new DEBUG_NEW
#undef THIS_FILE
static char THIS_FILE[] = __FILE__;
#endif
// Note!
//  If this DLL is dynamically linked against the MFC
//  DLLs, any functions exported from this DLL which
//  call into MFC must have the AFX_MANAGE_STATE macro
//  added at the very beginning of the function.
//  For example:
//  extern "C" BOOL PASCAL EXPORT ExportedFunction()
//   AFX_MANAGE_STATE(AfxGetStaticModuleState());
//   // normal function body here
//  It is very important that this macro appear in each
//  function, prior to any calls into MFC.  This means that
//  it must appear as the first statement within the
//  function, even before any object variable declarations
//  as their constructors may generate calls into the MFC
//  DLL.
//  Please see MFC Technical Notes 33 and 58 for additional
//  details.
// CHelloApp
BEGIN_MESSAGE_MAP(CHelloApp, CWinApp)
//{{AFX_MSG_MAP(CHelloApp)
  // NOTE - the ClassWizard will add and remove mapping macros here.
  //    DO NOT EDIT what you see in these blocks of generated code!
//}}AFX_MSG_MAP
END_MESSAGE_MAP()
// CHelloApp construction
CHelloApp::CHelloApp()
// TODO: add construction code here,
// Place all significant initialization in InitInstance
// The one and only CHelloApp object
CHelloApp theApp;
/*  函数:int user_initialize  */
/*  功能:用户初始化函数  */
int user_initialize(int argc, char *argv[])
//函数声明
int hello_function();
//调用函数hello_function
hello_function();
return (0);
/*  函数:user_terminate  */
/*  功能:用户结束中断函数  */
void user_terminate()
printf("Pro/Toolkit application terminated successfully\n");
return ;
/*  函数:hello_function  */
/*  功能:显示出"Hello World"欢迎信息  */
wchar_t wtext[64];
double pt[3];
pt[0] = 150.0;
pt[1] = 375.0;
/*设置变量wtext内容为"Hello World" */
ProStringToWstring(wtext, "Hello World");
/* 显示出"Hello World"信息 */
ProGraphicsTextDisplay(pt, wtext);
return (0);
请大家赐教!
发表于 2008-5-5 09:59:53 | 只看该作者
頭文件未包含
发表于 2008-5-5 23:57:40 | 只看该作者
发表于 2008-5-6 18:54:04 | 只看该作者
回复 3楼 破衣哥 的帖子
发表于 2008-5-15 10:08:53 | 只看该作者
GMT+8, 2026-8-3 14:40 , Processed in 0.097600 second(s), 13 queries , Gzip On, Redis On.
