查看: 17645|回复: 3
[求助] UGAPI选择EDGE
发表于 2008-6-1 11:33:14 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我按照帮助里面的例子修改的,却始终选择不到实体的EDGE!
帮忙看看哪里错了
#include <stdio.h>
#include <uf.h>
#include <uf_ui.h>
#include <uf_object_types.h>
#include <uf_disp.h>
void ufusr(char *param, int *retcod, int param_len)
int irc = 0;
char *message = "Select Object";
UF_UI_selection_options_t opts;
UF_UI_mask_t mask;
int response;
tag_t object, view;
double cursor[3];
char error[133];
int unhighlight=0;
UF_initialize();
opts.other_options = 0;
opts.reserved = NULL;
opts.num_mask_triples = 1;
opts.mask_triples = &mask;
/* set up selectable type, subtype, solid type */
opts.mask_triples->object_type = UF_edge_type;
opts.mask_triples->object_subtype = 0;
/* set selection scope to be work part */
opts.scope = UF_UI_SEL_SCOPE_WORK_PART;
irc = UF_UI_select_single(message,&opts,&response,
                          &object,cursor,&view);
/* if no error, print information about selected object */
if (!irc)
  printf("response= %d, object tag= %d, view tag= %d, cursor
    position= %f %f %f\n", response, object, view, cursor[0],
    cursor[1],cursor[2]);
  /* unhighlight selected object */
  FTN(uf1640)(&object,&unhighlight);
else  /* else get error message */
  UF_get_fail_message(irc,error);
  printf("ERROR: %s\n",error);
UF_terminate();
发表于 2008-6-1 16:01:48 | 只看该作者
更改为下面三条
opts.mask_triples->object_type = UF_solid_type;
opts.mask_triples->solid_type = UF_UI_SEL_FEATURE_ANY_EDGE;
UF_edge_type这个子类型已经作废了。
发表于 2008-6-2 09:07:49 | 只看该作者
非常感谢楼上的,我马上试试
发表于 2008-6-2 11:30:34 | 只看该作者
    opts.mask_triples->object_subtype = UF_solid_edge_subtype;
   opts.mask_triples->solid_type=UF_UI_SEL_FEATURE_ANY_EDGE;
GMT+8, 2026-7-6 13:18 , Processed in 0.047515 second(s), 11 queries , Gzip On, Redis On.
