查看: 17222|回复: 0
[求助] 宏命令应用
发表于 2008-9-4 16:46:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我用范成建《虚拟样机软件MSC.ADAMS应用与提高》中关于用宏命令建立齿轮的应用,
出现三个同样类型的错误:
ERROR:   ---------------------------------------------------------------------
ERROR:   Error detected on line number 123, character 6 of poly_gear.cmd.
ERROR:   No Reference_Frame was found because 'close' does not exist beneath '.gear_5'.
ERROR:   The command was not executed.
ERROR:   &> close=yes relative_to=.gear_5.PART_2.MARKER_1
ERROR:   No Wire_Geometry was found because 'tmp_poly' does not exist beneath '.gear_5.PART_2'.
ERROR:   &> .gear_5.PART_2.gear1  profile_curve=tmp_poly&
ERROR:   No Geometry was found because 'tmp_poly' does not exist beneath '.gear_5.PART_2'.
ERROR:   >> geometry delete geometry_name=tmp_poly
请宏高手指点!
涉及到的宏命令只有三行(红字部分):
file text write&
     format_for_output="close=yes relative_to=%s"&
     values_for_output=($center_marker) newline=yes
file text close
variable delete variable=$_self.inc
variable delete variable=$_self.a_inc,$_self.num_teeth,&
     $_self.out_rad,$_self.in_rad,$_self.out_rad2
file command read file_name=poly_gear
geometry create shape extrusion extrusion_name=&
$ref_part_name.$gear_name profile_curve=tmp_poly&
reference_maker=$center_maker length_along_z_axis=$thickness
命令原文见:
GMT+8, 2026-8-2 19:47 , Processed in 0.050445 second(s), 11 queries , Gzip On, Redis On.
