查看: 17311|回复: 3
[求助] 懂模具英语的高手请进的!!!!急
发表于 2008-9-5 09:19:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1.ADD GUIDE PILALR & BUSH DETAIL IN SECTION VIEW....
3.LOCK EJECTOR PINS AS PER 3D PART PROFILE.....
4.EJECTOR KNOCK-OUT HOLE IS MISSING  HERE
6.ADD ADDITIONAL SCREW BETWEEN BOTTOM PLATE WITH SPACER BLOCK....
7.ADD 3D PRODUCT ISO VIEW HERE.... FRONT & BACK SIDE.... &  ROUGHLY INDICATE ANY POST-OPERATION DETAIL OR ELSE... KEEP IN MIND FOR FUTUER PROJECTS ALSO...
8.ADD SHRINKAGE DETAIL IN TITLE BLOCK
9.ADD STEEL O-RINGS TO CONTROL WATER LEAKAGE....
10.INCREASE SLIDER TOP WEAR THICHNESS...
11.INCREASE SLDIER BASE LENGTH.....  SLIDER BASE LENGHT SHOULD BE CALCULATED BASED ON SLIDER HEIGHT (MIN +1.5 TIMES)....
13.BASED ON SLIDER MOVMENT ADD HASCO STD BALL CATCH FOR SLIDER STOPPER......
14.ADD SLIDER BOTTOM WEAR PLATE
15.FOR BETTER LOCKING ADD 2 SET SCREWS
16.ADD MANY HASCO STD REST BUTTON, Z55  BEHIND THE EJECTOR BACK PLATE
17.KEEP 3.0 mm GAP BETWEEN BOTTOM PLATE & EJECTOR UNIT...
18.ADD EJECTOR GUIDE DETAIL IN PLAN VIEW....
19.ADD EJECTOR GUIDE COUNTER BORE ON CORE PLATE
20.COOLING CHANNELS SHOULD BE IN DIFFERENT COLOUR IN PLAN VIEW & SECTION VIEW.... FOR BETTER VIEWING.....
21.WHY YOU NEED SUCH A BIG SLIDER MOVMENT.... ???????? DOUBLE CONFIRM SLIDER MOVMENT BASED ON 3D PART UNDERCUT & OVER FLOW DISTANCE !!!!
22.ADD ADDITIONAL SUPPORT PILLAR HERE
23.ADD EJECTOR PLATES LOCKING SCREWS IN PLAN VIEW...
24. ADD  EJECTOR PINS & SCREW HEAD + COUNTER BORE DETAIL IN PLAN VIEW.... THEN ONLY WE CAN DECIDE THICKNESS & ETC..... KEEP IN MIND FUTURE PROJECTS ALSO....
25.ADD EJECTOR PINS HERE & MOVE SOME PINS ....
26.CHANGE OVER FLOW DETAILS AS PER OUR MOULD FLOW  REPORT....
发表于 2008-9-5 16:39:26 | 只看该作者
发表于 2008-9-5 16:44:48 | 只看该作者
发表于 2008-9-6 12:36:03 | 只看该作者
GMT+8, 2026-8-3 11:13 , Processed in 0.094242 second(s), 12 queries , Gzip On, Redis On.
