查看: 16356|回复: 0
[讨论] 请教
发表于 2008-5-13 18:07:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
请教遇到这个问题,该如何处理,谢谢
ERROR:      ***** ADAMS MEMORY OVERFLOW *****
   A larger MD array is required.
   The error occurred in subroutine "SYMFAC" while allocating " INTE" space
   from "SOLV" for the "JACROW array".
   Space Available:  30528    Space Requested:  32168
   ADAMS/Solver requires more program memory to run this model.
   Be aware that the above figures for Space available and Space
   requested only reflect the current requirements.  Additional space
   may be required later in the solution process.
   Several off-the-shelf memory configurations are available and
   custom configurations may be created.  The available memory models
   and the corresponding array sizes are:
          NAME         MDSIZ
        STANDARD    1,100,000
        LARGE       3,000,000
        EX-LARGE   10,000,000
        HUGE       20,000,000
   where MDSIZ is the size in words (one word is 4 bytes) of the MD array,
   the main memory array in ADAMS in words (one word is 4 bytes).
   To use an alternative setting, you have to start the ADAMS 'Settings'
   program.  It can be found using the Start menu:
     Start -> Programs -> MSC.Software -> MSC.ADAMS -> ADAMS-Settings
   Alternatively, you can start 'adams_settings.exe' in the 'utils\win32'
   folder of your ADAMS installation directory.
ERROR:   Abnormal termination encountered in ADAMS/Solver.
ERROR:   ---------------------------------------------------------------------
ERROR:   The command was not executed.
ERROR:   &>    frame=(0)
GMT+8, 2026-6-13 16:39 , Processed in 0.056370 second(s), 13 queries , Gzip On, Redis On.
