查看: 17030|回复: 3
[求助] 有誰有这个后处理的其他四个文件给我一份
发表于 2008-8-12 16:56:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
*  3 axes Post Processor for NC document
* Cimatron90 VER 10.01
* Write by B-Y-D
* Last update :15-Jun-2004
* define private variables:
FORMAT (SEQUENCING)  SubSeq CNTRL_NUM NURBS_DEG count first deg ;
FORMAT (TOOL)        CutterComp FirstTool LastTool PAGE NUM ;
FORMAT (COORDINATES) Xold Yold Zold DXcenter DYcenter DZcenter hu ;
FORMAT (COORDINATES) Zinit Clear Depth CNTRL_X  CNTRL_Y  CNTRL_Z  KNOT_ cleard depthd;
FORMAT (COORDINATES) Xhome Yhome Zhome h1 h3;
FORMAT (COORDINATES)  maxz minz maxx maxy minx miny surftol sidestep downstep ;
FORMAT (COORDINATES) tooldia cornerr tapera CUT_LENGTH ;
FORMAT (COORDINATES) XfirstOrigin YfirstOrigin ZfirstOrigin ;
FORMAT (USER_1)      CurrSubNum   ;
FORMAT (USER_4)      LENGHT TIME OLDFEED DTIME ATIME RAD AANG TPTIME PGTIME  ;
FORMAT (coordinates) ORIGOLDI ORIGOLDJ ORIGOLDK ;
FORMAT (character)   TP_NAME PROC_NAME CURR_NAME TPNAME  TTM DATU H2 JJJ NAME MOLDT FT MZ alarm1 alarm2 alarm3 ;
FORMAT (character)   dname1 dname2 dname3 dname4 dname5 dname6 alarm4 alarm5 alarm6 ;
* define private flags:
FORMAT (USER_2)      FlagSub FlagSeq FlagSpin;
FORMAT (USER_2)      FirstOriginChange FlagError Flagrotmac  ;
FORMAT (COORDINATES) unit maxzo minzo sideso downso  diao rado cuto clearo partto partoffo feedo spino sd;
FORMAT (COORDINATES) minof  ;
* define private constants:
FORMAT (USER_2)      YES NO ZA ;
* change the format of existing variables:
FORMAT (USER_1)      SUB_NUMBER ;
INTERACTION (USER_1) "CAUSE"            cs = 1;
*INTERACTION (USER_1) "CAUSE"            MAINNUM = 1;
*INTERACTION (CHARACTER) "MOLD-NO"      NUMYN = "";
INTERACTION (COORDINATES) "X SIZE"      MX=20;
INTERACTION (CHARACTER) "EDM MODE"      SUB = "N ";
INTERACTION (COORDINATES) "Y SIZE"      MY=20;
INTERACTION (COORDINATES) "MAXPZ"       MMZ=10;
INTERACTION (COORDINATES) "Z SIZE"      MOZ=20.;
INTERACTION (USER_4) "Machine TYPE"     SM =1.;
INTERACTION (CHARACTER)    "Q_S(B/P/T) "       Abs         = "T"  ;
INTERACTION (USER_1) "3R(1=yes)" JR = 1;
NON_MODAL  ALL_VAR;
MODAL      X_CURPOS Y_CURPOS Z_CURPOS ;
MODAL      LIN_MOV CIRC_MOV MCH_FEED SPIN_SPEED SPIN_DIR MCH_COOL MCH_DWELL;
MODAL      CUTCOM_ON  CUTCOM_OFF ;
MODAL      CYC_DEPTH CYC_PECK CYC_DWELL CYC_RETR CYC_CLEAR Depth Clear NURBS_MOV;
MODAL      sidestep surftol downstep PART_TOL SIDE_STEP DOWN_STEP CONT_TOL CONT_OFST ;
*MODAL      NUM PAGE ;
IDENTICAL  X_CURPOS X_ENDPT ;
IDENTICAL  Y_CURPOS Y_ENDPT ;
NEW_LINE_IS $ ;
  OUTPUT \J ;
       surftol   = 0.0 ;
       sidestep  = 0.0 ;
       downstep  = 0.0 ;
       unit      = 1.0 ;
       hu=0;
       h1=0;
       h3=0;
       maxzo=-9999.;
       minzo=9999.;
    BEGINNING OF TAPE:
*     dname1="空刀";
*     dname2="空刀";
*     dname3="空刀";
*     dname4="空刀";
     firsttool=99;
     alarm1="N";
     alarm2="N" ;
     alarm3="N";
     alarm4="N" ;
     maxzo=-9999.;
      minzo=9999.;
     sd=0;
     ATIME = 0 ;
     TIME = 0 ;
     DTIME = 0 ;
     TPTIME = 0 ;
     PGTIME = 0 ;
     PAGE = 1 ;
     NUM = 0 ;
****使用人员库****
     NAME=USER_NAME;
***加工机型判断****
      IF_SET (sm _EQ_ 1) TTM = "罗德斯" ;    END_IF ;
      IF_SET (sm _EQ_ 2) TTM = "马豪机" ;     END_IF ;
      IF_SET (sm _EQ_ 3) TTM = "马扎克" ;     END_IF ;
      IF_SET (sm _EQ_ 4) TTM = "台中精机" ;  END_IF ;
      IF_SET (sm _EQ_ 5) TTM = "丽伟机" ;      END_IF ;
      IF_SET (sm _EQ_ 6) TTM = "森精机" ;      END_IF ;
*****取数方式判断*****
      h2=abs;
      DATU="";
      IF_SET (H2 _EQ_"B") DATU = "底面" ;    END_IF ;
      IF_SET (H2 _EQ_"P") DATU = "PL面" ;    END_IF ;
      IF_SET (H2 _EQ_"T") DATU = "顶面" ;    END_IF ;
      IF_SET (H2 _EQ_"b") DATU = "底面" ;    END_IF ;
      IF_SET (H2 _EQ_"p") DATU = "PL面" ;    END_IF ;
      IF_SET (H2 _EQ_"t") DATU = "顶面" ;    END_IF ;
****3R夹具判断*****
     JJJ="没有 ";
     IF_SET (JR _EQ_ 1) jjj= "使用" ;    END_IF ;
****加工原因判断***
     MOLDT="新开模具";
     IF_SET (cs _EQ_2) MOLDT= "工程变更" ;    END_IF ;
     IF_SET (cs _EQ_3) MOLDT= "设计变更" ;    END_IF ;
********HTM HEAD FORMAT(form)******
      PRINT1 \J "<html>" ;
      PRINT1 \J "<H1 ALIGN=CENTER>";
      PRINT1 \J "<head>" ;
      PRINT1 \J "<title>加工程式单</title>" ;
      PRINT1 \J "</head>" ;
      PRINT1 \J "<body bgcolor="DBL_QUOTE "#fef4d9" DBL_QUOTE "onmouseover=" DBL_QUOTE;
      PRINT1    "self.status='我们的质量方针:";
      PRINT1   "立足精密制造,发展零配件产业;顾客至上,以人为本;尽责尽力,";
      PRINT1    "共探共索,一流产品,一流服务';return true" DBL_QUOTE ">";
      PRINT1 \J "<table border=" DBL_QUOTE "0" DBL_QUOTE " width=" DBL_QUOTE "750" DBL_QUOTE ;
      PRINT1    " height=" DBL_QUOTE "20" DBL_QUOTE ">" ;
      PRINT1 \J "<tr>" ;
      PRINT1 \J "<td width=" DBL_QUOTE "473" DBL_QUOTE " height=" DBL_QUOTE "1" DBL_QUOTE ;
      PRINT1    "<B><FONT SIZE=5><P ALIGN=" DBL_QUOTE "RIGHT" DBL_QUOTE ;
      PRINT1    ">CNC加工程式单</P></B></FONT></td>" ;
      PRINT1 \J "<td width=" DBL_QUOTE "237" DBL_QUOTE " height=" DBL_QUOTE "0" DBL_QUOTE ;
      PRINT1    " SIZE=1 <FONT valign=" DBL_QUOTE "bottom" DBL_QUOTE " align=" DBL_QUOTE ;
      PRINT1    "right" DBL_QUOTE "><P ALIGN=" DBL_QUOTE "RIGHT" DBL_QUOTE "><font size=" ;
      PRINT1    DBL_QUOTE "1" DBL_QUOTE ">********制表" ;
      PRINT1    "</font></P></td>";
      PRINT1 \J  "</tr>" ;
      PRINT1 \J "</table>" ;
*      PRINT1 \J "<div align=" DBL_QUOTE "left" DBL_QUOTE ">" ;
      PRINT1 \J "<table border=" DBL_QUOTE "1" DBL_QUOTE " height=" DBL_QUOTE "16" DBL_QUOTE ;
      PRINT1    " width=" DBL_QUOTE "750" DBL_QUOTE ">" ;
      PRINT1 \J "<tr>" ;
      PRINT1 \J "<td>文件路径" ;
      PRINT1 \J "<td>"part_path ;
      PRINT1 \J "<td>文件名称" ;
      PRINT1 \J "<th>"tp_name ;
      PRINT1 \J "<td>程式制作者" ;
      PRINT1 \J "<th>"name ;
      PRINT1 \J "<td>加工机型" ;
      PRINT1 \J "<th>"ttm ;
      PRINT1 \J "<tr>" ;
      PRINT1 \J "<td >加工原因  " ;
      PRINT1 \J "<TH><FONT SIZE=4 color=" DBL_QUOTE "#FF0000>" ;
      PRINT1    "<P ALIGN=" DBL_QUOTE "CENTER" DBL_QUOTE ">" moldt "</TD>" ;
*      PRINT1 \J "<td>NC档案路径" ;
*      PRINT1 \J "<td>\\ad3172" ;
      PRINT1 \J "<td>Z方向" ;
      PRINT1 \J "<th>"MMZ ;
      PRINT1 \J "<td>加工零点" ;
      PRINT1 \J "<th>X0 Y0" ;
      PRINT1 \J "<td>取数基准</font></td>" ;
      PRINT1 \J "<th>"datu"</font></td>" ;
      PRINT1 \J "<tr>" ;
*      PRINT1 \J "<td >加工原因  </font></td>" ;
*      PRINT1 \J "<TD  ><B><FONT SIZE=4 color=" DBL_QUOTE "#FF0000>" ;
*      PRINT1    "<P ALIGN=" DBL_QUOTE "CENTER" DBL_QUOTE ">" moldt "</TD>" ;
      PRINT1 \J "</div>" ;
      PRINT1 \J "<table border=" DBL_QUOTE "1" DBL_QUOTE " width=" DBL_QUOTE "750" DBL_QUOTE ;
      PRINT1    " height=" DBL_QUOTE "348" DBL_QUOTE ">" ;
      PRINT1 \J "<tr>" ;
      PRINT1 \J "<td width=" DBL_QUOTE "355" DBL_QUOTE " height=" DBL_QUOTE "348" DBL_QUOTE ;
      PRINT1    " rowspan=" DBL_QUOTE "11" DBL_QUOTE "><img border=" DBL_QUOTE "1" DBL_QUOTE ;
***JPG图片
     PRINT1    " src=" DBL_QUOTE PART_NAME ".jpg" DBL_QUOTE " width=" DBL_QUOTE "735" DBL_QUOTE ;
     PRINT1    " height=" DBL_QUOTE "380" DBL_QUOTE "></td>" ;
*       PRINT1 \J "</table>" ;
      IF_SET (SUB _NE_ "N")
      PRINT1 \J "<tr>" ;
      PRINT1 \J "<td>";
      PRINT1    "放电间隙类型:前模(A)后模(B)行位(S)斜顶(X)镶件(C) " ;
      PRINT1 \J "<TD ><B>" sub"</TD>" ;
      PRINT1 \J "<td>放电座标(如图示)";
      PRINT1 \J "<tr>" ;
      END_IF;
      PRINT1 \J  "<td>"   "来料尺寸:     长:"MX" 宽:"MY"  高:"MOZ ;
      PRINT1 \J "<td>3R夹具  </font></td>" ;
      PRINT1 \J "<TD WIDTH=" DBL_QUOTE "11%" DBL_QUOTE " VALIGN=" DBL_QUOTE "middle" DBL_QUOTE ">" ;
      PRINT1 \J "<B><FONT SIZE=3><P ALIGN=" DBL_QUOTE "CENTER" DBL_QUOTE ">" JJJ "</TD>" ;
      PRINT1 \J "</tr>" ;
*      PRINT1 \J "<table border=" DBL_QUOTE "1" DBL_QUOTE " height=" DBL_QUOTE "16" DBL_QUOTE ;
*      PRINT1    " width=" DBL_QUOTE "750" DBL_QUOTE ">" ;
      PRINT1 \J "<tr>" ;
      PRINT1 \J "<td>工件材质∶铜</font></td>" ;
      PRINT1  \J "<TD>加工类型∶ □电极</font></td>" ;
      PRINT1 \J "<table border=.5PT width=" DBL_QUOTE "750" DBL_QUOTE " height=" DBL_QUOTE "58" ;
      PRINT1    DBL_QUOTE ">" ;
      END_IF;
      IF_SET (SUB _EQ_ "N")
      PRINT1 \J "<tr>" ;
      PRINT1 \J "<td>工件材质∶钢</font></td>" ;
      PRINT1 \J "<TD><font size=" DBL_QUOTE "2" DBL_QUOTE ">热处理 □前  □后  </font></td>" ;
      PRINT1  \J "<TD>加工类型∶□前模□后模□行位□斜顶□其它</font></td>" ;
      END_IF;
      PRINT1 \J "<tr>" ;
*****BIAO GE 1*******
      maxz             = -9999.0 ;
      minz             = 9999.0 ;
*****BIAO GE 1*****
      YES              = 1 ;
      NO               = 0 ;
*-----Unit matrix (MUST be input in this order !!!)
      ROT_MAT1   = 1.0 ; ROT_MAT2   = 0.0 ; ROT_MAT3   = 0.0 ;
      ROT_MAT4   = 0.0 ; ROT_MAT5   = 1.0 ; ROT_MAT6   = 0.0 ;
      ROT_MAT7   = 0.0 ; ROT_MAT8   = 0.0 ; ROT_MAT9   = 1.0 ;
*-----shift all data according to the MCHINE ZERO indicated by the
*     user in the POSTPR interaction
      TRANS_MATX = 0 - X_MACH  ;
      TRANS_MATY = 0 - Y_MACH  ;
      TRANS_MATZ = 0 - Z_MACH  ;
*-----shift the HOME according to the MCHINE ZERO indicated by the
      Xhome = X_HOME - X_MACH  ;
      Yhome = Y_HOME - Y_MACH  ;
      Zhome = Z_HOME - Z_MACH  ;
*-----tool location is HOME
      Xold = X_HOME ;
      Yold = Y_HOME ;
      Zold = Z_HOME ;
*-----For 1st ORIGIN CHANGE
      FirstOriginChange = YES ;
      MCH_FEED   = 9999 ;
*--For the first origin change
   ORIGOLDI=0 ; ORIGOLDJ=0 ; ORIGOLDK=1 ;
   flagrotmac = no ;
   TPNAME =TP_NAME ;
FEED:
      KEEP MCH_FEED ;
      IF_SET (MCH_FEED)
      OLDFEED = MCH_FEED ;
*          OUTPUT "(F=" MCH_FEED   ")";
       END_IF ;
BEGINNING OF PROC:
      SD=0;
      TIME = 0 ;
      LENGHT = 0 ;
      maxz = -9999.0 ;
      minz =  9999.0 ;
      KEEP   PROC_NAME ;
      SET_ON MCH_COOL ;
BEGINNING OF TLPATH:
*****BIAO GE****
       PRINT1 \J "<td colspan=" DBL_QUOTE "9" DBL_QUOTE ;
       PRINT1 \J "><FONT  color=" DBL_QUOTE "#FF0000" DBL_QUOTE "SIZE=" DBL_QUOTE "5" DBL_QUOTE;
       PRINT1  ">请操作员仔细核对刀具名称与刀径,半径是否一致,谢谢!</td>";
       PRINT1 \J "<tr>";
       PRINT1 \J "<TD width=" DBL_QUOTE "45" DBL_QUOTE ">刀号" ;
       PRINT1 \J "<TD>刀具名称" ;
       PRINT1 \J "<TD>刀径" ;
       PRINT1 \J "<TD>端部半径" ;
       PRINT1 \J "<TD>刀长" ;
       PRINT1 \J "<TD>刃长" ;
      PRINT1 \J "<TD>主轴转速" ;
      PRINT1 \J "<TD>进给率" ;
      PRINT1 \J "<TD>公差" ;
      PRINT1 \J "<tr>" ;
      TPTIME = 0 ;
       SET_ON  LIN_MOV CIRC_MOV ;
      minof = 999. ;
END OF TOOL PATH:
END OF TAPE:
*-----user define batch file------
      PRINT0 \J "@ECHO OFF" ;
      PRINT0 \J "MD C:\CIM\" PART_NAME ;
      PRINT0 \J "COPY " PART_NAME "." TPNAME ".byd.P01  C:\CIM\"PART_NAME "\" TPNAME  ".HTM> NUL" ;
      PRINT0 \J "COPY " PART_NAME ".JPG  C:\CIM\"PART_NAME "\*.JPG > NUL" ;
      PRINT0 \J "DEL " PART_NAME "." TPNAME ".*" ;
***以下为报错输出****
          IF_SET (minzo  _LT_ -8.01)
          print0 \J  "echo on";
          print0  \J "net send "  user_name ;
          print0 \J  " 系统提示:电极加工的最深深度已过Z-8MM.现在的Z值为:Z-"MINZO;
          print0 \j "del  C:\CIM\"PART_NAME "\" TPNAME  ".HTM";
          print0 \J  ;
          END_IF ;
      END_IF;
********HTML END*******
***页末***
*      PRINT1 \J "<td >开始Z值</font></td>" ;
*      PRINT1 \J "<TD ><B><FONT SIZE=4 color=" DBL_QUOTE "#FF0000" ;
*      PRINT1   "><P ALIGN=" DBL_QUOTE "CENTER" DBL_QUOTE ">" maxzo "</TD>" ;
*      PRINT1 \J "<td>最深Z值</font></td>" ;
*      PRINT1   "><P ALIGN=" DBL_QUOTE "CENTER" DBL_QUOTE ">"minzo"</TD>" ;
      PRINT1 \J "<tr>" ;
      PRINT1 \J "<td >备注:        </font></td>" ;
      PRINT1 \J "<td height=" DBL_QUOTE "28" DBL_QUOTE " width=" DBL_QUOTE "70" DBL_QUOTE ;
      PRINT1    "><font size=" DBL_QUOTE "2" DBL_QUOTE ">制作时间</font></td>" ;
      PRINT1 \J "<td >";
      PRINT1     DATE_SYY "年" DATE_SMM "月" DATE_SDD "日" TIME_SHH "时" TIME_SMM "分</TD>" ;
      PRINT1 \J "</tr>" ;
      PRINT1 \J "<table border=.5PT width=" DBL_QUOTE "750" DBL_QUOTE " height=" DBL_QUOTE "1" ;
      PRINT1 \J "<tr>" ;
      PRINT1 \J "<td width=" DBL_QUOTE "120" DBL_QUOTE " height=" DBL_QUOTE "3" DBL_QUOTE ;
      PRINT1    "><font size=3" DBL_QUOTE "1" DBL_QUOTE ">本页加工时间</font></td>" ;
      PRINT1 \J "<td >" PGTIME" MIN" "</font></td>" ;
      PRINT1 \J "<td >现场人员签名</font></td>" ;
      PRINT1 \J "<td ></font></td>" ;
      PRINT1 \J "</tr>" ;
      PRINT1 \J "</body>" ;
      PRINT1 \J "</html>" ;
END OF PROC:
发表于 2011-11-26 22:20:59 | 只看该作者
发表于 2015-11-19 18:07:35 来自手机 | 只看该作者
发表于 2017-2-7 18:28:01 | 只看该作者
GMT+8, 2026-7-27 06:50 , Processed in 0.047923 second(s), 11 queries , Gzip On, Redis On.
